Stuck in wet mode after battery replacement | FerrariChat
Discussion in '458 Italia/488/F8' started by Rajsb89, Apr 21, 2025.
  1. Rajsb89
    Rajsb89 Rookie
    Apr 21, 2025
    2
    Raj Bhandal
    Hi, after replacing the battery on my 488, I’m now getting a series of faults: AVH System Failure, E-Differential, ESC System Failure, and it’s stuck in Wet mode.
    I’ve left the car connected to the battery conditioner, but the issues persist. To perform a full battery reset, should I completely disconnect the battery or just use the quick-release lever?
    I figured I’d check here first before making a trip to the dealer. Car drives fine with no issues.
    thanks.
  2. MANDALAY
    MANDALAY F1 World Champ
    May 23, 2013
    14,259
    AUSTRALIA
    ANGELO
    A disconnected battery is a disconnected battery however I would always disconnect the earth.
    Now I had the same issue and it was drive slowly to the Ferrari dealership and got them to reset.
  3. Jrachetta
    Jrachetta Karting
    Feb 13, 2024
    58
    Syracuse, NY
    Jon Rachetta
    I just had this corrected myself. My battery died and tossed a ton of codes that stored. Dealer just did a reset of the system and everything all good now. Took about an hour or so you should be in and out.
  4. Rajsb89
    Rajsb89 Rookie
    Apr 21, 2025
    2
    Raj Bhandal
    Ok thanks, trip to the dealer it is.
  5. bakermiata
    bakermiata Rookie
    16
    I believe these were the first F cars with "smart alternators" that need to have a relearn process performed by the dealer
  6. SAFE4NOW
    SAFE4NOW F1 Veteran
    Sponsor Owner
    Aug 25, 2004
    5,799
    Dallas Texas
    If you know you know
    Good point!
    Another thing that is being overlooked these days, is that the battery itself needs to be charged ( out of the car ) to 100% BEFORE being installed
    Otherwise the car takes the installed battery current state of charge as 100%, even if it's actually only 60%
    A new battery off the shelf is not always 100%
    S
  7. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,674
    Central NJ
    Dominick
    AS stated above make sure it is 100% and then drive it a little to see if it resets itself on the next few start-ups
