488 - Stuck in Wet Mode and Dealer Cant Clear Lights | Page 2 | FerrariChat
488 Stuck in Wet Mode and Dealer Cant Clear Lights
Discussion in '458 Italia/488/F8' started by DiamondDog, Jul 8, 2022.
  1. GaryTarmac
    GaryTarmac Karting
    Mar 1, 2021
    144
    Gary Tarmac
    Hi
    Just got mine back from the dealership.
    Mine kept going into wet mode because the break pedal light switch was faulty.
    Gary Tarmac
    MANDALAY and Boiler Inspector like this.
  2. Boiler Inspector
    Boiler Inspector Formula Junior
    Oct 14, 2017
    347
    Texas
    Brian
    Apparently this brake pedal switch is a notorious troublemaker. My new to me '13 Spider would randomly throw up AVH failure, ABS failure, Mannetino failure, ESC failure codes and go into Wet mode. I thought it was battery. Dealer had it for other service and pulled codes and said by the way, you need a brake pedal switch because of the symptoms I mentioned. None of those failure warnings sense.
    GaryTarmac likes this.
  3. DiamondDog
    DiamondDog Formula 3
    Aug 29, 2021
    1,422
    Orange County, CA
    Can you tell me the approximate cost this brake pedal switch repair? Just trying to plan for the future
  4. GaryTarmac
    GaryTarmac Karting
    Mar 1, 2021
    144
    Gary Tarmac
    No idea
    Mine was done under warranty but I’m guessing not much if it’s just a switch.
    Gary Tarmac
  5. Boiler Inspector
    Oct 14, 2017
    347
    Texas
    Brian
    $490 before FCA discount. They had the $65 switch in stock. 2 hours labor apparently.
  6. MANDALAY
    MANDALAY F1 World Champ
    May 23, 2013
    14,259
    AUSTRALIA
    ANGELO
    Great that they found the issue. All good again ! DRIVE :)
  7. Pure745
    Pure745 Rookie
    Jul 18, 2021
    26
    Mine is a speed sensor, not covered under warranty.. $1300. Allegedly is triggering a bunch of lights, including the engine light?
  8. nick7777
    nick7777 Rookie
    Jan 29, 2024
    1
    same issue here, any idea which fuse they replaced? checking all, cant even find center console ones
  9. Racerjohn
    Racerjohn Karting
    May 29, 2018
    62
    California
    Do you know where the location of that specific fuse was? Was it one of the big ones on top of the positive battery terminal??
  10. DiamondDog
    Aug 29, 2021
    1,422
    Orange County, CA
    It ended up being Fuse F40 and not a 40 Amp fuse. I posted the correction on another thread. I believe it was for the hydrolic system. Not sure where it was located.
  11. hex337
    hex337 Rookie
    May 20, 2024
    47
    Alex Kleissner
    I bought a 458 spider in May, and it would drive fine for a little bit, and then it would go into limp mode like you described with everything turning off and the car set in wet mode only.
    The car had the dealer warranty, and they first looked for wiring issues and found one that might be causing it, but that ended up not fixing it. After more investigation and figuring it out how to trigger it (going over a speed bump or onramps onto the freeway seemed to do it), it ended up being a bad ABS sensor. When any of the wheels had a little bit of traction loss, the sensor would freak out and turn off all the assists in the car.
    These issues are so frustrating to figure out, but I would highly recommend getting a tool to read error codes (helped me narrow down what was happening since it would sometimes start up with no errors until I was driving for a bit, and then it would just crap out).
  12. DiamondDog
    Aug 29, 2021
    1,422
    Orange County, CA
    Which tool did you buy?
  13. hex337
    hex337 Rookie
    May 20, 2024
    47
    Alex Kleissner
    For the 458, the MOTOPOWER MP69033 Car OBD2 Scanner Code Reader works to read codes.
  14. Racerjohn
    Racerjohn Karting
    May 29, 2018
    62
    California
    What was the resolution? I have a new Anti Gravity battery new ABS wheel sensors and still have this ****
  15. dgl36
    dgl36 Karting
    Feb 20, 2013
    108
    Canada
    I'm wondering exactly which fuse was blown in what fuse area?
  16. DiamondDog
    Aug 29, 2021
    1,422
    Orange County, CA
    Dealer simply Stated Fuse F40 on the invoice
  17. Mrpseudonym
    Mrpseudonym Formula Junior
    585
    Sydney, Australia
    Ah so perhaps fuse 40, not a 40A fuse?
  18. DiamondDog
    Aug 29, 2021
    1,422
    Orange County, CA
    Yes, fuse F40 but still unclear to exactly what the fuse controls
  19. Mrpseudonym
    585
    Sydney, Australia
    Heated rear windscreen on the GTB, I don’t have the spider manual at hand
  20. dgl36
    dgl36 Karting
    Feb 20, 2013
    108
    Canada
    #45 dgl36, Feb 7, 2025
    F-40 is a 30amp fuse for the heated rear screen. Odd that a fuse for the heated rear screen would have this affect.
  21. dgl36
    dgl36 Karting
    Feb 20, 2013
    108
    Canada
    Now to find the bank of fuses containing fuse F-40. The manual says it is located on the driver's side dash in the bank called Body Computer fuses and replays. I looked in this area and could not find it. Fuses are suppose to be serviceable.
  22. dgl36
    dgl36 Karting
    Feb 20, 2013
    108
    Canada
    Found the fuse bank. Now to check the fuses.
  23. Mrpseudonym
    585
    Sydney, Australia
    And the answer is …?
  24. dgl36
    dgl36 Karting
    Feb 20, 2013
    108
    Canada
    And, the answer is... all good. No blown fuses.
  25. dgl36
    dgl36 Karting
    Feb 20, 2013
    108
    Canada
    Did you get this worked out?
