Stuck Key in 1986 3.2 | FerrariChat
Discussion in 'Mondial' started by cianfichi, Mar 5, 2020.
  1. cianfichi
    cianfichi Rookie
    Oct 21, 2013
    49
    Hey guys out of nowhere the key gets stuck in the ignition. It wont turn, and takes a couple minutes of gentle wiggling to free it. This just started happening out of nowhere. The silver metal "strike plate" assembly that the key goes in to appears to be loose a bit. Alas, if you wiggle the key you can eventually get it to turn forward to start the car.
    So has anyone replaced the tumbler in your Mondial? What part number would the tumbler be? How has the part? Do you get a new key for it also? Is this a locksmith job? Algar Ferrari? Do it yourself?
    Thanks ahead for your timely response, I need to get my Mondial started and moved soon!
    Vince
  2. BillyD
    BillyD Formula 3
    1,837
    Pacific Northwest
    Bill
    I’d use a lock lube 1st
  3. Meister
    Meister F1 Veteran
    5,516
    Duluth, MN
    The Meister
    yeah this happens on my 85 often. For some reason I had a locksmith at the house and IIRC he suggested a dry lube like graphite. Have yet to try it.
  4. Mondi Cab
    Mondi Cab Karting
    Oct 9, 2019
    170
    EU
    J.Schulz
    Agree: Take Graphite. but also WD40 would help you out right now if desperate.
    The difference is, that WD40 (or alike) are wet lubes and thus attract dust particles that could stick on to it, resulting in repeated blocking of your lock weeks or months later.
    Had to lube a boot lock last week. Key was stuck half way with no where to go and could not leave the car like that on the street.
    Sprayd it, works fine now.
    Make sure to move the key in and out whilst or just after lubing so the stuff gets where it is supposed to go.....
  5. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,994
    Isle of man- uk
    You lub it with wd 40 until it comes out, then use some contact cleaner spray to clear out the wd 40 when you get the key out. I believe you can use a soft graphite pencil to rub over the key as a lub.
  6. cianfichi
    cianfichi Rookie
    Oct 21, 2013
    49
    Mechanic (yes this decided to happen on my way leaving a service- I didn't mention that initially) did spray some lock lube and that seems to help the key in and out. For sure trying the lube thing is real time right now. But my concern is the tumbler and/or something else is worn out.
    I will try some graphite. Because even WD40 can gunk up over time. I think the contact cleaner is a good idea I'll try that.
    Vince
  7. cianfichi
    cianfichi Rookie
    Oct 21, 2013
    49
    Sprayed wd40 and the key is moving in and out nicely. Turns also. Didnt start the car yet, but it will turn far enough to start. Question is why use contact cleaner? Thanks for the assistance fellas!
    Vince
  8. Wade
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
    Contact cleaner is for trying to clean out the old gunk and grit before applying some fresh lubricant.
  9. cianfichi
    cianfichi Rookie
    Oct 21, 2013
    49
    Right, thank you Wade. I suspect my issue could be something faulty in the steering column with respect to some of the mechanisms internally. For example, sometimes the turn signal stalk slips, or will not hold, or will not turn off. Whatever is causing that may be getting worse and/or starting to affect the operation of the key. Any thoughts?
  10. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,994
    Isle of man- uk
    The contact cleaner might just clean the contacts inside the key body, no reason you cannot put the wd 40 back in later as the contact cleaner will evaporate. Other wise use the graphite off a soft pencil
  11. cianfichi
    cianfichi Rookie
    Oct 21, 2013
    49
    So today I started the car, drove, stopped, shut off. A few times. No issues. Just a sticky ignition switch most likely. WD40 worked very well. It's strange that it all froze out of nowhere. But it can happen again, so future checklist item to check the steering column components, ignition switch, tumbler, stalks etc. Thanks for the help guys!
    Vince
    Wade likes this.
  12. JessN16
    JessN16 Rookie
    Sep 20, 2019
    25
    Jess Nicholas
    Something I've found to use on keys in general -- with great results, and as yet, with no future "gumming up" of anything -- is gun oil. I got mine at Wal-Mart, spray can with a maroon label. I've fixed locks on a bank, door locks and ignition locks in cars, a lock on a gun cabinet (apropos), and the locks on my house. Can't remember the exact manufacturer right now but next time I see that can, I'll update.
    Jess
