Stud Remover Kit | Page 2 | FerrariChat
Stud Remover Kit
Discussion in 'Technical Q&A' started by Futureman, Feb 3, 2011.
  1. Lawrence Coppari
    Lawrence Coppari Formula 3
    Apr 29, 2002
    2,192
    Kingsport, TN
    Lawrence A. Coppari
    If stud removal is so difficult and you risk breaking off a stud, why don't you remove the gas tank? Gas tank removal is not so hard to do. I've done it twice myself on my 328. Trickiest part is getting it to slip past the rear axle.
  2. Robz328
    Robz328 F1 Veteran
    6,299
    ATL, Georgia
    Rob Hemphill
    If you are just trying to remove the compressor, why do you need to remove the studs from the block?
  3. Futureman
    Futureman Formula 3
    May 16, 2007
    2,024
    Because it won't come out with them in the way. You can't drop it down low enough to get the compressor studs out of the top bracket. I went through all this last year.
  4. Robz328
    Robz328 F1 Veteran
    6,299
    ATL, Georgia
    Rob Hemphill
    #29 Robz328, Feb 8, 2011
    Sorry about that. I certainly understand your frustration.
    I don't remember taking the engine block studs out when I removed my AC compressor. Maybe the AC studs were short enough or had been shortened. Maybe you could reinstall the compressor (without the shims...just keep note of their placement), cut down the compressor studs a little at the brackets, and then remove without removing engine block studs.
    I think I would have remembered if I had to remove the long engine block studs. BTW, they are much longer since they go beneath the timing cover; there is actually smooth shank closer to the block. With the long length you are trying to undo, you could be putting a lot of the torsion stress into the full length of the stud that is outside the block.
    You may consider loosening the gas tank strap to allow some play for removal.
    Whatever you do, once you get it out, design something to make it easier to remove next time (like with a belt change). This may include shortening the studs all around, and possibly grinding some access into the brackets (I'm surprised how huge they are).
    Rob H
  5. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,671
    San Carlos, CA
    Mitchell Le
    I had to remove all those studs on my 328 for the compressor to swing out of the way.
  6. Robz328
    Robz328 F1 Veteran
    6,299
    ATL, Georgia
    Rob Hemphill
    Did you do anything to make it easier to remove the next time?
    Recall, I deliberately removed my AC system entirely. I will investigate new AC methods later.
  7. Peter
    Peter F1 Veteran
    Dec 21, 2000
    6,441
    B.C., Canada
    What about in cases where the fastener (whether bolt or nut) is set to a specific torque rating? From what I know, it's best NOT to apply anti-seize as it'll allow the fastener to turn too easily and there'll be a chance that too much torque will be applied.
  8. wrxmike
    wrxmike Moderator
    Moderator Owner
    Mar 20, 2004
    7,675
    #33 wrxmike, Feb 9, 2011
    I highly recommend the Snap on- #CG500-2 with the correct insert to match the thread. Won't damage the thread like the roller style removers and not too large so will fit in most places. They are expensive though.
    M
  9. Futureman
    Futureman Formula 3
    May 16, 2007
    2,024
    #34 Futureman, Feb 15, 2011
    I finally got those suckers out! I bought some new nuts and used the red loctite. When those things came out I felt like Mel Gibson in Braveheart. "...you'll never take our FREEDOM!!" (Of course, when they wouldn't come out I felt like Mel Gibson chatting with Oksana's voicemail.)
  10. yelcab
    Nov 29, 2001
    13,671
    San Carlos, CA
    Mitchell Le
    No kidding, they are insanely expensive.
  11. Robz328
    Robz328 F1 Veteran
    6,299
    ATL, Georgia
    Rob Hemphill
    Success is good!
  12. SeattleM5
    SeattleM5 Formula 3
    1,265
    Kirkland, Washington
    Ettore Palazzo
    Ha! Funny stuff. Congratulations on getting those out.
  13. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,464
    Dumpster Fire #31
    SMG
    having just gone thru this on a couple blocks last week, here's what I found works best.
    stick the block in the oven heat to 220F, you're gonna need the hyper expensive collett remover and impact gun, grab a can of loctite freeze and spray stud while removing. also helps if you got some penetrating oil in there.
    I've got the roller ones that work on non seized studs, threaded ones for install and the offset cam one that is good if you've got the space and is hit or miss on the head studs.
    In general the loctite freeze off stuff is great, last resort was to heat the block. of course not everyone has a walk in oven :(
  14. Norm512TR
    Norm512TR Formula Junior
    Nov 10, 2001
    895
    Colorado Springs, Colorado
    Norm
    Now that the problem has been solved, I feel comfortable offering my solution.
    Ice Dancing- I've found that if I put an ice dancing program on the TV all the studs will leave the room and usually the entire house is clear.
  15. Futureman
    Futureman Formula 3
    May 16, 2007
    2,024
    #40 Futureman, Feb 16, 2011
    Think before you type. I'd watch Tanith clip her toenails. :D
