stupid F1 is stuck in nutrual and pump isnt coming on | FerrariChat
Discussion in '348/355' started by phrogs, May 21, 2016.
  1. phrogs
    phrogs F1 Veteran
    7,352
    Kzoo Michigan
    sorry stuck in first.
    Im stuck at a gas station so.
    where is the fuse that can blow?
    it has a brand new relay installed as well.
    pleanty of fluid and it drove here fine no light that I saw just got gas and then turned key and no pump noise.
    save me a tow anyone have any ideas what else it can be?
    I also.did the foot on the brake and turn the key remedy didnt work.
  2. phrogs
    phrogs F1 Veteran
    7,352
    Kzoo Michigan
    ok check hughe fuses in pass footwell they wew good wiggled everything and now it works.
    stupid thing
  3. phrogs
    phrogs F1 Veteran
    7,352
    Kzoo Michigan
    ok now it pumps im in nutrual but it wont shift and dash light is on.
  4. Subarubrat
    Subarubrat Formula 3
    Apr 1, 2009
    2,072
    VA
    Scott
  5. greg328
    greg328 F1 Rookie
    Nov 17, 2003
    4,209
    Austin, TX USA
    Greg
    Don't PM answers, put them here , we want to see!
    Sent from my LG-H901 using Tapatalk
  6. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    Shut off the battery switch for a few minutes and turn it back on and try, Johnny
  7. Subarubrat
    Apr 1, 2009
    2,072
    VA
    Scott
    #7 Subarubrat, May 21, 2016
    @ greg, I just PM'd my phone number....
    Johnny, here is that self learn sequence, when Tom's F1 was in a similar state it cleared it for him, stuck in your shoes I would give it a go.
    1. Turn key on wait for dash light sequence
    2. Press and hold (for duration, until success beep after calibration) AUTO button
    3. Press and hold (again, for complete duration) accelerator down to floor
    4. Press brake twice then hold on 3rd time, release when done
    Link to owners manual PDF for you: http://aussieexotics.com/forum/dlattach/attach,1998/ferrari/ferrari-f355-owners-manual-313.0.html
  8. phrogs
    phrogs F1 Veteran
    7,352
    Kzoo Michigan
    did just like you desribed, key on, pushed and hold auto button, push and hold gas pedal, hits break twice and hold.
    no joy.
    how long should the self learn take and have to hold them all??
  9. Subarubrat
    Apr 1, 2009
    2,072
    VA
    Scott
    3 brake pumps, hold on #3.
    Did you get that pump fuse connection working?
  10. Steve355F1
    Steve355F1 F1 World Champ
    Aug 26, 2011
    17,174
    Adelaide, South Aust
    Steve
    Is the gas flap closed properly?
  11. phrogs
    phrogs F1 Veteran
    7,352
    Kzoo Michigan
    yeah pump is just dead nothing happening.
    wondering of my new relay **** the bed.
    I replace the old one just because and now no workie
  12. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Do you mean the engine bonnet? That switch is tied to the F1 system.
  13. phrogs
    phrogs F1 Veteran
    7,352
    Kzoo Michigan
    no sensor on gas lid
  14. Subarubrat
    Apr 1, 2009
    2,072
    VA
    Scott
    Does the gas station or any place nearby sell multimeters? You could grab one and check the power out of the 40amp fuse, relay, and at the pump's connector. Calibration routine won't work if the pump isn't working.
  15. phrogs
    phrogs F1 Veteran
    7,352
    Kzoo Michigan
    #15 phrogs, May 21, 2016
    yeah I should have known but out of frustration tried anyway.
    Also tried a new fuse, and swapped out the relay with another new one I have.
    still nothing from the pump.
  16. phrogs
    phrogs F1 Veteran
    7,352
    Kzoo Michigan
    well I have 12 volts at the pump harnesss so its getting power just fine just no pumpy at the pump.
    Im going to guess the pump is dead at this point.
    Time to tow it home. I guess
  17. Subarubrat
    Apr 1, 2009
    2,072
    VA
    Scott
    If your getting 12v at the pump, then that is a pretty solid assumption, baring some current supply issue from a connection that appears under load. You could try the old starter trick and tap on the pump motor right after you get the key turned when it should be priming, might get it off the bad spot on the comm which could get you home. Time for a 360 upgrade then.
  18. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,016
    Indio Ca/ Alberta
    Grant
    Theres a connector at the back drivers side for the pumo get someone to hit the key to on and wiggle that connector.
  19. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,016
    Indio Ca/ Alberta
    Grant
    Its likely the fuse under pass footwell check both or the connector at back by pump. Hope this helps.
    Then check amps from pump when running usually between 10 and 20 while shifting.
  20. phrogs
    phrogs F1 Veteran
    7,352
    Kzoo Michigan
    #20 phrogs, May 21, 2016
    well I swapped the 40 amp footwell fuse just for giggles and it wasnt the fuse, but since I did that I checked it and I have 12 volts at the plug at the F1 pump, the fuse and relay are fine because theres 12 volts to the pump
    have to dig some more now that its home but Im over it for today.
  21. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,016
    Indio Ca/ Alberta
    Grant
    Probably bad connection at that plug at the back. I replaced the contacts on mine and its good now. Like i said have someone turn the key on and wiggle that back plug.
  22. WATSON
    23,834
    WI
    Original pump..or does it have the 360 swap out?
  23. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Can someone please explain the actual technical reasons to upgrade to the 360 pump? I hear it mentioned here all the time but I don't seem to recall reading the technical benefits aside from it primes quicker. Looking to understand if this is really required or not as my OEM pumps is not having any issues.
  24. tres55
    tres55 F1 Rookie
    3,572
    Canada
    Primes quicker and holds pressure better during spirited driving. Apparently handles heat much better as well (we all know the 355 produces plenty of that).
    I personally feel like my shift times improved slightly after the upgrade...more crisp if you will. That may have something to do with the old pump just being worn out though. Priming time was definitely obvious however.
  25. Subarubrat
    Apr 1, 2009
    2,072
    VA
    Scott
    What he said, and it allows for the easy addition of a heat sink for a longer life. The conversion also adds a filter to the system. And of course you can find one allot easier next time replacement comes due.
