Sub replacement | FerrariChat
Sub replacement
Discussion in '360/430' started by rcuming, Apr 13, 2011.
  1. rcuming
    rcuming Formula Junior
    Oct 18, 2009
    255
    Houston, Texas
    Reid
    Is there a good quality sub replacement for the 360 stock speaker that can just be "dropped in"?
  2. Piper
    Piper Two Time F1 World Champ
    Jun 6, 2010
    25,415
    Northern Virginia
    Bob
    If you search, there are a few threads going about this right now. Focal seems to make a 5" true subwoofer that might fit in the factory box with little mod. Just dropping in implies using the facory amp, too. We're all struggling with trying to mod our cars the least possible whiel still getting decent sound. I just "dropped in" replacement speakers and now am getting the head unit to drive them because without it, pearls before swine. Same thing with the sub. Putting a good sub or mid sub in there without changing the amp would give you least possible return on investment.
  3. needspeed
    needspeed Formula Junior
    Oct 5, 2006
    579
    Middle of nowhere IA
    Steve
    The thing that is odd about the sub is that it comes with a dedicated amp. So you would think the power should be there and puting in a high quality driver would help a lot. Since the stock driver looks like pure junk.
    As discussed in the other thread, I will have the Focal woofer tomorrow and put it in Friday night or Saturday and will report back my findings. I am not expecting real sub bass just appropriate and acurate base fill to give the sound some body, palpability even :D.......Steve
  4. Big Carrot
    Big Carrot Karting
    Nov 28, 2006
    172
    Dallas
    Crockett
    I put a little Bazooka tube behind my passenger seat and it sounds pretty good. Gives me enough bass to think I have a real stereo without rattling the car to death.
  5. needspeed
    Oct 5, 2006
    579
    Steve
    I installed my Focal 5" last night, unfortunately the coil is misaligned which creates a buzzing sound. It works well enough in testing to show real promise. Not deep base, but real base fill and punch. I hooked the original driver up in place of the passive unit along with the Focal in a push-push config and that is even better. I am going to order two new Focals and send the bad one back. The stock sub amp has plenty of power from what I can tell........Steve
  6. PbPedis
    PbPedis Formula Junior
    May 6, 2007
    710
    Ontario, Canada
    Dennis
    Please update us when you get 2 Focals in there. Is the rest of your system stock right now?
  7. needspeed
    Oct 5, 2006
    579
    Steve
    Yes, I figure I will change one thing at a time and see how it builds up......Steve
  8. Piper
    Jun 6, 2010
    25,415
    Northern Virginia
    Bob
    Glad it seems like you're on the right track. Not knowing about the focal sub at first, I've gone a different route, also adding one thing at a time. Was supposed to have the head unit installed Friday, but UPS screwed up the delivery thursday, so now that's into next week. If I still feel I need a sub after the head unit replacement, we're going to try to stick it in the facory sub amp location under the dash. Not going to rule out starting over if you rave about youirs though. I'm no stranger to redoing expensive mistakes.
  9. chris360hawks
    chris360hawks Formula Junior
    May 29, 2007
    477
    San Antonio, Texas
    Chris Hard
    Did the Focal just drop in easily to the stock enclosure?
  10. needspeed
    Oct 5, 2006
    579
    Steve
    #10 needspeed, Apr 17, 2011
    Had to get out the Dremmel and open up the cutout 1/4 inch. Then used two layers of Dynomat as a spacer to bring the speaker out flush with enclosue......Steve
  11. needspeed
    Oct 5, 2006
    579
    Steve
    So I have 2 Focal Utopia Be® 13 WS Shallow-mount 5" 4-ohm subwoofers installed in the stock F430 base enclosure between the seats running from the factory sub amp.
    The amp puts out plenty of power and the sound is much fuller and punchier than before. The cabin is filled with a richness that was missing with the stock sub/passive setup.
    This setup will not produce sub base, just enough to really fill in the bottom that is missing from the door speakers.
    The issue I am working on now is that the stock enclosure is not very strong and is leaky. So I am getting some enclosure buzz. I am going to remove it and see if I can brace it a bit internally and dynomat the crap out of it.
    So far my little project shows promise and I will report back over the weekend including some pictures.......Steve
  12. PbPedis
    May 6, 2007
    710
    Ontario, Canada
    Dennis
    Thanks for the update. I guess you feel this is worthwhile to do? I went for a drive today and with the engine and road noise, the "hi fi" stereo option pretty much sounds like am radio.
  13. Piper
    Jun 6, 2010
    25,415
    Northern Virginia
    Bob
    I was checking out my new head unit, tweaking options while driving and found myself forgetting to shift now and again, looked up to see 7500 rpm :) Definitely not hearing the motor over the stereo now, unless I want to. Just need to get a sub in there.
  14. needspeed
    Oct 5, 2006
    579
    Steve
    Which head unit did you get????
  15. Piper
    Jun 6, 2010
    25,415
    Northern Virginia
    Bob
    #15 Piper, Apr 22, 2011
  16. -CD-
    -CD- F1 Rookie
    3,834
    near the Nürburgring
    Christian
    Ist the stock sub amplifier in the sub box or under the dashboard?
    Or is the amplifier under the dashboard only for the door system?
    Greetings Christian
  17. -CD-
    -CD- F1 Rookie
    3,834
    Christian
    Thanks for the link but i want to keep the original sub box and i have already a Focal Sub for the replacement.
    Greetings Christian
  18. DonJuan348
    DonJuan348 F1 Rookie
    Aug 5, 2008
    4,442
    Taxing Jersey
    I thought you wanted deeper bass . You can also try a stronger cleaner amp. Factory amp suck. The Utopias you should produce good mid bass
  19. tubeguy
    tubeguy Formula 3
    May 21, 2003
    1,041
    Upland California
    Kevin Deal
    Mid bass is all you are gonna get in that cabin anyway. I'll take nice fat midbass any day.
    My guess is that you can fix up that sub enclosure by lining the inside with fiberglass. If you don't want to deal with it I would guess a car stereo dealer would be able to knock it out for you.
    I would like to upgrade my system too. My head unit may be giving me fits. But getting a handle on what drivers will mount in that sub enclosure would be handy. Two 5" drivers wired in parallel.
    So PLEASE post back to this thread.
  20. -CD-
    -CD- F1 Rookie
    3,834
    Christian
    #21 -CD-, May 2, 2012
