Sub woofer speaker replacement | FerrariChat
Discussion in '360/430' started by SCKOMS, Jul 22, 2014.
  1. SCKOMS
    SCKOMS F1 Rookie
    3,900
    Lake County, IL
    Spiro
    A while back there was a detailed post about replacing the sub woofer's "speakers" with regular speakers to get rid of the annoying pops. It documented the process nicely with photographs and a great description. I have searched extensively for that thread but can't seem to find it using the search function. Does anyone have that link?
    Thanks!
  2. SoftwareDrone
    SoftwareDrone F1 Veteran
    Sponsor Owner Rossa Subscribed
    Jan 19, 2004
    7,842
    San Jose, California
    #2 SoftwareDrone, Jul 22, 2014
    Were you wanting to replace the speakers in the OEM subwoofer box, or were you wanting to replace the subwoofer box altogether? I may sound biased, but the best you will be able to do with the OEM box is to stuff one 6 1/2" sub in the top and a 5 1/4" speaker in the bottom. With a new subwoofer box, you can fit an 8" sub in there and the enclosure will still completely clear the seats (not to mention it will definitely move your hair!).
  3. SCKOMS
    SCKOMS F1 Rookie
    3,900
    Lake County, IL
    Spiro
    I am familiar with your work and followed it's development through your posts...it looks great and I'm sure it sounds terrific. I am just looking to improve sound quality somewhat, but mainly to eliminate the "thumping" or "popping" that plagues the OEM set up. The post I was inquiring about used 2 identical stock 5.25" speakers, but there was something about the way in which they were wired, IIRC.
  4. SoftwareDrone
    Jan 19, 2004
    7,842
    I will search as well and see if I can find that post. I do know that the OEM setup is that one of the speakers is wired up and the other is not (i.e. passive radiator).
  5. bshah
    bshah Formula Junior
    Jun 28, 2011
    326
    Chicago
    I think you have to use FOCALS in the hi-fi sub box. They fit with no modding. There is a guy at ABT that works on F-Cars. I have his name if you need it.
  6. SCKOMS
    SCKOMS F1 Rookie
    3,900
    Lake County, IL
    Spiro
    Thanks Binoy. I had my head unit, radar detector and back up camera done at Abt. They suggested a new box with a proper sub woofer.
    Still trying to find the thread that addressed the speaker replacement with what I believe were Pioneers.
  7. MPtolomey
    MPtolomey Formula Junior
    Jun 8, 2014
    538
    Odessa, FL
    Mark Ptolomey
    JL makes a sub that will fit. I placed two in my factory box and they sound great. The factory sub has a dual voice coil, so you can drive 2 single voice coil speakers using the factory wiring.
  8. SCKOMS
    SCKOMS F1 Rookie
    3,900
    Lake County, IL
    Spiro
    Can you please provide some details on the speakers and how you wired them?
  9. MPtolomey
    Jun 8, 2014
    538
    Odessa, FL
    Mark Ptolomey
    JL Audio C5-525CW 5.25, you can pick them up for $149/each on Amazon. The stock woofer has a dual voice coil so you have a + and a - wire going to each side. Just take the + and - from one side for one of the JL's and the other + and - from the other side to the 2nd JL.
    I did solder a quick disconnect onto one of the cable sets to facilitate speaker installation/removal.
    Factory grills fit or you can use the JL supplied grills with or without logo.
  10. SCKOMS
    SCKOMS F1 Rookie
    3,900
    Lake County, IL
    Spiro
    Thanks! I finally found the thread I was searching for......on a different forum.
  11. Tnopud
    Tnopud Rookie
    Jul 19, 2014
    24
    Trois-Rivières QC Ca
    Pierre Dupont
    Does anyone knows how to remove the sub box to get to the fuses box Behring passsenger seat?
  12. bisel
    bisel Formula 3
    1,138
    Scottsdale, Arizona
    Steve Bisel
    Gently pry off the speaker grill. There are four plastic tabs that insert into the speaker ring. Try not to break them. If you do break the plastic tabs, you can reattach the speaker grill with some Velcro. Ask me how I know this.
    Remove the top speaker (or maybe it is merely a passive radiator dome). Reach in the box and disconnect the speaker. Then inside the sub box on the rear surface are two hex socket screws that mount the box. Remove those screws and lift the box out.
    Now you can access the fuse panel. When you put the fuse panel back, do not insert the screw directly under the sub woofer box. In this way you will not have to remove the sub woofer box next time you want to access the fuses.
    Regards,
    Steve
  13. Tnopud
    Tnopud Rookie
    Jul 19, 2014
    24
    Pierre Dupont
    Thank you so Much
    Regards Pierre
  14. jetdok5
    jetdok5 Karting
    Oct 4, 2014
    50
    warren ohio usa
    bruce gray
    the crackling coming from mine was repaired and here is how. Remove the grills, turn on the music and look at the speaker....the cone has probably come loose and you can clearly see it vibrating at the very outer edge. I used dental picks and gently lifted the outer ring from the surface, took a qtip and applied RTV sealant behind the surface to re-glue it down. Once you get the sealant on, gently smooth it out and let sealant cure....a day should be good. I would be careful and lift even the areas that have not yet separated and do the whole way around. Turn the music on and you should see no vibration and hear no crackling. I first thought my speakers were blown....they sort of were, but it turned out to be a very effective low cost repair. That was last year.
  15. John_K_348
    John_K_348 F1 Rookie
    Sep 20, 2013
    2,753
    Boston, MA
    John E. Kenney
    Hey, cool fix. But I have two 6.25 inch boxes on order for my J&L speakers I got fro my 348. A buddy of mine made carbon boxes fro them but never got them to me over a couple years before my 348 got hit. So I will fit the generic boxes behind the seats in the 360, I hope ;)
  16. Night life
    Night life F1 Veteran
    7,273
    The city that rhymes with fun in Canada
    Roberto
    Try these, fit perfect, sound great, tight hard thump bass, not hip hop kid bass
    http://www.ferrarichat.com/forum/360-430-sponsored-yellow-compass-group/482771-finally-i-found-sub-woofers-fit-rock-addition-clarion-deck.html
  17. John_K_348
    Sep 20, 2013
    2,753
    Boston, MA
    John E. Kenney
    Awwwe, but I want the tunable 20hz bass ;) No sweat, anything is better than that 5 inch fake box.
    Sent from my SM-G900T using Tapatalk
  18. John_K_348
    Sep 20, 2013
    2,753
    Boston, MA
    John E. Kenney
    I hope the generic boxes from amazon are deep enough and do actually fit. If not, then in the trunk.
