Suggested car lifts? | FerrariChat
Discussion in 'Boxers/TR/M' started by rpissm, Jan 31, 2014.
  1. rpissm
    rpissm Formula 3
    Aug 11, 2013
    1,620
    Salt Lake City, UT
    Joe
    Heeeey again everyone!
    I'm looking to buy a car lift for my TR, and while I would love to get one of those slick hydraulic post lifts (like this BendPak XPR-10 Two Post Lift for Cars & Trucks) I don't think I'll have enough space in my garage for it. So, I've come across a scissor lift such as this: FREE SHIPPING — Bend Pak Portable Mid-Rise Scissor Lift — 6000-Lb. Capacity, Model# MD-6XP | Scissor Lifts| Northern Tool + Equipment
    However, I read that the car's weight needs to be centered on the lift to be safe. Given the TR's butt-heavy weight distribution and the fact that the rear jack point is located ahead of the engine compartment, is this a dangerous arrangement?
    Joe
  2. okiedude
    okiedude Formula 3
    Jul 11, 2011
    1,013
    Remulak
    Blake
  3. rpissm
    rpissm Formula 3
    Aug 11, 2013
    1,620
    Salt Lake City, UT
    Joe
    Yeah true, but do you have any concerns with the possibility that the TR might flip off the back, given how rear-heavy it is and the forward location of its rear jack point?
    Sent from my Nexus 10 using Tapatalk
  4. Melvok
    Melvok F1 World Champ
    Jul 25, 2008
    14,252
    Mel
    There was a good posting on lifts here Joe, only some weeks ago ..... :)
  5. teveo
    teveo Formula Junior
    Oct 1, 2005
    403
    Norway
    Trond Vidar
    #5 teveo, Feb 1, 2014
    Mel is right, there have been some decent discussion on this, just search "maxjax".
    Depending space available, I prefer a 4 post lift to a 2 post, you loose a little flexibility but gain safety and an extra parking space if the roof is high enough. If you add a rolling bridge you will have all the flexibility you need.
    The 2 post require ground work (usually more concrete under the mounting points), most 4 post lifts today are self bearing and even if a little sloppy unloaded they become very stable when the car is loaded and if you get a caster kit you can move it around as well.
    Installed a Dannmar lift in my storage/garage last year and am very happy with it. I have this one.
    FREE SHIPPING — Dannmar 4-Post Auto Lift — 7000-Lb. Capacity, 85in. Max Rise, Model# Commander 7000X | Four-Post Lifts| Northern Tool + Equipment
    Do not have the rolling bridge but rather a cheaper jack platform (enough for a hobbyist).
    FREE SHIPPING — Dannmar Solid Steel Jack Platform for Commander 7000 and 7000X, Model# JP-3 | Lift Accessories| Northern Tool + Equipment
    If the 4 post fit in your garage its a great tool, and you do not have to run it all up if the height is the problem. Here is mine, sorry no TR shot yet.
  6. John B
    John B Formula 3
    May 27, 2003
    1,564
    NJ
    I'm installing two BendPak HD9's in my garage next week.
  7. okiedude
    okiedude Formula 3
    Jul 11, 2011
    1,013
    Remulak
    Blake
    I linked that in my post. It shows pics of a TR and 911 on the lift in question.
  8. okiedude
    okiedude Formula 3
    Jul 11, 2011
    1,013
    Remulak
    Blake
    Trond is right about the 4 post it's my first choice (I have two), the rolling bridge is a must unless you are simply using the lift for storage. I have one rolling bridge on one lift and two on the other. With two you can completely unload the suspension on the entire car. I am also spoiled with space and ceiling height.
  9. rpissm
    rpissm Formula 3
    Aug 11, 2013
    1,620
    Salt Lake City, UT
    Joe
    Hey everyone,
    Thanks for your suggestions on lifts and I did search the forums but the items I came across were asking slightly different questions than I am. Do you have any concern about the TR slipping off the back of any lift (except the 4 post, I presume?) given the rear-end heavy weight distribution? I assume this concern would exist with all scissor and 2 post lifts?
    Joe
  10. vincenzo
    vincenzo F1 Rookie
    Nov 2, 2003
    3,373
    #10 vincenzo, Feb 1, 2014
    The scissor lift works great for an engine out.... no concerns.
    Caution - The TR does not roll over the lift when it is flat. You'll need to improvise.
    Rgds,
    Vincenzo
  11. vincep99
    vincep99 Formula 3
    Jun 8, 2009
    1,938
    I have the twin-post BendPak and had no problem when I did my engine-out; the car was balanced just fine.
    If your space problem is with height, BendPak told me they can make the lift shorter at no cost.
  12. okiedude
    okiedude Formula 3
    Jul 11, 2011
    1,013
    Remulak
    Blake
    Whenever I put any car on a two post lift, I lift the car about 3-4 inches off the ground. Then give it a good shake, front and rear. If it is going to fall off it's going to happen a few inches off the ground, not 6' up in the air.
    I know if you look at photos from some of the bigger Ferrari indy shops virtually all their lifts are two post.
  13. rpissm
    rpissm Formula 3
    Aug 11, 2013
    1,620
    Salt Lake City, UT
    Joe
    Thanks for the additional info. My concern with the Bend-pak isn't height - I think my garage ceilings are at least 10 feet (height designed for an RV) - it's space around the third drive bay (not designed for an RV!)
    Something else I like about the scissor lift is that it is "portable", or at least more portable than a Bend-Pak is. I might want to take over our 2 bay area of the garage (we have 3 bays total) if/when I decide to do a belt service (to my wife's chagrin :) )
    Joe
  14. okiedude
    okiedude Formula 3
    Jul 11, 2011
    1,013
    Remulak
    Blake
    Portability is nice. My shop area is completely dedicated (7,000 sq. ft.), has nothing to do with the family two car garage. In that respect I am fortunate, I am never in the way of Mrs. Gibb-LOL.
  15. GregTe
    GregTe Formula Junior
    May 3, 2004
    544
    Maine
    I installed a Bend Pak HD-9 4 post loft in my garage about a month ago, it is great!
  16. rpissm
    rpissm Formula 3
    Aug 11, 2013
    1,620
    Salt Lake City, UT
    Joe
    That 4 post is nice, but wouldn't it make engine out services impossible since the car is still riding on its wheels and that bar is in the back?
    And I WISH I had a separate workspace to stretch out in. Okiedude, it must be nice! :)
    Joe
  17. okiedude
    okiedude Formula 3
    Jul 11, 2011
    1,013
    Remulak
    Blake
    I'm spoiled, I admit it. I do share my space with a select group of car nuts for projects and or work days. It just wouldn't be right to not give back to the community.
    I was wondering the same thing about the engine out on a 4 post? Can anyone expand on that?
  18. turbo-joe
    turbo-joe F1 Veteran
    Apr 6, 2008
    9,428
    romano schwabel
    when I put out the engine at a TR or equal I never remove it down complete with the axle. I take the engine out to the top. sure, a little bit more work, but when you take out the engine with the axle to the bottom you have to adjust after putting in again the complete wheel alignment when you do the job right.
    also when you only take out the engine to the top you still can move the car
  19. twsii
    twsii Karting
    Jul 21, 2011
    65
    Birmingham,AL
    Tommy Stinson
    I have the titan mrl 6000 portable scissor lift and it works great. I can move it around the garage and the good thing about this lift is the car will ride over it without draging. My car at max lift is 60 Inches and that is plenty of room to work under the car the lift is also very stable when I first receive the lift I was skeptical but after Placing the car on the lift in several different positions a few hundred times I am very confident in the lift and recommend it to anyone who has space problems in the garage. BTW my ride is a 93 512tr.
  20. Spitfire
    Spitfire Formula 3
    Nov 16, 2006
    1,602
    I've been pondering lifts for years without actually pulling the trigger, and when I stumbled upon these guys a few weeks ago it got me wondering whether or not their so called "pit stop ramps" might be quite useful:
    Vehicle Lift Ramps | Rack Ramps | Pit Stop Ramps
  21. okiedude
    okiedude Formula 3
    Jul 11, 2011
    1,013
    Remulak
    Blake
    Do you remove the rear deck lid?
  22. vincenzo
    vincenzo F1 Rookie
    Nov 2, 2003
    3,373
    That is the exact same thing I did out of plywood and 2x4s. 3ea 2x4s laid on their side with 1/4" plywood base and 3/4" plywood top. The sections under the tires were lagged into the concrete to keep the structure in place as the car drives up.
    In the photo I previously posted, you can see the section under the front left wheel. The sections under the rear wheels were pulled for subframe 'engine out' access.
    Works well with a low rise lift that won't fit under the car without the ramps.
    Just as good if not better than the $2,200 of plastic.
    Rgds,
    Vincenzo
  23. Spitfire
    Spitfire Formula 3
    Nov 16, 2006
    1,602
    To be honest, I hadn't looked at the price, but I'll be the first to agree that $2,200 is a bit unrealistic.
  24. qwazipsycho
    qwazipsycho Formula 3
    Oct 30, 2004
    1,176
    Utah
    Scott
    #24 qwazipsycho, Feb 3, 2014
    Solid as a rock. Never a concern.
    As I've said before, this lift should be sold with the car. They go together like peanut butter and jelly.
  25. teveo
    Oct 1, 2005
    403
    Norway
    Trond Vidar
    Have one of those as well, it is very easy to adjust to the car, usually need some "lumber/mini ramp" to get low cars on the lift, this is a very stable lift.
    Got the bendpak model and the only recommendation is to check the big lock rings now and then, they are prone to come off.
