Suggested fix for door latch not engaging? | FerrariChat
Discussion in '456/550/575' started by RDM, Feb 14, 2012.
  1. RDM
    RDM Karting
    Nov 22, 2010
    70
    Atlanta GA
    Doug Moffat
    My driver door has taken to occasionally bouncing back open when closed. Latch does not engage, intermittently. Adjusted striker with some but not complete success. latch engages when window is down or if upward pressure on door is applied. Anyone encounter a similar problem? any solutions? I know a new door latch and labor is about a grand. Thanks, Doug
  2. 308 GTB
    308 GTB F1 World Champ
    11,729
    New Jersey
    Barry Wolinsky
    Sounds like your window needs adjustment, Doug.
    Barry
  3. dersark_painclinic
    dersark_painclinic Formula Junior
    Mar 8, 2005
    981
    Glendale, CA
    Lazik Der Sarkissian
    I had same problem with passenger door, took two minutes to adjust the latch, now it is ok.
    Sark
  4. sclja
    sclja Formula Junior
    392
    San Diego Ca
    Scott Cairncross
    Just fixed one a few days ago... #1 had to adjust the height of the striker in the door jamb it was too hi... #2 we had to lube up the lactch mechanism in the door (actually took it out and cleaned it out with some contact cleaner and then lubricated it and reinstalled it and now it is perfect) (fixed the door switch in the latch at the same time)
    Scott
  5. henryr
    henryr Two Time F1 World Champ
    22,422
    Atlanta
    Juan Sánchez Villa-L
    is the door sagging ?
  6. D-bling
    D-bling Karting
    Jun 25, 2010
    121
    I am currently having the same issue and wondered how I was going to fix this problem. Very timely thread and sounds like I know where to start now. Thanks everyone.
    D
  7. RDM
    RDM Karting
    Nov 22, 2010
    70
    Atlanta GA
    Doug Moffat
    With the adjustment to the striker, mine now appears to be fixed. Perhaps the window was somewhat out of line...now that it has been lower and raised several times, the latch has no difficulty engaging even with tHe window up.
    Henry, the door isn't visably sagging but the striker is scuffed in top.
    Scott, I'll try cleaning latch as well, thanks. Doug
