Suggestion for 360 oil type | FerrariChat
Discussion in 'Technical Q&A' started by paulie_b, Oct 21, 2018.
  1. paulie_b
    paulie_b F1 Veteran
    Jan 13, 2003
    6,842
    Jupiter, FL
    Paul Bianco
    I have only seen "old" posts regarding this subject. Any suggestions for an "updated" suggestion for brand of synthetic oil and viscosity?
  2. paulie_b
    paulie_b F1 Veteran
    Jan 13, 2003
    6,842
    Jupiter, FL
    Paul Bianco
    no suggestions or help here?
  3. Motob
    Motob Formula 3
    Nov 11, 2003
    2,365
    Frederick, Maryland
    Brian Brown
    #3 Motob, Oct 21, 2018
    Ferrari recommends Pennzoil Platinum Euro 5W-40. Is it the only oil that dealerships use and many independents as well. It is what I put in all of my customers cars.
    Considering that it is easy to get (Walmart, Amazon, Pep Boys, Advance, etc.), I think that it is a no brainer.
    f355spider likes this.
  4. ttforcefed
    ttforcefed F1 World Champ
    19,255
    yeh dont kill too many brain cells here. For my cars in the northeast i use 0w-40. in florida i do the same or i use 5w-40 if i can find it. i used to use redline and amsoil but for the past 10 years ive been asking for Mobil 1 fully synthetic if im at an independent shop
  5. Kevin Rev'n
    Kevin Rev'n Two Time F1 World Champ
    Nov 29, 2009
    24,491
    Honolulu
    Kevin
    My last service the dealer noted Q Horsepower Synthetic 5W40 on the invoice. Quaker State but I don't see any branding on the labels that says "Horsepower" on the weights I can find for sale on the internet. The last self oil change I did I used the Pennzoil Platinum Euro one referenced above and had it shipped to my door from Amazon. It had the Ferrari Approved markings on the box and I don't see that on the ones for sale via the usual channels. It's easy to be confused about this stuff when you want it to be simple. The constant changes in packaging and marketing make you wonder if they changed something else besides the name.
  6. tbakowsky
    tbakowsky F1 World Champ
    Sep 18, 2002
    19,948
    The Cold North
    Tom
    5w40 Liqui Moly is what I use. Full european blend and spec. Pricey, but it is one one the better rated engine oils on the market.
  7. tazandjan
    39,163
    Any good full synthetic 5W-40 works fine so it is not rocket science. I use Valvoline, but any of the others mentioned will work great, too.
  8. sandreb
    sandreb Karting
    Feb 7, 2018
    52
    Sander B.
    Mobil 1 0w-40 is another good oil and not hard to find.
  9. ttforcefed
    19,255
    I shld clarify my previous response. Both my independent ferrari shops use motul. When i take my non ferraris to the local shop i ask for mobil1
  10. f355spider
    f355spider F1 World Champ
    18,044
    Simplest to use the factory stuff, that is what I do. I am not a oil expert, but do notice that the Pennzoil is spec'd by Ferrari is also LL-01 approved by BMW. That has many tough requirements to meet, so I would want any 5w-40 or 0w-40 oil to have a similar approval rating, which includes a high temp high shear (HTHS) rating of 3.5 or higher (required to meet LL-01). Not all oils have this high an HTHS...worth checking the spec sheets. Castrol Edge makes a 0w-40 that is LL-01 approved and bonus you can find it in 5 quart jugs at WalMart for around $25.
  11. John_K_348
    John_K_348 F1 Rookie
    Sep 20, 2013
    2,753
    Boston, MA
    John E. Kenney
    Penzoil platinum eurospec is easily available on Amazon. I got my 2 cases delivered to my doorstep this summer. Also, our lead mechanic from the old country up here at FoNE has advised against 0w40 in the old F119 engine in the 348. I had a little weeping at the cam seals on my second year when I used 0w40. He said the oil pumps were very strong and you don't need to worry about a 0 weight even in winter. Now the Cinquevalvole and later engines are different, especially with the vvt tech so sticking to the 5w weight is a better idea than a 10w. Even still, you are probably OK with a 0w40, just keep an eye on your cam seals. But on the 430, with the timing chain, it's not as big a deal. I was pleased how easily I got the Penzoil. Last year I put Rotella 5w40 in my 360 because that's all I could find locally. No sweat this year and that goes for the 0w40 for my Quadrifoglio as well. 0w is required on the new engine with the vvt and cylinder kill lifters. Even still they have a little noisey lash at low rpm low pressure.
  12. Ingenere
    Ingenere F1 Veteran
    Dec 11, 2001
    6,449
    On the Limit
    Dino
    Penzoil 5-40, that Ferrari specs is easy to get. Works for me!
  13. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    9,721
    It is the HTHS spec you are looking for in a 5W-40 oil.
    You want HTHS above 3.5
    And you want zinc at the 1100 ppm level. ZDDP.
    You are not going to find either on the can, you have to do your research on the internet.
  14. GTS Bruce
    GTS Bruce Formula Junior
    Oct 10, 2012
    804
    Orchard Park NY
    Bruce Roche
    Rotella T6 5-40
