Suggestions for computer *desk* cooling fan. | FerrariChat
Discussion in 'Technology' started by Crawford, Jul 12, 2004.
  1. Crawford
    Crawford Formula 3
    Mar 5, 2003
    1,294
    Nashville, TN
    Crawford White
    Just got in a new desk which has a slot for the computer tower. There is very little ventilation, though, and the computer along with the cable modem really get hot, especially if I have the door shut.
    I want to install a fan in the back of the desk. I was thinking of cutting a hole in the top of the back panel and attaching a fan there. It needs to be very quiet and run on 120 V. Any suggestions or ideas???
  2. PeterS
    PeterS Five Time F1 World Champ
    52,622
    Goodyear, AZ
    PeterS
    Take the metal shell off your computer and store it out of the way. Buy two 90 or 92mm 120V DC fans that will give 80-100CFM. Cut a hole in the wood in back of the computer. Mount the fan to blow in the direction of the Mother Board. Drill a clean hole pattern (1/4") in the front door. Mount the second fan to the inside of the door, exhausting OUT. This should keep things lice and cool.
  3. LetsJet
    LetsJet F1 Veteran
    May 24, 2004
    9,334
    DC/LA/Paris/Haleiwa
    Mr.
    https://www.vbd.com/fans/shop/products_detail.asp?CategoryID=36&ProductID=41
    It doesn't run on AC but you can plug it right into your computer and it will start when you turn on your computer.
  4. C. Losito
    C. Losito Formula Junior
    Dec 12, 2003
    922
    Metro St. Louis
    Chris Losito
    Don't they make cooling fans that plug into spare PCI slots?
