Supercharge???? | Page 2 | FerrariChat
Supercharge????
Discussion in '308/328' started by $$$=SPEED, Jan 2, 2005.
  1. DaMonsta
    DaMonsta Rookie
    Dec 22, 2004
    13
    south of France
    Jim Ashley
    Hello:
    I was wondering what intercooler arrangements you designed in your setup?
    Regards,
    Jim
  2. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,816
    The twilight zone
    Jim, if you click on my profile, there is a pretty good pic of the engine. On the right side of the manifold there are 2 very larger hoses. They connect to a cupper/nickel alloy heat exchanger mounted inside the manifold between the blower outlet and the plenum area.
    At the other end there is an electric pump that flows about 15 gpm of coolant to the manifold and then back up front to a pair of 9"x20" aluminum radiator mounted in front of the front wheels with air flowing in from the extra wide front grill ( I have a GTO spoil, but I made a full width grill instead of mounting driving lights). The engine ECU kicks the pump on when the engine gets to 4500 rpm, 5 psi boost, or above 45C inlet air temp.
    It seems to work pretty well. On a 90 degree day the inlet air temp will get to about 65C which is hotter than I would have liked....but it is hitting 22 psi too, with the air coming out of the blower at 180C (355F), so I guess it's really doing a pretty good job.
  3. DaMonsta
    DaMonsta Rookie
    Dec 22, 2004
    13
    south of France
    Jim Ashley
    Mark:
    Many thanks for the info. It looks a neat installation. Did you have any thoughts about maybe rerouting the air filter to a cooler spot? Or is the intake air temp not all that affected by engine-bay heat.
    Regards,
    Jim
  4. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,816
    The twilight zone
    ...yeah, it's on the list. I'm sure it will help...although honestly if I pick up 10 or 20 hp it really doesn't much matter, it's got pretty now.
