Supercharged 308GTB almost ready to go | Page 4 | FerrariChat
Discussion in 'Technical Q&A' started by wildegroot, Apr 7, 2006.
  1. wildegroot
    wildegroot Formula 3
    Nov 19, 2003
    1,520
    Frenchtown NJ
    Wil de Groot
    Ed,
    Joe is a friend and was an enormous help putting on our first Frenchtown Exoticarshow.
    This year's show is on September 24 (Sunday). It's in Frenchtown, NJ along the Delaware river. We're about 1-1/2 hours from NYC, about 1 hour from Philadelphia and about 1 hour from the first Pocono mountains in PA. We had a pretty nice turn-out last year and hope to increase that this year. We had cars from as far away as Connecticut (2 hours from Greenwich).
    Please reserve the date. We'd love to see you at the show!
    Wil
  2. walawdog
    walawdog Formula Junior
    Nov 9, 2004
    829
    Bluefield, WV
    Anthony
    I just checked out your website, and I am wondering if you could quote me a price for creating the block off plate like the one you used for your electric water pump set up. Also, I was reviewing all the posts and didn't find the brand name of the electric pump you used. Do you mind telling us? Thanks, I am looking forward to making some of the same mods to my car that you have done.
  3. walawdog
    Nov 9, 2004
    829
    Bluefield, WV
    Anthony
    Ooops, I just saw that you gave me the name of the pump. So, could you just quote me a price on the block off plate. Thanks.
  4. Birdman
    Birdman F1 Veteran
    Jun 20, 2003
    6,689
    North shore, MA
    THE Birdman
    I love the look of it with no bumper at all in the front. Mean looking! But don't bump anything! eeegads!
    Birdman
  5. wildegroot
    Nov 19, 2003
    1,520
    Frenchtown NJ
    Wil de Groot
    Your best bet is to remove the water pump and make an accurate cardboard template for the block-off plate. I custom made mine the same way and didn't save any dimensions. There are 2 8MM bolt holes to the immediate left of the water outlet port where the OEM pump mounts and there is one more 8MM hole you can use off to the right a few inches away. If you connect the dots, so to speak, you wind up with a triangle that has a bulge in one side. Make a hole in your template to mate with the water outlet hole in the engine. I made my block-off plate out of 1/2" thick 6061 aluminum. Then you need to machine a fitting for a 1-1/2" coolant hose and weld it in place in the general direction of the AC compressor area (I changed the angle twice). Once the welding is done you need to machine the backside of the plate flat (weld distortion) and machine an O-ring groove around the water hole identical to the O-ring groove on the OEM water pump. If you supply an accurate template, any competent machinist in your area should be able to make the part for you.
    I'm using a Meziere remote 55 GPM electric pump, #WP336, but if you poke around you can find lots of options. Stewart has a remote pump #E558A and SPA-technique sells a remote water pump kit too. The Electromotive ECU in my car runs the Meziere pump but the other two I mentioned are available with dedicated control modules that monitor temperature and control the pump accordingly so no thermostat is needed.
    Good luck,
    Wil
  6. wildegroot
    Nov 19, 2003
    1,520
    Frenchtown NJ
    Wil de Groot
    Thanks for the compliment.
    As far as bumping goes: If I hit anything hard enough it's going to be a project anyway, bumper or no bumper. What ever happens, if I don't total the car it'll be fixable.
    Have you ever considered the expense of bumping anything with a 360 or a 550 or one of the newer cars? A couple of weeks ago I priced parts for a 550 that got hit in the right front. It was no "bump" - it hit pretty good - but just the parts came to over $21,000.00! Then there's still labor, paint and materials.....Not nice to think about.
    Please don't stick any pins in any black model 308s and hopefully I'll be OK.
    Wil
  7. walawdog
    Nov 9, 2004
    829
    Bluefield, WV
    Anthony
    I have my water cooled oil cooler on order, but, I think I am not going to do the electric water pump. I read an article on a hot rod site which made me weary of such a set up. First, I don't think my stock alternator could handle to the amps needed to drive the pump (unless I rebuild my alternator). Also, water flow with electric pumps max out at what.....55 gph? According to this article, that's about half of what a good mechanical can flow. What are your thoughts on this? I know you went with a bigger radiator....is that how you will compensate for the decrease in flow? Also, the HP gained from removing the mechanical pump was about 4 horses....not enough I don't think to make all the other things I would have to do worth it.
  8. wildegroot
    Nov 19, 2003
    1,520
    Frenchtown NJ
    Wil de Groot
    That's 55 gallons per MINUTE (if you believe the advertising). On the other hand the OEM pump is pretty whimpy and might be lucky to put out 55 gallons per hour. I've never tested either pump but I'm comfortable with my choice.
    I got rid of the OEM alternator and installed a high out-put Ford single wire alternator. The electric water pump is not the only load. There is also an intercooler pump and an EFI fuel pump which draws more than the carb pump.
    My main reasons for replacing the water pump are: greater heat (from more power) requires more flow and also, the supercharger installation did not leave room for a belt driven water pump.
    The radiator is not only larger capacity but it's aluminum (lighter) and NEW. I didn't want some dirty, old, calcified radiator struggling with the additional heat.
    Wil
  9. walawdog
    Nov 9, 2004
    829
    Bluefield, WV
    Anthony
    How's the project coming, any new updates for us?
  10. whart
    whart F1 Veteran
    Honorary
    Dec 5, 2001
    6,485
    Grandview NY
    Herr Prof.
    I want one. Hey Wil. Assume you are in the P-cnos.
  11. wildegroot
    Nov 19, 2003
    1,520
    Frenchtown NJ
    Wil de Groot
    We had the car pretty much together and had the engine running but the supercharger seemed hotter and noisier than it should have been so I removed the supercharger and intercooler for inspection which is more complicated than it sounds. It looks like the SC may have sucked up a piece of debris from somewhere a made a few scratches in the housing inner wall near the intake side but otherwise everything looks fine and there doesn't appear to be any interferance anywhere. I e-mailed and phoned an engineer at Lysholm and described everything in detail and he doesn't seem too concerned so I'm reassembling everything. I had hoped to make today's Pocono event but the tear-down and inspection and time lost waiting for answers pretty much erased my chances of making it. I actually haven't done much to it at all in the last week, needing a break.
    I did go to the show but I took my F250 pick-up truck not my F-car.
    When I get a chance I'll take some more photos. Any one familiar with the 308 front trunk won't recognize it. I removed the entire spare tire housing to allow installation of the new, thicker than stock, aluminum radiator. This was a good thing because it made access to the entire area under the spare tire very simple and it now contains the electric water pump, the electric intercooler pump, a big pull-through shrouded electric fan, the fan control box and the horn compressor and the heater fans (relocated to make room for intercooler heat exchangers). The tandem Tilton brake master cylinder set-up sits above all that so it's pretty busy in the front "trunk".
    Up front next to the radiator I have the intercooler heat exchangers each with it's own electric fan. Fitting the heat exchangers was complicated by the retractible headlights. The fiberglass headlight fairings have sort of a duck bill protruding from the lower front of each headlight to fill the opening created when the headlight door is raised. Unfortunately this was getting in the way of the heat exchanger under each headlight when the headlight was down so I removed the fairings and had to make aluminum brackets to hold the headlight doors in place. I still have retractable headlights that look normal when down. When up they look bad anyway and I needed intercoolers and I don't plan on doing much night driving - too many deer around here.
    The stock clock didn't work anyway so it was replaced by an Auto Meter boost gauge. The stock temp gauge was alo replaced by an Auto Meter unit which monitors both cooling circuits.
    Thanks for your interest
    Wil
  12. wildegroot
    Nov 19, 2003
    1,520
    Frenchtown NJ
    Wil de Groot
    Bill,
    Funny, Last night I told myself I should contact you to see how you're making out with the inspection. Hopefully OK.
    Yeah, I went to the Pocono show this afternoon. Sadly the turnout was not as good as it might have been with better weather but the funny thing is that, with all the storming going on all around the area, the show apparently stayed dry! I think close to half the cars at the show were those supplied by dealers and there were about 5 dealers. It rained so hard on I-380 on the way up I could hardly see and a guy ahead of me spun into the guard rail! Nice driving pal!
    I met 8 or 10 people I'm friendly with but missed seeing many more. Too bad.
    Wil
  13. RobD
    RobD Formula 3
    Nov 10, 2003
    1,182
    wildegroot, do you know what's happening with the Pocono Raceway driving event? I assume today was rained out, but if it's dry tomorrow, will the cars be on the track? TIA
  14. wildegroot
    Nov 19, 2003
    1,520
    Frenchtown NJ
    Wil de Groot
    I'm not really the "go to guy" for the Pocono events but I've been going since it all started in the 80s and when it rains everyone just stands around bench racing hoping for a break in the weather. As far as I know the organizers pay a lot of money up front and basically own the track for Sunday and Monday whether it rains or shines. If you can find the zip code for Long Pond or Blakeslee, PA you should be able to get the weather of the net.
    Wil
  15. F&M racing
    F&M racing Formula Junior
    Feb 26, 2006
    668
    Michigan
    JimF
    Wil,
    What is the Magna Flow Muffler part number you started making your exhaust with? I was thinking on doing the same to my 308.
  16. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    Hey Wil -
    What's your opinion on the effectiveness of porting Ferrari 3.0/3.2 4 valve heads? Any specific experience?
    On the same line, any value in decking the heads while they are off a bit to raise compression?
    many thanks
  17. bill308
    bill308 Formula 3
    1,224
    Windsor, CT
    Bill Sebestyen
    Russ,
    Decking the heads, as you know, will increase the compression ratio, all else assumed unchanged. This will improve the volumetric efficiency of the engine, increasing power, torque, and milage. The penalty, and there is always at least one, is that the octane appitite of the engine will increase. Pick your poison.
    Bill
  18. wildegroot
    Nov 19, 2003
    1,520
    Frenchtown NJ
    Wil de Groot
    Sorry, I threw the boxes out a long time ago. I'm pretty sure you can find the mufflers on the Magnaflow website by dimensions. I won't be able to get to the car for a few days but If I remember I'll take some measurements. They're oval. I'm pretty sure they have 2-1/4" inlet and outlet fittings and they're made of 304 stainless. If you haven't heard from me in a few days and you still need the information you're welcome to rattle my cage.
    Wil
  19. wildegroot
    Nov 19, 2003
    1,520
    Frenchtown NJ
    Wil de Groot
    Russ,
    I've been working on 308s for years but never did any port work other than cleaning them up a bit. You need to talk to a porting specialist who has done a 308 and has flow bench and dyno specs to back up his results. Be careful. It's very easy to make the ports flow worse than stock.
    Bill is right about raising the compression ratio but 8/1 IS low. I would prefer to raise the compression ratio with different pistons though. If it's an early car it gives you the oportunity to uprade from cast to forged pistons.
    Wil
  20. F&M racing
    Feb 26, 2006
    668
    Michigan
    JimF
    Wil, did you get a chance to measure the muffler yet?
  21. wildegroot
    Nov 19, 2003
    1,520
    Frenchtown NJ
    Wil de Groot
    I knew I'd forget! Sorry.
    They're made by Magnaflow. Length is 14-1/8", width is 8-5/8" (at the end plates), thickness is 5-1/4" (at the end plates), inlet and outlet fittings are 2-1/4" or 2-3/8" (outside measurement is almost 2-1/2" but I cut and welded there so I can't get a direct ID measurement). Sorry I don't have the part number anymore but you should be able to trace it back by dimensions in the Magnaflow web-site. That is how I chose my mufflers. Good Luck.
    Wil
  22. F&M racing
    Feb 26, 2006
    668
    Michigan
    JimF
    Thanks Wil
    Hows the final sound ? I'll replace mine during the winter months.
    Thanks Again!
  23. wildegroot
    Nov 19, 2003
    1,520
    Frenchtown NJ
    Wil de Groot
    I've only heard it at idle. Unfortunately 308 engines sound like VW beatles at idle no matter what exhaust system you use. Stock, Larini, Tubi, etc - they all sound like **** at idle. I had to take things appart for inspection and to make some revisions. Hopefully next week I'll be able to start it again and rev it up a little.
    Wil
  24. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    I think after experimenting with several different configurations I have had a bit more luck on the muffler at idle. There are two ways to go based on my experience. In my single inlet muffler system (85 and above f&r headers dump into a single 3" collector) the the 3" collector in splits in a y pipe in the Dynomax (I got the largest free flow F-body muffler that would fit) to two 2.5 inch exits on each side. Then you have a choice:
    1. I ran two 3" non resonated tailpipes which give it a very deep but hard sound
    2. dual twin 2.75" Ansa resonated tailpipes (same as a Daytona) that really keep the deep sound, but smooth out the sound.
    I kept the Ansas, as it is low toned and quiet at cruise and idle, but opens up nicely at WOT. Not like a vw at all so far. Of course, the Webers may help that...
    Another option I am looking at is that Hooker Headers makes a very nice chromed 3" resonated twin tailpipe that might but a little lower tone but still smooth with a tad more flow.
    Pictures in the tech section if search on dynomax or magnaflow and Mondial
    best
    rt
  25. oss117
    oss117 F1 Rookie
    Jan 26, 2006
    4,185
    Plantation, Florida
    Alfredo
    However the "Porsche" calipers ruin the whole package, in my opinon.
    You should consider either replacing them or at least remove or hide the Porsche name.
    Also, what about the compression ratio: is it the same as before or did you lower it?
    oss117
