Supercharged QV (take 3)-or is it a turbo? | Page 11 | FerrariChat
Discussion in 'Technical Q&A' started by mk e, Jan 12, 2006.
  1. wildegroot
    wildegroot Formula 3
    Nov 19, 2003
    1,522
    Frenchtown NJ
    Wil de Groot
    Mark,
    Interesting developments.
    Are you NOT using the extruded aluminum dividers and parallel end-fences that Laminova makes for their intercooler cores?
    Wil
  2. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,857
    The twilight zone
    #252 mk e, Jan 18, 2007
    Wil, I am not using the laminova parts, I didn't know they made anything honestly. My plan was to build something into the intake.
    Are your core round with all the fins formed and to equal hieghts? Mine don't look too good to me.
  3. wildegroot
    Nov 19, 2003
    1,522
    Frenchtown NJ
    Wil de Groot
    Mark,
    You should call Opcon and get them to send you prints of the core separators. They are beautifull extrusioned aluminum pieces meant to guide air through and around the cores. They really look like a bit of research went into them to assure correct airflow. I don't think the fins are supposed to touch the separators so a little un-eveness shouldn't hurt. You should really talk to the engineers in Sweden. I also have drawings supplied by the old Opcon distributor in Connecticut for the end water manifold dimensions. If you can't get anything from Opcon, let me know and I'll scan my drawings.
    Wil
  4. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,511
    Dumpster Fire #31
    SMG
    here's the link to Opcon if you didn't have it.
    http://www.opcon.se/index.asp?sPage=1&langID=2&cID=14
    they also have PDF's of the intercooler core with tech dwgs.
    Mark, Opcon can also 'build' a unit to your specs' not sure on cost, but they seem willing. reading thru whipples site, they kind of layout the issues with Opcon/autorotor and the merger with lysholm after the split from SRM. it's a bit confusing but i think that's another reason whipple went on it alone.
    and you're right the 'twin screw' work better at PR's above 2. personally i think you've lost it ;) what are you shooting for..3???
  5. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,857
    The twilight zone
    Yeah, I've got he drawings, which is why I'm surprised by the cores...they don't appear close to spec.
    Opcon is pushing for OEM bussiness, I think that is their target custom market. They are also in litigation with whipple (I don't know about kenne bell) over patent issues. Opcon holds the patents on the screw type compressor, Lysholm was lisencing from them proir to the merger....whipple and kenne bell appear the think they found a way around the patent.
    I will be running 15-20 psi, just like before, so a PR of 2.2-2.33. When I went shopping the last time, the autorotor had a CR of 1.2 and was 2.2L and the lysholm 1.35CR and 2.3L wuth a higher redline, so I went lysholm. Now whipple and kenne bell have bumped redlines and bumped displacements....but neither seem will to share a compressor map or CR info. The Kenne bell makes good numbers on a Mustang and the H version (higher CR) makes better number in my boost range....I think I'll call and ask if they have manifolt temps at 15 and 20 psi for there car they tested, they might.
    Anyway, it looks like the kenne bell meets all the requirements....I just hate not having the compressor map.
  6. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,857
    The twilight zone
    I'll ask about them today...they have nothing that looks useful on their web site. The fins aren't supposed to touch, but the closer, the better. Because the design forces the air around a curve, the air will do it's best to be on the outside wall, where the cooler is least efficient (farest from the water) and if the fit is bad, not even touching the fins.
    Again, are yours like this? I'm trying to figureout if it's normal or not. If not I'll exchange them, Debra said she had them laying around the warehouse....there might be a reason the case was open.
  7. wildegroot
    Nov 19, 2003
    1,522
    Frenchtown NJ
    Wil de Groot
    #257 wildegroot, Jan 19, 2007
    Mark,
    Here are pictures of my intercooler set-up. The cores and dividers are Laminova parts. The end water manifold held in my hand I made using their specs for bore dimensions.
    I also included a shot of the inside of the plenum below the intercooler. You can see I have very short intake manifold runners like we talked about earlier.
    I understand what you're saying about the fins. They do fit very close to the dividers. My fins are not totally even but pretty close. It IS a stacked assembly so it will never be totally even. I think if you tried to machine the fins even, they would smear together. The fins are so close together you can barely see light between them. I suppose you COULD have reject parts there.
    It was a lot easier to deal with the distributor in Connecticut. They at least knew something about the products. I still think you should talk to an engineer in Sweden.
  8. wildegroot
    Nov 19, 2003
    1,522
    Frenchtown NJ
    Wil de Groot
    Mark,
    One thing I left out: The end extrusions on my intercooler were machined down due to space concerns. The actual pieces extend down further and have rounded ends.
    Wil
  9. Verell
    Verell F1 Veteran
    May 5, 2001
    7,027
    Groton, MA
    Verell Boaen
    I scraped & scraped, then caught Cindy at just the right moment & got her OK(whew).
    She just can't understand why the 308 needs more power than the it currently has. After all, her V6 Camry "can't (quite) keep up with it leaving a red light"... ;^)
    & the check will be in the mail Tuesday AM so you'll have $$ to work with...
    BTW, I was very surprised at the relatively small cross-section the laminovas & dividers present to the airflow. I guess the important question is how that cross-section compares to the SC's outlet port?
  10. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,511
    Dumpster Fire #31
    SMG
    I hear you on the maps, shame really as Opcon has all thier maps online. your going for sweet spot at 2.2~2.5 highest effeciancy, i'd be tempted to see how 3.0+ does, only becouse they say it should get better. ofcourse you'd need to buiild a brick house of an engine;)
    I haven't heard anything negitive about the whipple units or the KB's so it's a good choice eithier way. the lawsuit will probably take forever to sort and in the meantime if Opcon is as finacialy short as whipple makes them sound then it's only time before they close up or strike another merger, the only upside to us is cost wars, whipple has the US market, not sure who has the OEM contracts though. ehh doesn't matter i supose.
    Verell, it's not the cross section but the surface area that's critcal. and that is the 'coolest' <----pun;) intercooler i've seen. the surface area is HUGE!, my only question is, what is the pressure drop? how much 'more' pressure needs to be run to keep the desired Pr?
  11. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,857
    The twilight zone
    The lysholm ax 2300 has a peak efficiency at a PR of 1.7/1.8 and 8000 rpm….right about where I’ll be setting it up for Verell (he's got more sense than me), it should work out really well.
    I don’t know the number for the Kenne Bell, but in talking to them, they seem to not like to run it to redline, they say the charge it cooler at lower rpm, and the H version adds about 2% more rwhp at 15 psi and 5% at 20psi than the standard version. The unit is rated to 25 psi
    At first glance it looks like a ton of area, but when I did the math, I was surprised to learn that it takes a 14"x6" laminova to give the same flow area at the 7x7 convensional cooler I had before. The cores have a huge dead space in the middle of them. The 7x7 I had, has no effect on the flow bech number even with 1/2 the area tape of, so it must be big enoughand I'm planing to exceed that area with the laminova...I'm hoping it will all be good.
  12. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,511
    Dumpster Fire #31
    SMG
    Okay, makes sense. the only drag is ofcourse the heat at idle and cruise. see below...
    the numbers i got were 0.6sq/in per fin(one side) on a 34mm intercooler. based on a 14" long run if i read that right would give a surface area of 85.28sq/in based on both sides of the fin. if you used 4 of them then that's
    341.12sq/in of surface area. did you get about the same? haven't looked to see what std. flat cores have in terms of surface area.
    it seems though that along with the surface area the thermal transfer is what they are really good at, material and forced air flow. i wondered about the 'dead' space as well but it wouldn't work so well to pump water through it as the flow of hot/cold water tends to sperate and you'd loose your transfer and then you have the issue not enough surface area again for the water. it's a good design i think. it address alot of the engineering needed to make it work. i just wonder about the pressure head infront of the intercooler.
  13. Verell
    Verell F1 Veteran
    May 5, 2001
    7,027
    Groton, MA
    Verell Boaen
    Umm,
    Poor terminology.
    Yes, the fin area exposed to the airflow is huge.
    I was referring to the inlet area presented to the incoming air ie: the sides of the V formed by the end of the fins. It's going to be a significant component of the equation for the pressure drop thru the intercooler.
    This is the area that the air has to flow thru as it enters the fins. I believe this is what mk e is calling the 'flow area' when comparing the laminova to a conventional radiator type intercooler.
    I was trying to say that it is quite small relative to the total dimensions of the inlet side of the system, as most of the inlet side surface area is consumed by the spacers and the laminova cores.
    Whereas on a conventional radiator core style intercooler, the flow area is the cross-section inside the core, at the widest point of the heat removal tubes.
    Anyway, mark has already noted my concern in his flow area comparison in post #261.
  14. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,511
    Dumpster Fire #31
    SMG
    right, i think we're all talking about the same thing but using differeing verabge. but yes, i'am wondering about the pressure difference between sides in the plenum.
  15. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,857
    The twilight zone
    Here's the update.
    I almost ordered a blower today....but the numbers are still troubling me so I held off.
    The problem is this. The 300rwhp system I had used 450rwhp worth of fuel and air by the math. The 420rwhp system used about 700rwhp or fuel and air. My first though then was to get 600rwhp I need a blower rated at 900rwhp, and that is what I was planning to buy....but that just seems wrong.
    I got looking at everything again and looking at the flow numbers for the ported heads and I think I finally found the answer. The stock cams are 220 degrees of duration and in the stock heads make peak hp at 6800 rpm. When I plug the stock cams and the ported head flow into the computer it says the hp peak will now be at 8000 rpm.
    That tells me the stock combination is really inefficient. The head flow is way low from where in needs to be and ferrari over-cam’d the snot out of the engine to make up for it. It all works out fine on an NA engine and makes decent power, but all that duration, the small intake and oversize exhaust all seem to combine to make the engine waste an incredible amount of air and way I’ve needed way over-size blowers.
    My new though is that the heads now flow enough air to fill the cylinders nicely to about 7200 or 7400….so I should probably install cams that peak at 7200-7400 instead of 8000 and everything will be better. Vic, my head guy, is chewing on it a little bit for the next few days, but I think we’re both on the same page, which is I need to pull 10 or 15 degrees of duration out of the cams and set the lobe separation at 112 or 114 degrees.
    Once I do that it will make peak hp at 7200-7400, with almost no valve overlap making it impossible for the blower to pump air out the exhaust. There will be more boost sooner, so more power all the way up to about 7500, then over that, it will lose just a tad to the longer duration cams. It also should mean that I don’t need the expensive monster blower, and that’s good…and it looks like that means the peak hp may be as good or better because the intercooler will cool the air better because there is only 2/3 at much of it and it only takes 2/3 the hp to pump it. The only down side I see is that there will still be a bit of boost rise from 6000-7700, but it should be much less pronounced than it was before..maybe 3-4 psi instead of 8 psi.
    That’s where my head is today….but of course it's still subject to change :)
