Supercharged QV (take 3)-or is it a turbo? | Page 2 | FerrariChat
Discussion in 'Technical Q&A' started by mk e, Jan 12, 2006.
  1. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,869
    The twilight zone
    If anybody knows anything about specing the turbo, I'd love the input.
    As I said in the other post I'm thinking Garrett GT42 right now...but it is a touch big I think.
  2. pad
    pad Formula 3
    Sep 30, 2004
    1,426
    Tequesta, FL
    Paul Delatush
    Mark,
    At what point do you see needing beefing up other components such as axles,
    etc.? I know you have already upgraded the clutch and brakes. For those of us who are interested in SC our cars and using them on the track, we are concerned with 1. HP to the wheels, 2. traction, especially when running slicks, and 3. not going beyond the "breaking point" -pun intended. (Perhaps this belongs in a seperate thread.) Your thoughts?
  3. enjoythemusic
    enjoythemusic F1 World Champ
    Apr 20, 2002
    10,676
    Worldwide
    Steven
    As i recall, other than beefing up the clutch it should be ok for added HP/TQ to about 500+ with stock setup. The only problem i have heard about is that high G forces on the rear stub axle can be problematic. i KNOW at one point someone offered a beefed up stub, but can not seem to locate the data/person who offers them.
  4. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,869
    The twilight zone
    I think the application really drives what mods are required and what the limits are. Road use is pretty easy on a car, roadrace use is not. On the street, you can add hp and nothing else if you choose because speed is limited. For road racing, changing hp, tires or suspension requires the brakes to be upgraded to handle the extra speed.
    A couple years ago I spoke to Jim (I think) at Norwood who told me they had a couple 800hp 308s running at the track without problems and that the 308 trans parts look a lot like TR trans parts which are good to about 1100-1200 hp, but seem to have a ***igue life issue (at least in one f-chetters car) at 500 hp....but I don't know the extend of the mod. I've heard the stud axles hate slicks, but that is a Gs issue more than hp.
    I'm probably not the best source of info for how to hook-up the car at the track, but hp isn't going to change the set-up an awful lot...tire widths and probably a bit more spring for the higher speed...but others could answer that better.
  5. Gary48
    Gary48 Guest
    Dec 30, 2003
    940
    There exists many new drugs for your affliction!
  6. F40
    F40 F1 Rookie
    Apr 16, 2003
    3,230
    AZ
    Maybe Paul at Forced Air Tech can help you... He has designed a twin turbo and supercharger kit for the Subaru Impreza STi, as well as a single turbo and blower combination. Supercharger wise he uses the Mercedes Benz C32 AMG unit, because it has the clutch on it from the factory.
    http://www.forcedairtech.com/
  7. Javelin276
    Javelin276 Formula Junior
    Jan 16, 2005
    512
    Idaho
    Thor Zollinger
    If you do, put me on your first-run list. I have a Mondial-8 that could use a lot more horse power. My email is [email protected] if you do.
    If not, please make any engineering drawings available so the rest of us can benefit. I'd pay for your drawings as well.
    Thor
    www.JavelinArt.com
  8. ROLOcr
    ROLOcr Formula Junior
    Oct 25, 2005
    619
    Costa Rica
    ROLO
    i don't really know, just guessing
    do you need to change the cooling system(or make it more efficient since your are modifing the engine i think it would run hotter??
    just asking
  9. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,869
    The twilight zone
    Thanks, I'll give them a call. I'm not sure what he's doing exactly, but based on the shape of the torque curve he's got a LOT more boost up top than on the bottom so I suspect it's a blow-through on the blower. My goal is a torque curve as close to flat as I can get it.
  10. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,869
    The twilight zone
    Good point. The stock cooling system works I guess if it's in perfect condition. I've installed a much larger aluminum radiator in my car because I was tired or worrying about sitting in traffic - driving it was fine.
  11. ROLOcr
    Oct 25, 2005
    619
    Costa Rica
    ROLO
    well at least change the thermostat to a much cooler one, ust to be on the safe side, as i recall force fed cars run much much hotter than normal aspirated ones!!
    also you have to delay(or retard i don't know the correct trasnlation for it) timing on it so it doesn't knock .
    then we have the normal issues like fuel delivery, also needs BIGGER OIL COOLERS
    if not, engine will run as hot as hell
  12. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,869
    The twilight zone
    #37 mk e, Jan 14, 2006
    The engine is currently supercharged and hits 22 psi at redline and doesn't seem to have any problems. It is fitted with a water/oil heat exchanger and a programable ECU that I set to pull the timing back to about 20 degrees at full boost.
    What I'm looking to do now is take my boost curve (yellow line) and make it flat from idle to redline at about 20-25 psi....ok maybe a little more :)
    I'm going to do some head and intake manifold work to try and get the torque to carry out a bit flatter after 5500. Even if I can't fix it, the turbos wastegate will keep the boost flat up top where the SC boost climbs due to the engines dropping VE.
  13. ROLOcr
    Oct 25, 2005
    619
    Costa Rica
    ROLO
    well, i can see that you're half way there , good luck with making the curve flat, is quite an interesting challenge!
  14. ROLOcr
    Oct 25, 2005
    619
    Costa Rica
    ROLO
    i just noticed that isn't the air fuel ratio a bit lean?
  15. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,869
    The twilight zone
    Yes. I corrected that as well as the way lean throttle on at the start of the graph.
    I just realized that the place to find turbo on a 3 liter info is supra sites...tons of dyno graphs with different turbos....I've got some reading to do.
  16. ROLOcr
    Oct 25, 2005
    619
    Costa Rica
    ROLO
    supra sites are a great resource, but i think you should talk to people who make costum turbo setups for a better fit
  17. EspritSE
    EspritSE Formula Junior
    Dec 1, 2003
    509
    Colorado
    Craig
    As well as lots of math. Dealing with volumetric flow on a turbo is one thing...Mass flow from compound compression is another story.
    On another note...
    Turbos don't lack low-end...Oversized turbos lack low-end.
    Lastly,
    Where is the Intercooler(s)?
  18. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,869
    The twilight zone
    ...and that is why god gave us excel :)
    I don't think it will be that bad really. At low rpm, only the blower will actually be doing anything and above about 4500 only the turbo will be working. I;m a little concerned about the control scheme for the say 3000-4500 range, but I've got a couple ideas that I think will work depending on whether or not I use the CVT....the CVT will make a better system I think, but it will be a bit harder to get the controls right.
    2 things here. I think the scope of the problem really depends on the system boost. You can get reasonably good low end from a 5 psi system, but a 25 psi system is another story...or it could be your idea of low-end and mine are a bit different. I've never seen a high boost turbo system deliver low-end performance that I find acceptable, which is why I've been sticking to superchargers.
    On my engine or proposed system diagram?
    It's not on the diagram because it didn't fit on the page and I was too lazy to shift everything to add it. On my current system there is a water/air unit built into the intake. I'm not sure yet what I'm going to do on the new system...I'd like to go with a simpler, more effective air/air but I'm not sure I can get enough space or cool air for it to work properly. I may need to stay with water/air, but it won't be inside the intake on the new system either way.
  19. ROLOcr
    Oct 25, 2005
    619
    Costa Rica
    ROLO
    intercoolers...yes, WHAT ABOUT THE PIPES !!! they take up a LOT!!of space!!!! SPECIALLY a twin turbo set up!!
    this things tend to get SO COMPLICATED and space is a mayor factor!
    but it is so much fun and so interesting to take the car to its limits
  20. GrigioGuy
    GrigioGuy Splenda Daddy
    Nov 26, 2001
    33,594
    E ' ' '/ F
    Enzo Gorlomi
    Speaking of intercoolers, Mark you may like this.
    There's a MR2 running around locally that has the intercooler mounted in the rear trunk behind the motor, and they have CO2-powered cooling nozzles pointed at the thing for additional charge cooling during dyno runs and heavy use. Maybe something to consider for that 1000 HP motor :D
  21. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,869
    The twilight zone
    I'm just not sure what to do for intercoolers. The Aussie TT355 put them behind the rear wheels and I really liked that...but I'm not sure I have enough space on the 308 without taking the sides of the trunk...and I like the trunk, my canopy that is SOOOO nice at the autocross just fits side to side as it is.
    .....although I guess I could put it on the wheel trailer I keep threatening to put behind it :)
    I need to do a bit of measuring in the engine bay. I've pretty much settled on the basics now, so I can start figuring out where they go and that will give me a clue about the intercoolers. water/air untis big enough to do so good will fit behind the wheels...I might be able to do something using the side intakes. I thing the blower and the turbo will fit behind the engine...I need to measure and think on it a bit......
  22. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,869
    The twilight zone
    #47 mk e, Jan 15, 2006
    I went and did a bit of mearuring today.
    There is really only one placd to put the supercharger that makes any sense, and that is behind/over the engine on the right side....unless I want to hydraulic drive it, and I don't think I do.
    That leaves 2 places for the turbo. The one I'm pretty sure I need is pretty big, but will fit behind/over the engine on the left (show by a 10" duct I had) or under the car where the (empty) cat sits now. I like under the car, but I think that will mean I need a return pump for the oil....more parts.
    The intercooler(s) depends on water/air or air/air and where I put the turbo. If the turbo goes under the car, I can fit a pretty good size water/air cooler behind the engine on the left. If the turbo is there, I can fit about a 12x12 unit behind the reqar wheel without going into the truck...that would give me 2 cores of about 12x7, which I think should be plenty. If I go into the truck, I can get a pair of 12x16 units, so 2 cores size 12x11 or so, I think that would be ok for air/air...I want hp, but I don't want to lose the trunk space. I need to think about it, air/air is lighter and simpler, but I do alread have the pump and radiators up front for a water/air and it space the trunk.
  23. wildegroot
    wildegroot Formula 3
    Nov 19, 2003
    1,522
    Frenchtown NJ
    Wil de Groot
    Mark,
    I've been reading this thread with great interest. We PM'd about a year ago when you wanted to come see my supercharged 78 308GTB in Jersey. I'm much further along now and plan to be on the road with it in the spring.
    I have an Opcon supercharger mounted ontop of a billet intake manifold with integral Opcon air/water intercooler cores. I'ts been a whole lot more machine work than I had anticipated and if I did it again I think I would do it much simpler. A little less efficient in operation maybe but simpler.
    Anyway, why do you state that the next intercooler will not be inside the intake? Is it also because of the complexity?
    I also have an aluminum radiator (Griffon Ford NASCAR) and an oil to water cooler (Setrab's biggest). I've modified a pair of Ford AC evaporators into intercooler heat exchangers to be mounted up front, one on each side of the radiator. I plan to install two electric water pumps in the spare tire well. One for cooling the engine block and a smaller one for the intercooler. I have the intercooler surge tank in the trunk.
    Wil
    PS:Your new project sounds you're looking to go orbital with it.
  24. F40
    F40 F1 Rookie
    Apr 16, 2003
    3,230
    AZ
    I meant Robert, I can never remember the buys name.
  25. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,869
    The twilight zone
    Wil,
    I think every project I've ever done was WAY more work than I realized up front if it makes you feel any better.
    I'd still like to get out to see what you're building sometime, it sounds really cool.
    There are 2 reasons I'm not planning to put the intercooler int he manifold this time. The main reason is that because I'm planning to run stupid amounts of boost and I want a really big cooler and it just wouldn't be possible to put it in the manifold. The second reason is thatI've got it in my head that part of the reason the QVs lose torque above 5500 is the design og the manifold. Ferrari changed the manifold design (and the dropping torque) on the 348 and has kept the 348 design on every engine after. I want to try that type manifold this time and it will take up all the space I have over the engine, so I'll have to put the intercooler somewhere else.
