Well it's just full of typos...but that's pretty normal for me....or did you mean the graph of the 1100 hp 308 engine
They claim a better fuel efficiency .. .. in Europe fuel prices are currently around 8 $/ gallon. BTW: BMW is currently exploring an engine where the exhaust temperature is used to feed a small steam turbine ..
It would get better milage....but it would have to be a lot better to pay the extra cost. The hybrid cars claim great milage (which it turns out they don't deliver - the US gov is changin the test to fix that), but even with $10/gallon fuel the car would be in the junk yard before you ever got the money back. I've honestly never understood why the people who live in Europe allow the government to put SOOO much tax on fuel, but I guess that thought belongs in the politics section
If I was any good at altering pictures I could show better what I was thinking. I must first offer my caveat, I prefer Ferrari's to "appear" stock, but in the quest for madness, I offer the following..... Starting where I left off earlier, with the fuel tanks and oil cooler out of the way, a large air to air intercooler could be placed in each side of the car where the present fuel tanks reside now. One intercooler feeds each bank. Each bank has its own seperate intake manifold. Each bank has its own seperate turbo charger. This would probably be difficult to incorporate a blower into, but do you really need one? You could use VNT turbo chargers that provide boost at lower speed, and hold across a taller band. You could put air doors in the intake side like Ferrari did on the F40, and I also believe the 288, to keep the turbines spooled during off throttle downshifts, so that they are at full speed when you lay back into the throttle. So much design and technology has been done in the aftermarket arena with turbocharging, that I believe throttle lag is largely a small issue these days in a properly designed system. Its not like the 930 Turbo era anymore, or at least doesnt have to be. I believe with a VNT, you could size it for maximum boost at redline, and the variable nozzle would provide good boost at lower speeds as well. That way too, it wont just all come on at once, but smoother and more progressively. No one would like 8-900HP to light off suddenly.
There is definitely merit to your plan. Im already planning on 2 separate intake manifolds and I ordered the material to build them yesterday. Twin turbos is a good set-up particularly on a v-type engine a little less efficient than one larger turbo, but that might be offset by getting more of the heat to the turbo with shorter pipes. I need to think about moving the fuel tanks a bit .The space would be really nice, but where they are puts the fuel load on about the front/rear mass center so the car handles about the same at any fuel load. Putting it up front would make the front act different at different fuel loads. I dont know if it would be significant though .I need to think on that one. The first step has got to be to fix the heads though. If the number Kermit sent me are right, the intake flow is only 2/3 what it should be and there is no viable valve lift that maxes out the exhaust. I think Im just going to go ahead and pull the engine and get the heads off .they need help. Since the heads will (hopefully) be changing A LOT, it doesnt make sense for me to even try to spec the parts for the boost part I just dont know what engine Im trying to match. Ive got to fix the heads first, run the engine to get a baseline curve, then add the boost. Thats good though, because then there will be a nice data point for a QV with good heads for anyone thinking about working on their heads.
Playing with the sym again.... it thinks if I port the heads right and just put my old blower right back on, the boost will be down and I'll gain a couple hundred hp....I need to get the heads off for porting. Image Unavailable, Please Login
Just to quantify this head porting thing, as I am really looking at this. We are talking about keeping the same valves, but removing material in the intake and exhaust ports to allow a larger flow track. These ports are then polished to reduce wall friction with the air. The proceedure also matches the intake opening on the head with the manifold wall. I have heard the figure of $2000 said for the machine shop work, which includes new guides and valve seats, and setting clearances. Would need to add to this costs of removing both heads Is it possible, or advisable to raise compression by shaving the head a little? I am at 9.2 which is ok, but would up to 9.8 or so make a difference? I understand it would mainly buy lower end torque. The other 'while you are there things (besides the usual belts, etc) would include matching the exhaust manifold to the head ports, and looking at blocking off air injectors. I'd also consider removing the heat shields and porcelein coating the headers. I will wait to see what flow improvement Mark and his machinest bench out, but I an quite optomistic, although I can't believe it is worth 50 hp...or is it? So if I paid to have this done - are we talking around $4K soup to nuts?
While most of my experince is with 2 wheels, proper porting REQUIRES the use of a flow bench to qualify and quantify the modifications. Porting may include removing material, adding material or modifying port shape and location. Far too many heads have been turned into junk by just hogging it out, and not knowing what you are doing. Cleaning up the heads (Matching the ports and manifolds, etc) will give improvements, but not what a full poting job would. The rule of thumb that I have heard is that HP increase is about 50% of the flow increase. (Increase flow 10%, HP increases 5%)
As Fred says, porting cant be done without a flow bench and many involve removing or adding material. It also cant be done without a calculator. Just making the ports bigger will usually make more flow, but to make hp, the velocity of the air is as important as the quantity .its been my finding that most people, even people with flow benches, do more harm than good when they start porting a head. Its really hard to do the job right. I called T. Rutland today and they are looking for a scrap head for me. A scrap head to play with should save a lot of time because there is no need to be careful if we grind too much, a little modeling clay will put it back. Im pulling my engine and popping off the heads Saturday. Then Im ready for a trip up to my buddy Vics to see what Ive got. Ive done a few heads with good results, but Vic has done 100s with what I think are great results so the plan is pretty much just to do as he says. His first look at the valve sizes and everything that I emailed him make him think 335-345hp NA with stock cams. To me the numbers looked like more lift would be better, but I havent talked to him about it yet again Ill probably just do as Im told. I sent Vic an email last night and asked if he had any idea about price but he may want to wait until he sees everything. Im not sure about milling the head Ill look at the scrap head to see what could be done. Maybe the guys at Norwood would have an opinion on it? Compression is good, that Im sure of my first thought is you would want to change the pistons to get it, but there may be metal that can come off the head I need to look at it.
I talked to James at Norwood (those guys are great) this am. The good news is that he is going to call Bob Norwood and ask him to run some computer sims of porting a qv head as well as changing some cam timing as well. The less than good news was that James did not think there was a lot of hp hiding in the head, not cost effecrive anyway, and mentioned anumber of 10 hp. He also freely admitted that he did not do NA ports, as his expertise was in boosted engines. He did mention the Ferrari factiry valve jobs were exceptionally poor, and some angled seating would help. He said that he'd need about 2 weeks to get the computer sims from Bob. We also talked about shaving the heads. He said it was possible, but Ferrari did not leave much to shave off, maybe up to 20 thou; he also said that with the roofed chambers you do not loose as much volume as with a hemispherical chamber; The bottom line is that you are talking "much less than a point" and taking away material that you may wish you had at the next rebuild. He also echoed your statement that most people do not know how to do 4 valve heads well, and that a 2 valve head porting is totally different from 4 valve, and they usually just mess them up for a whole lot of money. I'll be interested to see what numbers you can come up with. If they look promising, see if your guy will do a package deal for 4 heads...
Ill know a lot more once I personally see the numbers on a flow bench, but if Kermits numbers are right, there is a lot more than 10 hp hiding there. Even if it turns out my number dont agree with his values, the ratios of intake to exhaust are still way way off, just fixing that should gain 20+hp if I had to guess. Im going to try to set-up the flow bench for next weekend .so well at least have the baseline confirmed and I should be able to spend at least ½ a day with Vic trying to make it better .now understand, getting the flow right on a new head that neither of us have messed with before could take 10 or 20 hours on the flow bench and includes port, valve, and combustion chamber iterations. Once everything is figured out, doing the rest the same goes pretty fast maybe a couple hours per cylinder. It often means ordering custom valve shapes.
The heads are off. Now the cleaning begins. Hopefully I'll get the junk/practice head this week and can get to the flow bench next week. The feeling is the exhaust valves are fine to big as is, but the intakes are probably just too small...but we'll find out soon enough. Anybody have any idea just how much lift can be put in a QV head? The math says 340ish hp on OEM cams, but the intake valve really wants to open almost .400 to get the full potential out of the engine.
Is it possible to put newer heads on the motor, rather than spend the time porting them? From what I saw, the 308, 328, 348, 355 all share a common bore, and just vary the stroke. It seems that it would be possible to stick 355 heads and pistons in any of the motors, for instant power. Or am I missing something?
That was my first thought too: http://www.ferrarichat.com/forum/showthread.php?t=88373&highlight=355+heads Then I got to tons of boost, which is what I started this thread with....now I'm back to do what I can with the OEM heads and use modest boost. I'm still a bit concerned about what I see on the exhaust side of the stock head....the port is bigger than the intake which will make it really hard to get the exhaust flow to 80% of the intake flow while maintaining velocity. I may need to weld it in a bit - the 911 heas I did needed a ton of welding in the exhaust port, I made the port 33% smaller and got 66% more flow. I'm hoping I don't need to go that way here. Maybe larger intake valves and port to get the ratios better...maybe an extension on the header that fits into the port to reduce the size a bit. Or maybe, as you suggest, force fit a set of modern heads.
I thought I should share this...the other day I finaly got the time to conver the 83 lb/min the monster turbo I was thinking of to cfm....it turns out the blower I already have on the car flows about 81 lb/min. I would have spent a lot of time building exactly what I already have in a much harder way. I need to get the heads fixed so I'm not losing pounds(or cfm) of air and fuel out the exhasut pipe. Looking at the head, the exhaust port exit is about 20% bigger then the intek inlet when it should be 20% smaller...that's going to be hard to fix.
if you use QV heads, just "de-lobe" half of the exhaust cam and you'll have half the exhaust valve area, making this basically a three valve head. You could also use a larger exhaust valve for the one that opens. Don't take this too seriously, just a thought. btw... got to touch base with you on finishing up / modding if needed my system. It's been collecting dust. Been considering just making the beas normally aspirates and selling of the Supercharger sytem. JD
On the topic of putting newer heads on, I wonder what the combustion chamber volume is? The 348 head has larger ports, and valves, so there may be some advantage there, but then again the exhaust port will be bigger,and flow will drop of in velocity. Putting 348 inake valves in the QV heads may be the best avenue, considering cost/outcome. This will increase the valve size about 1.5-6mm, and will produce some gains. Decking, or surfacing the head wont gain enough in compression to be worth the effort, IMO, and will not allow a "second chance" should the heads need it later, due to the lack of material. Necking down the exhaust is a lot of work, and will gain flow on th flowbench. I wonder how that relates to actual use in a street set up, with the restrictive exhaust?
Hey Mark: I'd been down an exploratory path with Bill Pound a few years ago on this topic. (Pound and Norwood built the IMSA 308s.) His comments: 360 BHP from 4 valve, 380 on race gas. 340 from 2v. Race gas. Wild cams, lots of porting. Trick (shim under) set ups. Measured on engine dyno. Barry Sale (engine builder of repute in Chicago-region) obtained 342 bhp from 2v. Race gas. On the 2v cars, Michelotto used the 208 heads -- exports were too large on the 308. BTW, Bill used to rev the cars to 11,000... Good luck Philip
Sometimes, just reducing the lift in the cams does help, it's not as goos as fixing the port, but it helps. The problem here is that the exhaust seat IDs are pretty much the right size...but the port exit area it 60% more than the seat area. Air just hates to go from small to big. When the angle in more than about 8 degrees, the flow separates from the wall and goes turbulent. That is what is happening in the QV exhaust port. It makes the port inefficient and causes the flow to go up with valve lift WAY past the point where valve lift should matter. I dont see any choice but to close it up about 60% Im hoping to figure out some way to just put in an insert welding in a port s*cks. On the intake side on the other hand, the seat IDs and the port are probably too small. Vic is going to try to work some magic, but Im pretty sure well end-up increasing the seat ID and valve by 2-3mm but if we do that, it will need more lift in the cam like a 328 intake cam maybe. Let me know...we'll get it straightened out.
Bigger combustion chamber mean new pistons to get the CR back up. I'm thinking bigger valves will probably be required...I hope not...but probably yeah, probably not a good idea. A flow bench doen't tell the whole story, but when the number are what they are supposed to be, you almost always get the best hp. So, the exhaust won't be "restricted", it will be corrected. Bigger doesn't mean better most of the time.
I'm thinking that I don't think I trust development work that was done 20 years ago anymore. I know that a 3 liter race engine should make 420+ hp, 2 or 4 valve. In street trim with a stock redline 340 should be a good number, 380 should be good with an 8500 rpm redline. I might be wrong...time will tell.
Philips post got me thinking just a little bit so this is a bit of a soapbox post so stop reading now if you have weak stomach It often seems to me that us ferrari types have been living in the ivory tower just a bit too long. We think the reason a street model ferrari cant beat a 911 on the track is because the rules favor the porsche. We think the reason a ferrari cant beat a vette in an endurance race is oh I dont know, the rules again. We think we need to hide from supras.. ..whatever you do, dont race a supra. Why? Because there are supras out there with more hp than any TT 512TR ever had. It seems nobody ever stops to actually ask why though. I think the answer might be engineering. The supra has a head that flows right from the factory. A 308QV head is so bad Im not even sure it can be fixed .its a ferrari and the head design is so bad it may not be salvageable. That is sad. Honda makes more hp/liter than ferrari, that is sad too. In college I has a suzuki switft that made as much hp/liter as as the ferrari of the day an economy car for Gods sake. Im hoping to get the same hp/liter I get out of my harely .think about that. A harley isnt exactly known as a hp king in the world and I just wish my ferrari could be that good sad. A small block chevy race engine makes 800 hp from 5.7 liters thats 140 hp/liter from a 2 valve pushrod engine but a ferrari 308 4V overhead cam engine can only muster 126? Sad. I honestly never thought that much about it because its a ferrari. I blamed the low hp of my car on it coming from the emissions era. I never really looked at the heads or flow when I built the engine because I was planning on boost anyway. But this project got me wondering about the supras. I spent a couple weeks my 308 barely makes 400 that made me think a bit. OK Im done ranting back to the regularly schedule thread
FWIW, found this old chart in my files - it's an unported 4valve intake head flow at 10". Image Unavailable, Please Login
