Supercharged QV (take 3)-or is it a turbo? | Page 5 | FerrariChat
Discussion in 'Technical Q&A' started by mk e, Jan 12, 2006.
  1. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,862
    The twilight zone
    I've got that and the matching exhaust...it's part of what sent me on my rant :)
    For a 375cc cylinder at 7700 rmp, that 94 number should be well into the 130s, 140 would be better. The exhaust should be about 110-115 to match.
    The intake port looks pretty good size wise, I'm sure it can be fixed and made to flow what it needs to flow without alot of work. The exhasut port needs to be made over 1/3 smaller to make it right...that's going to be hard. The engie will run much better and make a lot more power just getting the intake flow up and getting a matching exhaust flow without good port efficeincy on the exhaust, so I may have to settle for that...but I'd guess that would leave 10-20% of the hp gain that's possible sitting on the table (or the flow bench :) ).... I hate to leave hp behind, but that might be the best thing to do. It would certainly keep the cost of doing the head down if it doesn't need welding...I'm still hoping to be able to put an insert in. If it can be done with an insert, it would be almost as good as welding and way cheaper and easier.
    Maybe the thing to do is have Vic do the heads 2 ways. Porting, no welding as a stage 1 head, good for most applications and stage 2 welded with everything optimized to the particular engine set-up..twice the price for 20 extra hp. Something like that.
  2. Artvonne
    Artvonne F1 Veteran
    Oct 29, 2004
    5,379
    NWA
    Paul
    I know what your saying here, but I think you need to consider some other factors. And take note that I am no means any real expert, just observant.
    First of all, as I have bumped along, I have been more and more coming to the conclusion that 4 valves dont necessarily make more power. But they do seem to have better low end power and hold it over a wider range, and they are good for emissions. Also, I think what we get with a Ferrari is the name, but not necessarily thier top engineering. In going over my own 308, and in talking to people at Wiseco, Norwood, and others, as well as many people here and elsewhere, Ferrari seemed to have built these engines in a way to drastically detune them.
    On my particular motor, the pistons come up to TDC and stop .055" below the top of the liner. Wiseco confirmed that on all the 308 motors they have made pistons for, they were all in that same range, QV's included. While my engine had 9.7:1 Borgo pistons, it actually only made a calculated CR of only 7.9:1, Stock pistons would never net anything close to the 8.8:1 Ferrari claimed, more like 7.4:1 or less. Perhaps this is why they work so well turboed???
    The cylinder heads have the exhaust ports offset from the header ports by 4mm, and are drastically large in comparison to the intake, and quite a bit larger than the header port. Some have said this was done for emissions reasons, to create turbulence for the air injection. For a factory hell bent on racing, and attempting to sell an image of thier accomplishments, it had to be hard to be forced to detune thier engines further and further to comply with world wide regulations.
    I honestly believe that if owners had raced 308's on the track, and developed aftermarket components to improve the cars braking, handling, and power, it should be highly capable of whipping any 911. Its liquid cooled, and the architecture is there to make a lot of power. But Ferrari were also trying to package the motor back there under that deck lid, so maybe thats why it has such screwed up heads. I don't know. Your 800HP Chevies have some pretty radical heads over stock so I dont know if thats a fair comparison, and all of the jap cars, while capable of making huge amounts of power, are not able to stay together at those amounts for any period of time.
    So where is the power? Again, not a big expert here, but just looking at this motor in comparison to others, it "looks" like it should be able to make quite a bit. I personally worked on a Renault 813 engine, that was highly modified for ice racing. This would be the hot Renault engine for a Europa, and thats actually what this engine ended up in. The heads were ported, high CR pistons, pair of 45 DCOE's, header, and a very very hot cam. The motor idled at about 1500 and was very loud and rough. Gassing it would immediately send the tach past 5000. While it was never dynoed, the general feeling of those involved felt it was making over 200 HP. That motor was 1565 cc, so roughly half a 308. But it had pushrod valve train, and I doubt the head could ever be worked to flow like a 308 could, it just was a tiny and short head.
    So, I think if you took a good streetable figure of 120HP per liter, NA, our 308's should be "able" to produce in the neighborhood of around 360, but most probably wouldnt like it as it would be far to peaky. So backing off to 100 HP per liter, makes a good streetable figure. As you are wanting to supercharge yours, it will be interesting to follow your discoveries of the cylinder head. I really think this is where the engine will make its power.
  3. Fred2
    Fred2 F1 World Champ
    18,351
    nj
    I have used special porting epoxy to correct inlet ports near the valve seat area, and the epoxy lasted well. I seem to remember that thy also made an epoxy for exhaust ports.
    (I think it was a Moroso or a Manley product.)
    I am sure that it would work for a naturally aspirated engine, but I am not so sure on the exhaust temps when a supercharger is put into the mix.
  4. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,862
    The twilight zone
    I've epoxied intakes too, but never thought about it for exhaust....I'll do a search and see if anything turns up.
  5. bretm
    bretm F1 Rookie
    Feb 1, 2001
    4,577
    Northern NJ
    Bret
    Mark, any thoughts on stock compression? Are you still running stock pistons? I thought you changed when you did the 2nd blower.
    I never calculated my old one, Krowbar's number of .055" below the deck is correct though (I think I got .056, regardless). I don't remember the head cc off hand (around 30 maybe). To get to 11:1 we had to run a touch above the deck to make up for the valve pockets.
  6. Artvonne
    Artvonne F1 Veteran
    Oct 29, 2004
    5,379
    NWA
    Paul
    I measured 40.5 cc chamber volume on my 2 valve heads which was a number Wiseco also had. So along with that and a good head height I have heads that were never milled. I have no knowledge of the QV head volume.
    Brett, I am curious how high above the deck you went? I should be about .010" above if I recall, with 10.4:1 CR. But these new pistons have some pretty radical pockets and I think I may carefully mill off the sharpness of the pocket edges, so as not to have any hot spots.
    I would also be interested in hearing opinions on coatings, like on piston crowns. I know they work short term, but what about long term durability, flaking, etc. I am also somewhat concerned with the idea of a straight stainless steel exhaust valve, vs sodium filled. Would new sodium valves offer any real benefit and or, is straight stainless durable enough in our applications?
  7. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,862
    The twilight zone
    I still have the stock pistons...at least for now. My pistons are about .055" below the deck too...but I haven't calculated the CR yet. With boost, low is good, so it doesn't all that much matter I guess.
    Optimal is about .030" squish to the piston, so it sounds like yours is just the way it should be.
  8. wildegroot
    wildegroot Formula 3
    Nov 19, 2003
    1,522
    Frenchtown NJ
    Wil de Groot
    We had a set of 12 pistons coated a while ago for a Diablo engine we were hopping up a little. We had anti-friction coating applied to the skirts and a high temp coating applied to the piston tops. We were experimenting with some special rings that turned out not to want to seat and wound up taking the pistons out after only a short time. We were amazed at how quickly the coating was disappearing after such a short time. With all the oil that was being pumped through the combustion chambers you would think, air/fuel ratio being the same, the pistons would not be running that hot.
    One thing I've considered doing to my(supercharged) 308 engine next time I take it appart is to install spray jets to cool the pistons from below with motor oil. It's not a new concept but it shouldn't be too hard to rig something like that up to keep the pistons alive under boost.
    One problem with putting large non-aluminum (epoxy,etc) lumps in the exhaust ports might be that it acts as an insulator, possibly making problems with uneven expansion in the head. 308 heads are already prone to cracking.
    I've supercharged two engines before this one with great results but still consider myself a novice at that end of it. I've only had a few chances to check in on this thread but I'm really impressed with the mental processes going on here. It's been great reading. Inspiring reading.
  9. Artvonne
    Artvonne F1 Veteran
    Oct 29, 2004
    5,379
    NWA
    Paul
    I was reading that idea, and while I wasnt thinking insulation, it didnt seem like something that would stay there very long. I thought of an aluminum tube type insert, like Mk e suggested. But again I wasnt considering it being an insulator, more I thought it would be a really good place for corrosion to start. So is the best way to solve the problem really only to weld the port up? I have never liked welded up heads, but if there was a good enough performance gain I might consider it. Then I could re-center the port so it flows directly into the header. Does anyone have a ball park idea what this would gain for power?
  10. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,862
    The twilight zone
    I was a bit worried about corrosion to...and once it gets corroded the insert is insulated and will get really hot, probably hot enough to melt if it's aluminum. Plain carbon steel of inconel might be the way to go...or just remember the world is not a perfect place and live withit being oversize.
    I don't have any idea about flow in a 2 valve head to make a guess at hp gains...I think I remember reading something on the 4 liter thread about it, but I don't recall. ... I'm pretty sure I read the intake flow is poor. I'd guess it's at least as poor as the QV head. That being the case, there's at least 50 hp to be gained with proper porting....but that's proper porting, not eyeball porting.
  11. bretm
    bretm F1 Rookie
    Feb 1, 2001
    4,577
    Northern NJ
    Bret
    krowbar, I have wisecos for my 4v, definitely grind down the pocket edges. They provide the pistons somewhat unfinished (like most other one offs I suppose). I used a dremel to smooth/round the edges of the pockets and then just polished polished polished on a wheel until they're mirror-like.
    .010-.015 above the deck is about where I'm at, compressed head gasket was .050 or .055 IIRC. I have all the exact numbers at home, it's been awhile though.
  12. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    Being a government employee and all, I've been wondering about most bang for the buck. It's been mentioned before that perhaps just opening up the intake side might be the best way to go, especially with a view toward reliability (Very big with me) based on the recent exhaust concerns.
    If the head could be done with just the intakes done to an open 348 oval spec and simply better match the exhaust header to the port and clean up the injector, that seems like the best overall fit. If I could target a reliable 265 - 270 rwhp / 215 - 230 rwft-lbs from a na 3.2 4 valve, that would be the ultimate street engine for me.
    Looking forward with great anticipation to the flow numbers.
    best
    rt
  13. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,862
    The twilight zone
    I think you're basically right Russ. I'm sure the intake side can be ported to flow correctly without any real problem. The exhasut side needs work no matter what. IfI were building a race car, there is no doubt I would weld the port in to make it perfect....but for a street car perfection is not always the best path to flow, often the extra hours of work just aren't worth the gains. I'm just not seeing a good way to do an insert, and I'm not keen on welding my heads, it's just too much work...I had over 100 hours into the 911 heads I did, after that I decided boost was the way to go. Now I'm thinking there may be a happy medium.
    The numbers I have say the exhaust port flows about 86 at .300 lift and 96 at .450. It needs to flow more like 115 at .270 lift. I'm pretty sure that with a little work around the seats the numbers can be brought up to where they need to be...if worse comes to worse, we can always open up the seat ID a mm or so and get the number...the bigger the seat, the closer the exit is to correct. The port won't be perfect, but it will flow what it needs to flow...so instead of a gain of 60-80hp, the gain will be a little less, maybe 40-70hp...I don't think were really talking about leave a ton of power on the table, 10-20 I guess. Getting the intake perfct is much more important than a perfect exhaust I think.
    T. Rutland still hasn't actually found me the head they think they have....maybe Monday.
  14. TURBOQV
    TURBOQV Formula Junior
    Mar 6, 2003
    838
    NV and Utah
    Interesting project Mark.
    I have one going on myself. I bought a complete spare engine and trans on Ebay and have decided to make the next one twin turbo with a 50 shot of NOS to reduce lag. The ball bearing turbos should help as well and bring on hp sooner. I am wondering if working the heads is worth it? for 40-70hp it is not worth it to me. It seems the gains should be more?
    cheers
    paul
  15. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,862
    The twilight zone
    Paul,
    Good to hear form you...and you're at it again too :)
    40-70 is with OEM cams and pre-boost. 40-70 is 80-150 at 15 psi. I'm not sure what you're thinking, but as you up the redline, the numbers just keep going up if you can continue to fill the cylinders.
    Right now I'm thinking that with the heads fixed and the cams re-timed to about 114 degrees lobe separation, I should be looking at 15-20 psi and 700-800 hp just bolting the blower I already have back on the engine.
    Question for you, I know you're running 15 psi now, but what turbo are you using to get it? My blower is pumping about 1100 cfm, which is about 81 lb/min of air....everything I find syas that much air is good for over 800 hp and I'm wondering if you're suffering the same amount of blow-down with the turbo that I am with the blower????
  16. wrecktech
    wrecktech Formula Junior
    Jun 4, 2004
    368
    Fort Wayne, Indiana
    Out of curiosity, what if you could use an a/c evaporator as part of an intercooler? Or why couldn't you?
  17. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,862
    The twilight zone
    Do you mean run the A/c to cool the intake air? If so, it ends up a net loss. The power required to drive the compressor is more than the added hp from the colder air. Misting the intercooler with water or better yet alcohol works well…spraying it with CO2 or better yet liquid nitrogen is even better :)
  18. wrecktech
    Jun 4, 2004
    368
    Fort Wayne, Indiana
    I thought it might be the case. When we charge an a/c system we usually get the air temp down to about 40 degrees or so. I wasn't sure if by using two seperate evaporators on the a/c system and switching off the cab a/c and turning on the evaporator in the intake would be of benefit or not. This is a very interesting thread.
  19. TURBOQV
    Mar 6, 2003
    838
    NV and Utah
    Garret turbo on the car now. I do not know the trim sizes. I will have to look at the original invoices.
    This turbo is going to be swapped for a hybrid ball-bearing T3/T4 60-1 Hi-Fi w/ P trim .81 dry/standard cart. This will increase the air flow considerably and bring on the boost 300rpm or so sooner. At 18 psi I am anticipating another 80rwhp. James at Norwood says this is the right turbo for the car. I have been told it will pull strongly to 8000 rpm without giving intense "shock load" to the transaxle. I can give up a little boost response in an effort to save the transaxle.
    The TT turbo project will involve hotter cams, lighter cam followers, stronger valve springs, billet rods, twin ball-bearing turbos, Motec, and a 50 shot of NOS to get things rolling. I bought a set of headers on Ebay that look horrible from the factory. I was hoping to use these with the new engine. The were obviusly made before a mandrel bender. I do not know of anyone that makes headers for a turbo 308 application? I am thinking that you and I could benefit from some headers that flow much more effeciently than the euro headers. Look at the ripple in the pipe in the link below. Not good for flow!
    http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1,1&item=4600064092&sspagename=STRK%3AMEWN%3AIT#ebayphotohosting
  20. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,862
    The twilight zone
    Interesting. I'm a little surprised that you don't already have a BB turbo.
    A 60-1 flows about 63 lb/min at 18 psi max with the surge line at 25 lb/min on the map I have. if say 60 is enough to feed your engine at 8000, I guess that means it could be set it up to hit full boost right around 4000 maybe 3500 and miss the surge line.
    That’s a definitely less air than I am using to make that boost. My boost is 18 at 7000 rpm and I’m at about 72 lb/min. flow. The boost hits 22 psi at 7700, where I’m using about 80 lb/min….hmm, I just did the math and I guess it would hang right at 72 lb/min all the way up to 8000 if the boost straight flat at 18 psi…I didn’t expect that result. That means that at 18 psi, the flow of the engine itself is maxed out at 72 lb/min and the torque (and therefore cylinder fill) is dropping inversely proportionally to the rpm increase…which of course confirms that the heads are the problem….sorry for the side track here.
    I’d still love to know which turbo you have now to have a true tested point to look at and compare to the maps and see how much air you’re actually using….I’m honestly surprised it seems to be doing better with air because if I recall, you have some pretty big fuel injectors (52 Lb/hr?) fed by 2 fuel pumps to get the fuel flow you needed….and 52 lb/hr injectors should be able to feed at least 600 hp…you don’t know your fuel pressure and injector duty cycle do you? I’ve got 55 lb/hr injectors at 60 psi, which makes them about 62 lb/hr injectors running at 90%…which is something like 750-800 hp worth of fuel to make my 500 hp
    The headers do look a little ripply….and also appear to be for a single cat set-up. I’d thing for a TT car, you’d want to start with the ‘83 dual cat headers, the rear header points in the other direction and it seems like that would give you more room for the 2 turbos…maybe not. If you can’t find what you what off the shelf, there are plenty of places that can make anything you need. I’ve made about ½ a dozen sets over the years just by buying mandrel bent tubing (it comes 45, 90, 180 degrees) and tig welding it together to get what I needed.
    I’m very seriously thinking of making a set of step-headers for my car. The stock headers are 1.5” tubing, if I leave the stock redline, they probably fine. If I end up doing cam, I may bump the redline to 8500 or 9000 and then I think 1 5/8 is probably a better size….and I guess I’d go with dual mufflers at the same time.
  21. TURBOQV
    Mar 6, 2003
    838
    NV and Utah
    I would have replaced the turbo at Norwood had I known it was not the ideal setup. James told me this after I outgrew 14 psi. I would ship it in a heartbeat but the last time i did that it came back with a ding in the front fender. 42lb. injectors on the car with two fuel pumps, secondary comes on at 10psi. I have way too much fuel right now which is ok since I am going to up the boost to 18 with the new turbo.
    fuel pressure and duty cycle i do not recall? I can get that off the Haltech? 60 psi sounds right but not absolutely positive.
    Bigger headers would be a great benefit that is for sure.
  22. TURBOQV
    Mar 6, 2003
    838
    NV and Utah
    Garret T04 is all it says on my invoices from Norwood.
  23. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,862
    The twilight zone
    42 lb/hr...I wonder where I got 52 in my head....probably by not reading carefully....that sounds small, unless your engine isn't wasting stupid amounts of fuel like mine is :)
    On the pressure, if you don't have a gage on the regulator, you won't know.
    The haltech will data log injector duty cycle I think, but I don't recall it reading it out anywhere. The easiest way to get it is to just look at the fuel map and see what the injector pulse time is and just do the math. It's probably set-up to fire the injectors every revolution, so I'd expect to see times of about 6-7 ms. Then 7700rpm, is 128 rps (revolutions per second), which is 7.8ms per revolution. That would make duty cycle 7/7.8= 90% if the time in the map is 7ms. If you see times over 8ms, that means they are per cycle, not revolution, and you need to divide by 15.6 to get duty cycle.
  24. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,862
    The twilight zone
    I finally found a scrap head to play with on the flow bench...that was harder than I thought it would be (in both time and money). It's coming from the other coast, so it will still be a week before I have it, but at least it's coming.
    I've got it in my head that lobe separation angle is also going to be a key in the final set-up. I've currently got the cams timed at the euro spec which is a 109 separation angle. I see 114 quoted on blower cams often and that is for relatively low boost blowers...I'm thinking start at 114 when I put it back together and see what happens goin up to 116 or 118....and hopefully get the air to stop blowing out the exhaust.
  25. wildegroot
    Nov 19, 2003
    1,522
    Frenchtown NJ
    Wil de Groot
    I think you want a little valve over-lap to help cool the exhaust valves. Besides, how else are you going to make those big flames out the back?
    I have a couple of junk 2 valve heads if you ever need one.
    Good luck on your mission. It'll be interesting to learn what you discover chopping up that 4 valve head.
    Wil
