Supercharger Options | Page 2 | FerrariChat
Discussion in '308/328' started by smg2, Mar 25, 2007.
  1. SonomaRik
    SonomaRik F1 Veteran
    nice work Scott....
    now.....when done, we'll dream of some 348 work :\
  2. regisgtb4
    regisgtb4 Formula Junior
    463
    tx
    willis
    Looks so nice and 308s are such a nice sized car that we love em. Classic v12s have that splined crank and I never saw trouble in 28yrs with the cars, I saw lots of trouble with bmws and that awfull keyed crank.Will that front pulley hold up? I grew up in a Pontiac Buick Opel dealership and we burned out every ride. Will that front pulley take t he pounding of continuous full off/on throttle. At high speed interstate work backing off /on throttle @ 130mph really puts a rockin on the piece even being smooth.Have you run it @80/135 continuous on interstates? I really do appreciate your great efforts and would love to splurge but remember the old addage,"if you want a faster Ferrari, buy one"
  3. Mike C
    Mike C F1 Veteran
    Aug 3, 2002
    6,081
    Southeast USA
    Mike Charness
    I considered doing that, but the 308 is my FAVORITE Ferrari body style...
  4. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,148
    Dumpster Fire #31
    SMG
    yes I have run for extended periods of time at high speed and down shifted at 85mph into 4th for passing as well. I've run it for over 6hrs at 90mph with bursts into the arrest me range.
    no issues at all, I have put it thru 6k miles of grueling abuse from 110*F days to 14*F days. 100 octane racing abuse, full throttle red-line shifts. all of this at 20psi. I wanted to make sure it will stay together when pushed.
    the pulley is attached to a new mechanical dampener that replaces the stock unit. it is concentrically mounted to the dampener and held with (3) 5/16-24 screws and then the large crank bolt holds the entire assembly to the crank.
  5. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,630
    The twilight zone
    The Butcher
    I've put about 15k supercharged miles on my including about a dozen autocrosses and there has not been even a hint of a problem with the balance or anything else for that matter.....well the clutch wasn't too happy.
    My pulley is quite a bit shorter than Scott's, but I've also got a 10 rib belt on mine cranked about as tight as I can get it to keep it from slipping.
  6. regisgtb4
    463
    tx
    willis
    Why no need for an intercooler in constant high speed operation?Will the jet tronic compensate @ 20psi or are there mods? Ive done a couple of snapped trans shafts in euro and USA 308s, any comment? Will the ebay kit for $6500 fit my euro 84 german gts?
  7. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,148
    Dumpster Fire #31
    SMG
    I have no affiliation with the Ebay kit so I can't answer that one. as to the 20psi, this is a centrifugal supercharger in order to operate at full boost for extended periods of time would require vast amounts of open highway. most of the time i'm operating at 8~10psi with blips into the 15~20 range for brief seconds.
    when cruising at speed the charger is bleeding boost because the throttle is barely open. under the boost threshold there is little to no strain. unlike a positive displacement blower where boost is constant and available from off idle the centrifugal builds boost in relation to RPM, so at 20psi max it's only 4psi at 3krpm. with the power building in such a manner it's harder to strain the transmission.
    no intercooler as yet, I'm working on a water/air plenum to replace the stock one. the infrared temps show that the heat from the engine and exhaust into the plenum still exceed the supercharger heat from compression. which is why i want to cool the plenum as well.
    I could not find any info on the pressure limit for the CIS, I'm running what I'd consider the limit but I don't know. the WUR Ferrari spec'd controls fuel pressure based on boost, vacuum and altitude that is why you can boost these motors with the stock CIS.
  8. Mike C
    Mike C F1 Veteran
    Aug 3, 2002
    6,081
    Southeast USA
    Mike Charness
    #33 Mike C, Apr 22, 2007
  9. Mike C
    Mike C F1 Veteran
    Aug 3, 2002
    6,081
    Southeast USA
    Mike Charness
    #34 Mike C, Apr 22, 2007
  10. Pizzaman Chris
    Pizzaman Chris F1 Rookie
    Mar 13, 2005
    3,919
    New Hampshire
    Pizzaman Chris
    Hey Mike,
    That second picture, are you taking it apart to see what makes it tick? :D
  11. Mike C
    Mike C F1 Veteran
    Aug 3, 2002
    6,081
    Southeast USA
    Mike Charness
    I know it kind of looks like that's what I've done, but it's really just the rear-side external view of the machined gear/shaft casing of the particular V9-G model that Scott spec'd out.
  12. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,148
    Dumpster Fire #31
    SMG
    Alright, in keeping with the current theme of sharing :D here's some video of runs I've done. i'm going out this week to do the install on Mike C's 308qv. I'll get some vids of that as well. there will be more added, upload is slow right now.
    http://www.youtube.com/watch?v=s-w3B6QcaJ8
  13. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,148
    Dumpster Fire #31
    SMG
  14. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,148
    Dumpster Fire #31
    SMG
  15. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    Sounds great to me - I cannot discern any supercharger whine in yours or Lou's - is that accurate or just my speakers?
    Would love to hear it from the outside.
    Great work!
  16. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,148
    Dumpster Fire #31
    SMG
    it's weird to me as well but there is no whine. I know that positive displacement blowers will whine due to their nature but the centrifugal should have some, but it's drowned out by the engine noise. the only tip off is the blow off valve which on mine is LOUD due to 20psi and when you shut her off for a brief second the gear whine is noticeable.
  17. DavidDriver
    DavidDriver F1 Rookie
    May 9, 2006
    4,424
    Grass Valley, CA
    David Driver
    So, if I want to do this to my GT4:
    1) I have to convert to FI
    2) Will all that extra stuff fit in my car?
  18. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,148
    Dumpster Fire #31
    SMG
    you'll need EFI, stock or otherwise and yes it'll fit in with room to spare.
  19. GrigioGuy
    GrigioGuy Splenda Daddy
    Nov 26, 2001
    32,625
    E ' ' '/ F
    Merritt Tockkrazy
    A point of clarification, please? I thought the point of this was that you could run the supercharger without converting from CIS to EFI? Am I wrong?
  20. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,148
    Dumpster Fire #31
    SMG
    no no no, you're right, David is running carbs from what i recall so he would indeed need to run some sort of FI or EFI. this was and is designed to run on the stock CIS. however I'd think that if you were to upgrade to FI from carbs I'd go past CIS and move over to EFI, additional power and better adjustability in tunning.
    so yes, i got fast and sloppy with my acronyms :D
  21. DavidDriver
    May 9, 2006
    4,424
    Grass Valley, CA
    David Driver
    Hmmm..
    This is sounding intriguing. The idea of converting though, seems a little daunting, if not fairly expensive..
    any thoughts?
  22. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,148
    Dumpster Fire #31
    SMG
    if going to CIS you'd need all the stock bits. CIS, manifolds, intakes, WUR, injectors, sensors, etc... not sure what that would cost, probably ALOT from a parts place. you might find somebody who upgraded their CIS for EFI and buy their old stuff, providing they sell.
    I think EFI would run about 3k, check with Mark, aka Mke here, the other insanely boosted 308. he'd know for sure.
  23. DavidDriver
    May 9, 2006
    4,424
    Grass Valley, CA
    David Driver
    Thanks. You have a PM
  24. GrigioGuy
    Nov 26, 2001
    32,625
    E ' ' '/ F
    Merritt Tockkrazy
    Oh right, forgot where he was starting from. My apologies
    I have a friend with an 82 Mondial who might be persuaded to swap for a carb setup. I can't guarantee that the CIS is currently set up right, though. As a second thought, isn't there someone on here with a GT4 and CIS? Maybe some creative trading there?
    Just random late night thoughts.
  25. Mike C
    Mike C F1 Veteran
    Aug 3, 2002
    6,081
    Southeast USA
    Mike Charness
    YEAH, MAN!!!! It's very disturbing... I mean I'm so jazzed and eager that it's disturbing my concentration on getting anything else done between now and then! ;)
    Wednesday is the planned install day, Thursday is tuning and Dyno!
