Supercharger Options | Page 3 | FerrariChat
Discussion in '308/328' started by smg2, Mar 25, 2007.
  1. Dr Tommy Cosgrove
    36,716
    Birmingham, AL
    Tommy
    When can I come see it?
  2. Mike C
    Mike C F1 Veteran
    Aug 3, 2002
    6,081
    Southeast USA
    Mike Charness
    Any time, my friend! I know you're next! ;)
  3. Pizzaman Chris
    Pizzaman Chris F1 Rookie
    Mar 13, 2005
    3,919
    New Hampshire
    Pizzaman Chris
    Scott is doing house call???:)
  4. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,544
    Dumpster Fire #31
    SMG
    why of course :)
    it comes down to the customers needs or wishes. each one being different, If it works out I can go out and do the install or if preferred the car can be brought over for a custom install.
  5. Zertec
    Zertec Formula 3
    Oct 5, 2004
    1,335
    Singapore
    Clive Reed
    Hmmmmmm, holiday in Singapore......
  6. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,544
    Dumpster Fire #31
    SMG
    oooooh sounds exotic :D
    of course the lyrics to Dead Kennedys' Holiday in Cambodia came to mind when I read that. WOW that was 27yrs ago!
  7. Brian Harper
    Brian Harper F1 Rookie
    Feb 17, 2006
    4,078
    San Jose area
    Brian Harper
    No way, man! I'm saving up for the supercharger kit!!!
    Besides the CIS doesn't soot up the back of the car like a bunch of Weber accelerator pumps, and the car is white, so that's a big plus.
  8. DavidDriver
    DavidDriver F1 Rookie
    May 9, 2006
    4,425
    Grass Valley, CA
    David Driver
    Ahhhh... so YOU'RE the one who bought that car!!!
    How is the fuel pump/distributor/thingie mounted in your car?
    If you could share a few pictures, it would be GREATLY appreciated.. :D
  9. regisgtb4
    regisgtb4 Formula Junior
    463
    tx
    willis
    Thanks for the science and the effort. How much for the brackets? Thanks to all Ferrari men from Texas
  10. Pizzaman Chris
    Mar 13, 2005
    3,919
    New Hampshire
    Pizzaman Chris
    Scott,
    This sounds very very interesting.
    I'm asuming water/air plenum to replace the stock 308?? Something like Marks old SC?
    And this would work with your SC as an added goodie? WOW!
    Sorry for changing/hijacking the thread. Got a little excited.:)
  11. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,544
    Dumpster Fire #31
    SMG
    in a way I guess, the new water/air plenum would look just like the original 2v or 4v one but would have 'cores' that water flowed thru to cool the air charge. preliminary est I have show this costing an additional 2~3k however if I can do some volume on it that should drop into the 1k range or less.
  12. Artvonne
    Artvonne F1 Veteran
    Oct 29, 2004
    5,379
    NWA
    Paul
    Okay, I know its sooo 70's, but so is the car? So why wouldnt this blower work with carbs? If you pressurise the airbox, the vents for the fuel bowls are up top by the airhorns vented into the airbox, so the fuel bowls will always equalise pressure with incoming air. Obviously you would need more fuel pressure to overcome the fuel pump pressure, so you would need a higher pressure rated fuel pump with some type of rising rate pressure regulator.
    Will higher internal pressures make the carbs more susceptible to leaks at the lead plugs ? Well duh, we can we stake them better.
    Will they blow fuel mixture out at the throttle shaft bearings? Carl sells sealed bearings, will that eleviate the problem? Probably.
    Will changes in carb internal pressure throw fuel mixture off considerably? Lotus blew the Espri through Weber carbs, what did they do different from NA? I think unless you blow insane pressures they will work as is ?
    Would the stock airbox rupture with 5 PSI put into it? Well, we could always put something else together, Russ has sure built enough airbox's to be a pathfinder.
    If guys put in P6 cams or something reasonably hot, and get the power up near 275-300 crank HP NA, and then blow the airbox, what would say, 5 pounds of boost do to horsepower ? 7 pounds? 10 pounds ? How would you know when your nearing the limit of preignition or detonation? With Tubi exhausts etc., you sure as hell aint gonna hear it. Maybe an exhaust temp gauge?
    Russ should get in on this, his new motor would freaking leave orbit with just about any boost it could smell. What would 5 pounds of boost do to Russ motor as he has it described so far, IE approx 325 wheel HP NA?
    Discuss please.
    P.S. Scott, how much for a DIY blower only?
  13. ddiesen
    ddiesen Karting
    Apr 6, 2006
    159
    Mesa Arizona
    David Diesen
    I believe the computer to convert to EFI will cost 3 to 4k all my itself not including the rest .. or am I wrong? : )
  14. Mike C
    Mike C F1 Veteran
    Aug 3, 2002
    6,081
    Southeast USA
    Mike Charness
  15. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,881
    The twilight zone
    You certainly can spent that much, but you really don't ned to for most all applications, $1500 will get you a decent ECU.
  16. Svito
    Svito Karting
    May 13, 2013
    90
    Miami
    Svito Puko
    Hi, I am looking for some spare parts to upgrade my 308 QV. Where can I find those beautiful adjustable cam pulleys?
    In addition: do you have any suggestion about the best cam belts out there? And last but not least, what is in your opinion the best clutch for my car? Thank you
  17. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    Try this link to Nick Forza, is this the system?
    http://www.nicksforzaferrari.com/forzaferrariwebsite1_073.htm
  18. Pizzaman Chris
    Mar 13, 2005
    3,919
    New Hampshire
    Pizzaman Chris
    #68 Pizzaman Chris, Mar 12, 2014
    I like these belts. :)
  19. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,931
    Mike 996
    Heck, they say "Racing" on them so they HAVE to be good! ;)
  20. Bradley123
    Bradley123 Rookie
    Feb 25, 2020
    22
    Oakland
    Brad Kansas Long
    I just got a 85 Mondial with Electromotive EFI and ECU (TEC3r)
    smg2 likes this.
