Supercharging the F430 Engine | FerrariChat
Discussion in '360/430' started by Tarek K., Jul 23, 2007.
  1. Tarek K.
    Tarek K. F1 World Champ
    Sep 7, 2006
    10,788
    Cairo - Egypt
    Tarek K.
    What are the disadvantages on supercharging the F430 engine through the Novitec conversion and how reliable is the Novitec conversion?
  2. RBK
    RBK F1 Rookie
    Jul 27, 2006
    3,105
    Calif and Nev
    Bob
    Not to steal the thread, but for those who know - could you address turbocharging vs supercharging a 430 when answering Tarek or send me to another thread if it has been perviously discussed? I am considering the same. Best
  3. Tarek K.
    Sep 7, 2006
    10,788
    Cairo - Egypt
    Tarek K.
    The differences between turbos and superchargers are the following. Both provide additional air into the engine for more power. The most essential difference is the method of driving the turbo or supercharger. Turbochargers are driven by exhaust energy which is usually otherwise wasted out of the tailpipe into the atmosphere. Superchargers are driven by a belt which draws power from the engine's crankshaft.
    I guess applying a supercharger to a naturally aspirated engine is mechanically easier than applying a turbocharger.
  4. shawsan
    shawsan Formula 3
    Jul 2, 2004
    1,090
    Vancouver, Canada
    Another big difference between supercharging and turbocharging is that the supercharger blower is 'parasitic' whereas turbochargers are not. The supercharger takes power from the flywheel (and therefore engine) to drive it. If I recall correctly, the parasitic loss is about 10% -- though the added power generated by the SC will full compensate the loss. Also, incorrect set up, meaning bolt on, and alignment of belts can produce vibration, though I'm sure Novitec has worked that out.
    I can imagine that a Novitec supercharger system is good quality, with a good reputation for reliability. Having said that there are 3 realities one will have to live with after installation;
    1. If it breaks or performs sub-optimally, NO authorized Ferrari dealer will have the knowhow or interest in looking at it, repairing it.
    2. If it breaks or performs sub-optimally, you're not likely to have peace of mind or find optimal solutions unless Novitec people are in your city, state, country.
    3. When you sell your car, potential buyers will fear you're a power monger, probably driving the car into the ground. They will likely offer you less than for a stock car. Thus, if you spend $$ on a supercharger do it for yourself, with no expectation of a value-added return on your car.
    Just my opinion, based on my own prior experience of supercharging.
  5. charlie_ludden
    charlie_ludden F1 Rookie
    Nov 12, 2005
    2,762
    Orange County
    Charles
    PM
    2nastie
    he twin supercharged both his 430 coupe and his 360 spider.
  6. Tarek K.
    Sep 7, 2006
    10,788
    Cairo - Egypt
    Tarek K.
    Thanks ;). I will.
  7. MONARCHY
    MONARCHY Karting
    Mar 28, 2007
    76
    what type of blower does novitec use. if its a n Eaton M112 or the Whiple id say it would be pretty damn awesome. i believe the 360 novitec was pretty disappointing in power out put.
  8. ErikV10
    ErikV10 Formula 3
    Oct 30, 2006
    1,653
    My dad contacted one company (I forgot the name, but he is here on F-Chat). They said 2 certified technicians from Germany would fly out here to install. It takes 4 days and costs ~$55K. Is that worth it?
    The only disadvantage I could think of is that it could shorten the life of the engine like most turbochargers and superchargers do in a car. Other that that, I couldn't think of anything else.
  9. Tarek K.
    Sep 7, 2006
    10,788
    Cairo - Egypt
    Tarek K.
    This was posted before:
    "11. Engine
    Power-optimized ECU's, new adjusted engine electronic controls, modified
    fuel curves, higher rev limiter 8,850 rpm (8,500 rpm stock), 509 hp (490
    hp stock), 348 ft-lbs, +4 mph top speed $5,479
    Performance kit 3, Carbon airbox, two air filters, modified ECU, modified
    fuel curves, higher rev limiter 8,850 rpm (8,500 rpm stock), 513 hp (490
    hp stock), 351 ft-lbs, +4 mph top speed (200 mph) $9,990
    Twin compressor conversion, on-site installation by two NOVITEC Germany
    technicians. Twin superchargers with independent oil system; modified
    and insulated air induction system; water-cooled intercoolers with water
    pumps and additional radiators; reinforced drive belts with dynamic
    tensioners; additional fuel injectors; reprogrammed Motronics, 636 hp,
    465 ft-lbs of torque. 3.7 second 0-60 mph, requires sport exhaust and
    carbon engine panels $55,000"
    http://www.ferrarichat.com/forum/showthread.php?t=159457
  10. 360trev
    360trev F1 Rookie
    Project Master
    Oct 29, 2005
    4,319
    Gibraltar
    360trev
    While I appreciate what your saying regarding main dealer servicing point 3 really is an opinion and not based on any facts, its actually wrong. Also I have heard (at least in Germany) that main dealers where still happy to service (and stamp) the book according to Ferrari specs with no bother - not sure how FNA would take it though.
    The cost of supercharging or turbocharging a 360 runs about $40,000 to $60,000 depending on the sophistication and level of engine changes required by the conversion (such as forged pistons).
    Lets face it these extensively upgraded cars are highly rare and have performance figures close to that of an Enzo (and with a little bit of weight reduction) better power to weight ratios too. I have in all honesty never ONCE seen a converted car sell for less than stock car (this 100% truth), not a single car! Its simply not reality because they are so rare and the power is 50% higher than stock you'll always get interest from enthusiasts - regardless of horror of some purists. It is is however true that you wont get your $60k back but typically your car will be worth what it was + half the price of the conversion. So if your car is worth $100k and you spend $60k you'll like get somewhere around $130k back.
    In some cases owners have simply removed the superchargers before sale and sold the kit for half the price privately. Thats the great thing about the Novitec supercharger kit is that it doesnt require any internal engine work so its just a bolt on. Very easy to remove.
    I would also point out it makes it harder to sell your car but Ferrari's (unless its the waiting list variety) are not that easy to sell privately for cash in the first place so if you want serious hp its not as bad as its being made out to be. A bit pricey bit so is everything else in the world of Ferrari.
  11. 360trev
    360trev F1 Rookie
    Project Master
    Oct 29, 2005
    4,319
    Gibraltar
    360trev
    The only point I'd like to add to this is try to stay away from the body modifications. None of them seem to really gell with the 360/430 and if you do change your alloys keep the originals. Keep the car looking as stealth/original as possible for the best resale values later on...
  12. Tarek K.
    Sep 7, 2006
    10,788
    Cairo - Egypt
    Tarek K.
    I agree 100%
  13. bostonmini
    bostonmini Formula 3
    Nov 8, 2003
    1,890
    upgrade to a scuderia; its cheaper, gives 510 hp; and has a warranty. also a better starting point for serious mods imo.
  14. Tarek K.
    Sep 7, 2006
    10,788
    Cairo - Egypt
    Tarek K.
    You are right :). Already done that today, exactly two hours ago ;).
    But I think I will keep both 430s.
  15. misfit138
    misfit138 Rookie
    Nov 19, 2006
    8
    Good lord.
    Ten Thousand Dollars for an airbox, 2 filters and a hacked ECU.
    Thats some incredible **** right there.
  16. Jas
    Jas Formula 3
    Mar 2, 2005
    1,060
    Kent, UK
    Jas
    IMHO supercharging is FAR superior to turbocharging. Turbos give a "peaky" power delivery, whereas supercharging retains a linear torque curve as engine speed rises.
  17. CHADW
    CHADW Rookie
    Oct 4, 2005
    28
    Sarasota, FL
    Chad
  18. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,615
    The twilight zone
    The Butcher
    Novitec uses centrifugal superchargers, which I am not a big fan of. They do make nice peak numbers up top, but don't help down low. The power curve is nowhere near as flat as a screw-type supercharger will deliver and generally not as good as a turbo either.
    The real plus side is it's a kit and everything is already worked out so the car won't be down very long. If that is not a concern, you could probably do better on both price and performance having a custom system build. I'm currently doing the 3rd supercharger system on my 308. The first was good and made about 360hp, the sencend really good and made about 540hp, the new one should yield about 750hp....hp in an addiction.
  19. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,615
    The twilight zone
    The Butcher
    It really depends on the type of supercharger. All OEM supercharger applications are positive displacement type superchargers (roots or screw type). These types provide boost at all rpm and very wide, usable power. Many aftermarket kits, including Novitec, use centrifugal supercharger because they are easier to package, but they produce a power curve at least as peaky as a turbo, often motor peaky….which is why they are not ever used in OEM applications.
  20. Jas
    Jas Formula 3
    Mar 2, 2005
    1,060
    Kent, UK
    Jas
    I'm referring to the sudden surge of power that turbos tend to deliver in my experience, and the drop off of power at the top end. Superchargers I've tried have not done this.
  21. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,615
    The twilight zone
    The Butcher
    Centrifugal superchargers sure do. A Centrifugal compressor has a fairly narrow rpm operating window, about ½ that of a piston engine, so it simply can not work well over more than ½ a piston engine’s rpm range.
    With a turbo you have 2 choices, you can cover the top ½ and make great power to redline at the expense of any gains below ½ redline. Or you can bring the turbo in at about ¼ redline and cover nicely to about ¾ redline then live with the power dropping as the engine’s needs exceed the compressor’s capacity. 80's turbos chose A, while more recent versions tend to be B and the fancier set-ups are twin turbos that have 1 of each.
    With a centrifugal supercharge the only choice you have is to cover the upper 1/3 of the engine’s power band. The reason is that with a supercharger, the drive ratio between the engine and compressor is fixed, spin the engine faster, the compressor spins faster. The problem however is that while the engine’s air needs are linear with rpm, a centrifugal compressor’s output is exponential with rpm, so you really need a variable drive ratio to make it work right. A turbo with a wastegate or boost controller has a variable drive ratio, but it’s much harder to do with a supercharger, although some have tried over the years.
    All OEM superchargers are positive displacement designs because the output is linear with rpm and therefore a good match to the engine’s needs. So the Ford, GM, Mercedes, Aston Martin, or whatever you may have driven was a positive displacement supercharger and probably worked really well.
  22. MGD416
    MGD416 Formula 3
    Jun 4, 2006
    2,385
    tarek, so unfair, you just get to walk in and get one! :) o well I cannot wait to see your pictures... enjoy and if you do supercharge the f430... well damn that would be pretty wild
  23. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    Generally,
    Superchargers benefit at the lower RPMs while Turbocharger's benefit at higher RPMs.
    Why you would want to consider Turbocharging a high compression ratio engine like the 430 is beyond me, you'll be changing the whole characteristics of the engine especially denying the bottom end.
    Forced induction has enough problems with reliability and slapping a turbo onto an engine like the 430 is borderline mental. Note that aftermarket tuners usually change out internal engine parts to de-stroke the engine prior to attaching forced induction items, but then you're into blasphemous territory.
  24. Tarek K.
    Sep 7, 2006
    10,788
    Cairo - Egypt
    Tarek K.
    That's the benefit of living in a country where demand on Ferraris is low ;).
  25. Tarek K.
    Sep 7, 2006
    10,788
    Cairo - Egypt
    Tarek K.
    I agree to your argumentation. The compression ratio on the F430 engine is too high to be turbocharged.
