Suspension bushings: ES vs Superformance | FerrariChat
Discussion in 'Boxers/TR/M' started by Prova85, Nov 8, 2018.
  1. Prova85
    Prova85 Formula 3
    Nov 13, 2003
    1,993
    So. Shore MA.
    Kenny K
    Restoring my suspension this winter and debating whether to go with Energy Suspension poly bushings or the up-rated Superformance bushings. Any thoughts or experiences, pro or cons with either?
  2. xplodee
    xplodee Formula 3
    Jan 3, 2017
    1,101
    Allentown, PA
    Tim
    TR or Boxer?
    Could you elaborate on what other parts you will replace during the process of restoring the suspension?
  3. ago car nut
    ago car nut F1 Veteran
    5,246
    Madison Ohio
    David A.
    I would personally stay away from aftermarket stiff bushings! They pound out the chassis mountings.
    Testarossa Sean likes this.
  4. Prova85
    Prova85 Formula 3
    Nov 13, 2003
    1,993
    So. Shore MA.
    Kenny K
    See avatar. Replacing shock mounts and the other shock rubber bits. Refurbing the Koni's and control arms.
    Just wondering if anyone has run into any problems or fit issues installing the ES or Superformance pieces. Did a bunch of searching here and the 308 forum and didn't see anything glaringly negative.
  5. wda24729
    wda24729 Formula 3
    Sep 22, 2014
    1,000
    Devon, UK
    Graham
    Ive used the standard Superfromance bushings on my 348, 308 and 400 all with positive results. I will also do the same for my TR when it comes to the time.
    Prova85 likes this.
  6. jgmblair
    jgmblair Formula Junior
    715
    Winnipeg, MB Canada
    Jeff Blair
    Hey Kenny would be nice to see you start a post while you tackle this job and post a bunch of pictures, good luck.
  7. Ludwig
    Ludwig Formula Junior
    Mar 27, 2006
    307
    Redmond WA
    Ludwig Allegra
    Prova85 likes this.
  8. Prova85
    Prova85 Formula 3
    Nov 13, 2003
    1,993
    So. Shore MA.
    Kenny K
    Jeff, the job was pretty well documented in this thread from a few years ago. https://www.ferrarichat.com/forum/threads/aussie-testarossa-rebuild.366206/
    Lots of threads in the 308 section about the ES bushings. No real downsides to poly. The Superformance are a high quality rubber. After a lot of thread reading I've concluded you can't go wrong with either. It's a toss up for a street car.
  9. Prova85
    Prova85 Formula 3
    Nov 13, 2003
    1,993
    So. Shore MA.
    Kenny K
    Think I'm going with the Superformance units. Found this tidbit below about OEM's being a bonded bush as are the Superformance. And also read that in Rifledriver's experience good rubber will out last poly and that rubber bushings will never develop any sort of squeaking that poly can. The ES bushings are not bonded like Superformance:
  10. jjeffries
    jjeffries Formula Junior
    Sep 4, 2012
    250
    Connecticut
    John Jeffries
    Ludwig, that's a very cool photo of your car in heavy-maintenance mode.
    Prova, I remember reading Steve Dinan saying something similar to Rifledriver's explanation, probably twenty years ago. I think poly bushings generally yield pretty horrid results. John/CT.
  11. pshoejberg
    pshoejberg Formula 3
    1,694
    Denmark
    Peter H
    I have always used the SF bonded rubber bushings with success. Nice tight ride and still comfortable and used by most I know for regular road driving. Highly recommended.
    Best Peter
