348 - Suspension Bushings | FerrariChat
348 Suspension Bushings
Discussion in '348/355' started by John Glen, Jun 23, 2020.
  1. John Glen
    John Glen Formula Junior
    Dec 30, 2009
    478
    Victoria, B.C, Can.
    John Glen Wesanko
    Just thought I would ask the experts about how best to remove and replace suspension bushings. Is there a special fixture or a homemade tool that can support the suspension arm while applying pressure with a press ? I notice the new bushings have flats on the inboard end where as the original ones do not ? Do I have to cut the old bushes ? Thanks for any help, JGW
  2. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    12,661
    San Carlos, CA
    Mitchell Le
    This is one of the more awkward job even for a press. The A arms can be large and not fit that well into the press. You will have to be very creative. What you need to do is
    1. Use a sawzall and cut the two ends off the bushing.
    2. Then drill out the center shaft or push it out.
    3. Remove the rubber portion of the bushing surrounding the center shaft.
    4. Then use the sawzall to cut a slit length-wise into the outer shaft of the bushing to relieve its pressure.
    5. Grind off the two spot welds attaching the bushing to the A arm
    6. Hammer out the outer bushing skin.
    7. Reverse the process this time use a press or a high quality bench vise, and finish with two spot welds on the new bushing to the a arm again
    I noticed that freezing the new bushings the night before does make it a little easier to install, just a little. Do take picture of the A arm and orientation of the bushings before you remove anything. You won't remember how they go back together without notes.
    So welder, sawzall, bench vise, cheater bar, press, grinder, and creativity.
  3. 348Jeff
    348Jeff Formula 3
    Oct 25, 2011
    1,500
    Jeff
  4. QSA
    QSA Formula Junior
    302
    Kingwood, TX
    Quinn
    Here are a couple of resources that will help with methods of install/removal.
  5. Ferrarium
    Ferrarium F1 Veteran
    5,631
    Central NJ
    Eric
    SoCal1 likes this.
  6. A348W
    A348W Formula 3
    Jun 28, 2017
    1,748
    North Wiltshire, UK
    As Jeff says above.
    I did mine in a similar way with a big bench vise.
    other difference was in removing the old bushes I didn’t drill the rubber; I just burnt it out with a hand held blow torch and the inners just fell out.
    Sod of a job, so worth while asking your local Ferrari specialist how much they would charge. (Make sure they know what they are doing!). Either for the entire job or to take the arms and bushes in and get them to swap them over.
  7. yelcab
    Nov 29, 2001
    12,661
    San Carlos, CA
    Mitchell Le
    I really do not want to rain on this parade but these two methods are worthless when it comes to the Ferrari control arms. The first one is useless because the Ferrari A arm has cross braces that impede access to the press, and the second one is worthless because the Ferrari bushings are welded on and there is no gap for the chisel to fit in.
    This job is really a big and nasty job best left for someone who is a very serious and well equipped DIY or for the professional mechanic.
  8. Ferrarium
    5,631
    Central NJ
    Eric
  9. QSA
    QSA Formula Junior
    302
    Kingwood, TX
    Quinn
    I see no issue with using an air hammer to remove all the control arm bushings. They have metal ends and can be pushed out through the backside. I have an arm on my bench now and will give it a go and report back.
    I also don’t see an issue of access with installing with a press. Fundamentals should all be the same. Will report back on this as well.
    As far as the bushings being welded on, I’ll have to go take a look. I did not notice that when I pulled the control arm.
  10. Ferrarium
    5,631
    Central NJ
    Eric
    If you cut the flange end off with a saws all you can push the pushing from either side on a press easily. Just need a mandrel the right size is to press on the same OD as the bushing sleeve (I suspect a chrome plated 1" socket will work.) and a backing mandrel.
    As such.
  11. Ferrarium
    5,631
    Central NJ
    Eric
  12. 97 Spider
    97 Spider Formula 3
    2,241
    Texas
    Brian
    I just did mine, what a giant pain. They made a revision on 355 arms to give a lip to press against. You can get 355 bushings out in minutes, 348 not so much, same as early Diablo I did, the engineers had no thought for the guy who had to replace them in the future. Image Unavailable, Please Login
    ShineKen likes this.
  13. yelcab
    Nov 29, 2001
    12,661
    San Carlos, CA
    Mitchell Le
    All suspension bushings from the GT4 to the 328 including the one I did yesterday all had spot welds holding the bushing to the A arm. It's been a while since I did the 348 so I can't remember if it had spot welds. Nevertheless, it's still a pain of a job. Good luck to you DIY guys to tackle this.
  14. Pangea
    Pangea Formula Junior
    Mar 27, 2011
    442
    Nick
    Mine weren't spot welded.
  15. John Glen
    Dec 30, 2009
    478
    Victoria, B.C, Can.
    John Glen Wesanko
    Thanks for all the help. Yes it is a nasty job on a 348......will report when I have completed, JGW
  16. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,562
    SoCal LA/OC/New Mexico
    Tim Dee
    I use mine all the time works great, not a HF one but quite similar. even makes truck ball joints an easy job
