Suspension Control System Failure on a 458 | FerrariChat
Discussion in '458 Italia/488/F8' started by Chadly, Oct 21, 2018.
  1. Chadly
    Chadly Formula Junior
    Mar 21, 2010
    294
    Bothell, WA
    Chad
    Doesn't look like there is any answers to this on the forum. My car started doing this yesterday and I can't get it to go away. I put a new battery in it yesterday as I saw someone said that cured the problem on a California. Anyone have this problem on their 458 and how did they remedy it?
  2. Baitschev
    Baitschev Formula Junior
    Jan 8, 2017
    262
    Vienna
    #2 Baitschev, Oct 23, 2018
    Image Unavailable, Please Login I had the same Problem
    Solution was a defekt connector on the Suspension damper cost only 25€
    It is a selfresetting system.so Check all conectors remove it at the top of the Suspension damper.
    Disconnect the wirecable.messure lnside middle socket to wireside.0 Ohm.
    If you have more Ohm,replace this connector.
    LVP488 and Chadly like this.
  3. Rory breaker
    Rory breaker Formula Junior
    Apr 17, 2017
    270
    Is this a DIY (IE a couple screws, nothing wild) or is this intensive?
  4. Baitschev
    Jan 8, 2017
    262
    Vienna
    To Check all 4 Suspension damper 2 Hours
    The wheels has to be removed.
    First clean all connectors with Gold 2000 Spray.
    Plug it on and Start engine .if fault is cleared .take a testdrive in all modes
  5. Rory breaker
    Apr 17, 2017
    270
    So once you remove the wheels you can see the connectors easily while the car is on a lift/jack Stands? Just reach in and unplug, or work to be done?
  6. Baitschev
    Jan 8, 2017
    262
    Vienna
    Take an experienced mechanic man to help you
    Its better belive me.pay him 200 and 4 coffees have fun.
    Ask Dealer perhaps they can readout the defekt Suspension side.so you have only remove only one Wheel to Disconnect and Check .
  7. Rory breaker
    Apr 17, 2017
    270
    It seems to be intermittent - comes and goes, is that normal? Maybe the battery is getting low triggering the error?
  8. Baitschev
    Jan 8, 2017
    262
    Vienna
    In the connector is an Electronic circuit board.i think one Söldner joint is broken.so If you drive over bad roads or the vibrations of engine is enough for this issues.
    Dont Write .start working,Start working,
    Start working and Write us your Solution.
  9. Baitschev
    Jan 8, 2017
    262
    Vienna
    Image Unavailable, Please Login You can See the wire in the upper Position that you have to Disconnect cleaning or replacing Suspension connector
    Best regards Alois
  10. vincep99
    vincep99 Formula 3
    Jun 8, 2009
    1,939
    Alois,
    Thanks for posting! This will be a big help to us all
  11. up4speed
    up4speed F1 Rookie
    3,660
    Long Island, NY
    Chris
    I'm curious to hear the fix, and if it's easy to do your self.
