Suspension information required | FerrariChat
Discussion in '206/246' started by LeoDino, Sep 12, 2023.
  1. LeoDino
    LeoDino Rookie
    Sep 2, 2010
    35
    Germany
    Georg
    Hi 246 experts,
    please have a look on the photo attached. As you can see there, the upper wishbone is not held by the “U bolt fork”. Instead, the fork is welded on the frame. It seems to be original. No traces of DIY modification. No holes in the frame behind the fork. Welding is Ferrari style.
    In the spare parts catalogue, instead, both lower and upper wishbones are being held by adjustable U bolt forks.
    Any idea why this 246 is different?
    Thank you in advance
    Georg Image Unavailable, Please Login Image Unavailable, Please Login
  2. TonyL
    TonyL F1 Rookie
    Sep 27, 2007
    4,202
    Norfolk - UK
    Tony
    Later 246 top suspension pick ups were welded, lower are adjustable by shims for camber adj..
    Upper and lower Ball joints are also adjustable with shims for castor setting, be sure to put them back as you found them or get the suspension fully aligned once finished
    Nuvolari likes this.
  3. LeoDino
    LeoDino Rookie
    Sep 2, 2010
    35
    Germany
    Georg
    Tony, thank you very much, that is very helpful.
    Georg
  4. LeoDino
    LeoDino Rookie
    Sep 2, 2010
    35
    Germany
    Georg
    PS: Tony, do you know, starting what VIN, this modification came into effect?
    Georg
  5. TonyL
    TonyL F1 Rookie
    Sep 27, 2007
    4,202
    Norfolk - UK
    Tony
    Not sure
    this service bulletin may be helpful later!
