Suspension re-build | FerrariChat
Suspension re-build
Discussion in '308/328' started by RWDOMKR, Jul 14, 2007.
  1. RWDOMKR
    RWDOMKR Karting
    Aug 18, 2004
    97
    Stockton, CA USA
    RWDOMKR
    '75 GT 4 #10448 - I'm getting ready to go thru the suspension and I'm looking for some cross-references on all of the rubber. I am also going to be rebuilding / replacing the rack & pinion as well as the outer tie-rod ends...suggestions??
    Many thanks!
  2. carb308gtb
    carb308gtb Karting
    Oct 20, 2006
    188
    Svezia
    Patrik
    I bought mine parts from UK, http://www.superformance.co.uk
    Fast delivery and good prices, well I bought more things for the engine also.
    /Patrik
  3. maurice70
    maurice70 F1 Rookie
    Jan 25, 2004
    4,334
    maurice T
    Yes Superformance does have everything.You will need 16 A'arm bushes-either go with the original that need to be tack welded in or you can go with the ES type(do a search on these)You can get the originals from Superformance or there is a guy on Ebay that sells them for cheap.There is also another guy who is selling steering rack rebuild kits on Ebay as well.You will also need 8 suspension bushes(if you have the original Koni shocks then I suggest to replace them as well).You will need new sway bar bushes front and back
