suspension | FerrariChat
suspension
Discussion in '458 Italia/488/F8' started by Bluem5, Jun 23, 2020.
  1. Bluem5
    Bluem5 Rookie
    May 31, 2020
    20
    hi, new to the ferrari world with a 2011 458.
    i couldnt find any info in relation to suspension in the discussions page
    i noticed there is significant amount of squeal coming from the suspension at low speeds, especially going through bumpy roads or speed bumps
    is there something that can be done without changing to aftermarket ones? can the dealer do something to improve it without charging an arm ?
    thanks in advance
  2. Viperjoe
    Viperjoe F1 Rookie
  3. Bluem5
    Bluem5 Rookie
    May 31, 2020
    20
    About 7.5 k miles on the 2011
  4. RayJohns
    RayJohns F1 Veteran
    7,860
    West Coast
    Ray
    In some cases that squeaking noise can be coming from bushings that are dry and/or a failing shock. You might try removing the tires and/or get under the car and spray some Silicone into those areas and see if that helps. Even if it doesn't, it's good for the bushings and rubber stuff under there.
    If it's a shock that is failing, sometimes Silicone on the piston rod can help, but not always.
    It's worth a try though.
    Ray
  5. Bluem5
    Bluem5 Rookie
    May 31, 2020
    20
    Thanks for that, car just came back from service and I requested them to have a look at the bushings to have it cleaned. They re greased it as well but somehow the small squeaks are still evident
    Hopefully will become less in the coming days
