355 - Switch modification. | Page 3 | FerrariChat
355 Switch modification.
Discussion in '348/355' started by radback, Jan 14, 2023.
Tags:
  1. radback
    radback Formula Junior
    809
    France
    I think both + go to relays that control solenoids.
    Actually I will connect my OEM switch between the control unit (that sending currents) and the box were all tank compressor and valves are installed.
  2. Qavion
    Qavion F1 World Champ
    14,664
    Ian Riddell
    I think the LED backlighting is going to cause issues. If the LED is in the circuit normally, the light won't work (if you set up the wiring like this)....
    If you reversed the LED, it should work (if you add an earth circuit):
    I haven't opened up one of these switches to see if the LED is easily reversible? Maybe ask one of the sticky switch experts?
    radback likes this.
  3. radback
    809
    France
    Thanks a lot for your help, but it seems too complicated for me. I guess I need to seek a local car electrician to help me.
    Last system I built, I used a windows switch from a Civic from the 80s and it was much more simple than that.
    I'm lost here. :)
    Qavion likes this.
  4. radback
    809
    France
    I tried the switch with a fob battery and some wires just to see.
    I only managed to light the switch and, while moving the switch UP (or DN, don't remember) it cuts the 10v that the switch is continuously sending to one pin.
    As is,I'm afraid this switch is useless for my need. :(
    Is there any other momentary switch that could be more appropriate for my use?
    Window control one seems to work exactly the same.
  5. Qavion
    14,664
    Ian Riddell
  6. radback
    809
    France
    Well...
    I guess I'll have to use the switch from the kit then.
    Doesn't look as good, but at least it could be fitted where I want:
    (not my car)
  7. 308 GTB
    308 GTB F1 World Champ
    11,758
    New Jersey
    Barry Wolinsky
    Spray the switch flat black and it will look just fine.
  8. redwedge
    redwedge Formula Junior
    Sep 30, 2012
    493
    London
    Steve C
    Put the switch somewhere it can't be seen, but can be easily accessed, like under the edge of the dash.
  9. radback
    809
    France
    I went to see my electrician and you were spot on about the solution.
    He did exactly what you said: sold the led the other way and adding a small relay to invert polarity.
    Now, I need to change the logo for the F50 lift one... :rolleyes:
    Qavion likes this.
  10. Qavion
    14,664
    Ian Riddell
    Not sure why you’d want to reverse the polarity with relays.
    Is the system triggered with an earth or a voltage?
  11. radback
    809
    France
    This is to get this switch light on with the others, I have to pick-up the + from another switch and send it thru the relay that will change it to earth and go to pin 3 on the switch.
    Last wire from relay goes to earth.
    Here is a pic of the relay:
    Qavion likes this.
  12. Qavion
    14,664
    Ian Riddell
    Not sure I completely understand. I think I'd need a diagram for this. I understand that you want your switch light to come on with your exterior lights, but I'm not sure how you're going to isolate your switch internal light circuits from your switch internal switch contacts (using a standard Ferrari switch).
  13. radback
    809
    France
    Sorry, as you might have noticed, I'm not at top level regarding electrical internals ;)
    So I've no idea how this relay is inside.
    All I know is that the guy soldered the led other side and gave me this small relay and the way to connect everything.
    Relay receive + for light from another switch of the console.
    One wire goes out the relay to earth, another wire out of relay is connected to the pin 3 of the switch.
    Then switch receive + (from ignition key contact) on pin 4 and earth on pin 5.
    Then, when switch is activated it is sending + on pin 1 or 2.
    This is pretty much the same diagram you posted before except one wire from relay:
  14. Qavion
    14,664
    Ian Riddell
    So I guess something like this...
    I'm just wondering what circuit is inside the lift controller (on the DOWN pin). With the ignition on, you have ignition volts going through the LED, through the un-pushed "down" switch straight to the Lift ECU. Is the current flowing through the LED small enough NOT to activate the down signal (with the light relay NOT activated).
    Follow the pink line....
    radback likes this.
  15. radback
    809
    France
    I guess I'll have to ask this question to my electrician.
    I'll let you know what he'll say.
    Qavion likes this.
  16. radback
    809
    France
    Yes, that's what he's thinking.
    By the way, I made a mistake in the previous diagram.
    There is no need of earth at pin 5.
    Here is the correct one:
    I'm going to start the installation of my lift kit, and then, I will do the install of this switch with the guy to be sure everything is as it's supposed to be.
  17. Qavion
    14,664
    Ian Riddell
    Possibly. Some relays do have earths on unsued terminals. Perhaps it's part of the fault diagnostics for more complicated systems, but if it's not mentioned in the installation guide, then no need to worry.
  18. radback
    809
    France
    308 GTB and Qavion like this.
  19. 308 GTB
    11,758
    New Jersey
    Barry Wolinsky
    That switch says it all.
  20. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
    I did all mine in blue including all switches and heater controls
    In this pic the heater was not done yet
    I just had a drivers window switch fail but I got over 10 years out of it.
    Can not find my thread because I think it’s in the other ferrari forum
    Need to figure out again so I’m searching now for the details of what I did
  21. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
    Yes they are because when is was building mine they had to be soldered in the correct polarity
  22. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
    I just unsoldered and soldered in new blue led
    Also the dimmer switch works but not as good because they dim quicker and shut off about half or so
    This is ok though if like me you do them all as they are relative to each other
    Qavion likes this.
  23. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
    If you buy the led bulbs for the dash from ‘super bright led” they come with resistors and brackets and are plug and play
  24. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
  25. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
    In this next pic it shows the correct orientation for one of the window switches
    The led is at the top of the switch and if it is you would mount the led with the missing bottom left corner as shown below
    this screen shot shows the bottom left triangle of the led smd needs to go as shown
    Top from picture above would be mounted to top of the window switch
