switch removal | FerrariChat
switch removal
Discussion in '348/355' started by 4respy, Jan 23, 2016.
  1. 4respy
    4respy Formula Junior
    Aug 15, 2014
    601
    los angeles
    steve
    How can I remove switches without damage?.. I Have tried, but seems like it does not want to give...
  2. marioz
    marioz Formula 3
    Nov 21, 2003
    2,025
    Cedar Mills,Ontario
    Mario
    What switches & on what car?
  3. 4respy
    Aug 15, 2014
    601
    los angeles
    steve
    355 Spider ..seat switches.. i would imagine same as a lot of the others as far as how they are connected
  4. 4respy
    Aug 15, 2014
    601
    los angeles
    steve
    I take it nobody knows.. Which I feel somebody could easily let me know, This Forum is really great help?
  5. S-T48
    S-T48 Formula Junior
    575
    Stevenson Ranch, CA
    Be patient, provide more details and possibly a picture (-;
  6. Shootfighter65
    Shootfighter65 Formula 3
    May 13, 2014
    1,372
    Charleston SC
    Randy..alluneedtokno
    Chill. Maybe you should try patience
  7. 4respy
    Aug 15, 2014
    601
    los angeles
    steve
    #7 4respy, Jan 24, 2016
    Im trying to chill, but my car seat is stuck in the far up position (would go forward but not back.). i can not even get into car let alone drive and it is outside right now, so sorry but I just would like to switch my passenger switch to drivers..All these toggle switches must connect the same way
  8. PhilB
    PhilB Formula 3
    Feb 17, 2004
    2,339
    Southern New Jersey Shore
    Phil
    Remove the ashtray. Then the side mirror switch. Then pop the switches out from underneath or remove the whole tray they sit in.
  9. 4respy
    Aug 15, 2014
    601
    los angeles
    steve
    Thanks,but I had that part out already.. im talking about removing switches from connector
  10. drbob101
    drbob101 F1 Rookie
    Nov 26, 2012
    3,821
    Tinton Falls, NJ
    Bob Ferraris
    There's release tabs on the sides of the connectors. Just squeeze them and pull the connector off the switch.
    I'll see if I can find a pic. I changed my surround and had it apart.
  11. 4respy
    Aug 15, 2014
    601
    los angeles
    steve
    Thank You Bob!
  12. 285ferrari
    285ferrari Two Time F1 World Champ
    Sponsor
    Sep 11, 2004
    20,973
    MD and NE
    Robbie
    Sometimes they are VERY tight also, may need to pry a bit with screwdriver
  13. 4respy
    Aug 15, 2014
    601
    los angeles
    steve
    Thanks Robbie!
  14. 4respy
    Aug 15, 2014
    601
    los angeles
    steve
    Well its not the switch..Maybe the motor..What a *****!
  15. Qavion
    Qavion F1 World Champ
    14,447
    Ian Riddell
    If it ran forward, then maybe it's not the motor. Unfortunately, there are no readily available wiring diagrams for the Spider, so I don't know if there are computers, relays or what controlling the seats. Have you tried moving the roof to various positions to see if that affects the operation of the driver's seat? Something might be out of sync.
    Cheers
    Ian.
  16. phrogs
    phrogs F1 Veteran
    7,352
    Kzoo Michigan
    Just disconect the battery before using the screwdriver.
  17. 4respy
    Aug 15, 2014
    601
    los angeles
    steve
    Thanks Ian, I will check that, But there are Two motors for the seat I believe
  18. 4respy
    Aug 15, 2014
    601
    los angeles
    steve
    I did that, But thanks regardless!!
  19. Qavion
    14,447
    Ian Riddell
    That would be very inefficient, Steve. Usually, motor phases/polarities are reversed to make them run in different directions.
    The parts diagram shows two motors (but only to show the parts breakdown more easily)
    SEATS AND SAFETY BELTS -VALID FOR SPIDER- - Ricambi America, Inc.
    Cheers
    Ian.
  20. 4respy
    Aug 15, 2014
    601
    los angeles
    steve
    Thanks Ian, I think i must have been thinking of another seat that I remember seeing two motors on..My aftermarket mats that I just Put in got stuck under seat around when this all happened..
  21. 4respy
    Aug 15, 2014
    601
    los angeles
    steve
    I thought originally it was the switch,,When I went to move back made no sound and could feel power to seat, unlike when i try to move it forward
  22. Enzojr
    Enzojr F1 World Champ
    Dec 12, 2013
    14,001
    West of PDX
    Tomy
    So you got the mats out and all is well ?
    ...and the seats also work ?
  23. 4respy
    Aug 15, 2014
    601
    los angeles
    steve
    I got the mat out, but seat still does not move back
  24. phrogs
    phrogs F1 Veteran
    7,352
    Kzoo Michigan
    some don't and I have forgotten before. Those sparks get your attention.
  25. phrogs
    phrogs F1 Veteran
    7,352
    Kzoo Michigan
