Switch to Synthitic Oil? | FerrariChat
Discussion in 'Technical Q&A' started by Futureman, May 7, 2009.
  1. Futureman
    Futureman Formula 3
    May 16, 2007
    2,024
    My 328 currently is running with Castrol GTX 20-50. That's what the original owner has always used. So when I bought it 2 years ago, I just kept using the same. I've been considering switching to synthetic, but just haven't pulled the trigger. Two questions:
    1. What's the procedure when switching to synthetic? Seems I remember reading that you need to drain the old oil, put in synthetic, run the car for a specified time (?) and then drain and replace with fresh synthetic. Is this correct? Are there more details and specifics to this?
    2. I'm taking the 328 to the track for the first time next month, which is why I'm changing the fluids (among other things...don't get me started). Is synthetic going to be that much more beneficial in a track environment? Per Brian and Dave's recommendations, I'm going with Redline (so don't start selling your oil of choice...it's Redline...period). Is there a better Redline oil weight for track use? Obviously, it will get changed when I return.
  2. GCalo
    GCalo F1 Veteran
    Sep 15, 2004
    7,645
    Northern California
    Greg Calo
    Good thing to do. It takes a while to rid the standard oils. So after first change maybe after a few thousand miles change again.
    Very good oil choice. Don't know specifically what's best for the 328 but I use 5W40 Redline in my 360.
  3. irondogmike
    irondogmike F1 Rookie
    Sep 8, 2006
    2,532
    San Diego area
    Michael Tucker
    I use redline 5/30 in my 308qv
  4. ZiFF
    ZiFF Formula Junior
    Mar 30, 2009
    323
    Synthetic is fully compatible with non-synthetic. Just change it, and run it to your normal interval.
  5. gidge348
    gidge348 Formula Junior
    Dec 12, 2008
    343
    Perth West Australia
    Ian Wood
    Not sure of the mileage on your 328 but I have noticed in other cars that I have changed from mineral to synthetic with higher mileage that oil consumption rises quite quickly.
    May possibly be worth looking at a semi synthetic?
    Either way talk to your Redline rep I have found them very good with info.
  6. hacker-pschorr
    hacker-pschorr Formula Junior
    Sep 27, 2006
    584
    Land of Lambeau
    The motorcycle guys will neer use synthetic oil - this has been well known for years:
    Subject: Beware synthetic oil
    Beware of synthetic oil, it can do terrible things to you and your beloved motorcycle. It will not only leak out of your engine faster than you can put it in, but it will also cause your oil filter to clog and implode, dumping debris and dirt into your lubrication system. It also will make every part of your bike permanently slippery because of its linear molecular chain dispersion action. Then it will leak onto your kickstand causing it to retract automatically, dropping your bike on the ground! But that's not all...
    Synthetic oil will round off your gears and spin your bearings. It will also splatter onto your seat causing your girlfriend to fall off in the apex of a turn and she'll never ride with you again. Synthetic oil coats your sight window and your timing window with a whitish pro-emulsification additive that is both non-removable and highly corrosive. Synthetic oil will completely leak onto the ground overnight and your dog will drink it and die.
    Synthetic oil will wear out your tires and make your battery leak. It will give you the desperate need to urinate after you put your full leathers on and then jam your zippers shut. It will contaminate your gasoline causing your bike to stall on railroad tracks and accelerate uncontrollably near police cars. It will make it rain during rallies and on weekends. It will lubricate four timing belts causing them to jump teeth and break your valves to bits. Synthetic oil chemically weakens desmodromic valves and causes the clearances to change every six miles. Then it melts the black soles of your riding boots night before you walk across your new carpeting.
    While riding past groups of attractive women it will cause both of your handlebar grips to slip off at the same time so you smash your windscreen with the bridge of your nose. It also causes your swingarm to crack, your studs to break, and your rotors to warp, and then it voids your warranty by changing your odometer reading to 55,555. It also dries out your wetclutch and wets your dryclutch. It makes your clutch slave cylinder seal fail in the heaviest traffic on the hottest day of the year while putting an angry wasp in your helmet for good measure.
    Synthetic oil hides your 13mm socket and puts superglue on your earplugs. Synthetic oil will scratch your faceshield and make your gloves shrink two sizes night before trackday. Synthetic oil stole your neutral and sold it to the Chinese for $1.25. Synthetic oil will make you grow a tail.
  7. Rifledriver
    37,288
    Yup, as per federal law.
    No special measures needed. just drain and refill.
  8. Futureman
    Futureman Formula 3
    May 16, 2007
    2,024
    Brian, seems like I remember you or Dave Helms saying straight 30w for the track and 5w-40 for everyday use on a 328. Am I remembering this correctly or is my CRS disease acting up again? (CRS - can't remember sh*t)
  9. h00kem
    h00kem Guest
    Dec 15, 2004
    734
    Texas
    ...not another oil thread !@#$##^%$. Ok, how about Mobil 1 (that comment ought to get the thread really going!).
  10. bpu699
    bpu699 F1 World Champ
    Dec 9, 2003
    17,805
    wisconsin/chicago
    bo
    drip...drip...drip...
  11. Iain
    Iain F1 Rookie
    Jan 21, 2005
    3,350
    #11 Iain, May 7, 2009
    30W is lighter than 40W at operating temp so if anything you'd go to a 50W for the track because it will cope with higher temps (as I understand it). Anything W40 seems to be the right kind of thing for general use.
    0W40 would be better than 5W40 which would be better than 10W40 because the lower the first number the lighter at cold temps meaning it will get up round the engine faster at cold start (which is when a lot of wear takes place).
    20W50 will be quite thick at cold and stay thicker until you get the thing really warm. Personally I think its too thick at cold and hot for normal use. Probably gives great oil pressure though! However, high oil pressure is not the end-all and be-all. Oil flow volume/throughput is arguably more important.
    Easiest available 0W40 synth I know of is Mobil 1 & I've just dumped 9 litres (near enough) of it in my 328 (after using Castrol Magnatec 10W40 for years). No leaks yet but then I havn't actually driven the car since I changed it! :)
    You can never get all the old oil out, there is probably 1/2 a litre at least gets stuck in the oil cooler because (at least on my car) the bottom oil cooler hose rises up out the cooler before it meets the block and oil won't drain uphill!
  12. Rifledriver
    37,288
    I use 5-40. If it was to be run really hard at the track and I was seeing oil temps getting over 250 or so I would go to a 50.
  13. cmt6891
    cmt6891 Formula 3
    Feb 25, 2008
    1,340
    Encino, Ca
    Carl T
    The seals and gaskets on 3X8 cars don't agree well with synthetic oils....too much leakage.
  14. hardtop
    hardtop F1 World Champ
    Jan 31, 2002
    11,298
    Colorado
    Dave
    Futureman,
    You need to get that mud out of your motor. It does not protect well at startup. You will notice your manual calls for 10-40. Ferrari changed from 50 weight to 40 weight at some point during 328 production although there were no changes in the motors. Oils have improved greatly. I have used mobil 1 0-40 in my 328's for years. The thinner it is at startup, the better. Typically, you will get about 80-85% of the oil in the motor out in an oil change. When I got my "replacement" 328 last year, the previous owner had 10-50 in it. Since it was very fresh, I changed the oil, but not the filter, then ran it for another 300 miles and changed the oil and the filter. That way I figure I have at least 95% of the new stuff.
    Dave
  15. f308jack
    f308jack F1 Rookie
    Jun 7, 2007
    4,300
    Cape Town, South Afr
    Jack Verschuur
    I don't know anyone here who is NOT running a full synth in their 3X8's, and it doesn't seem to be a problem at all.
    Mine has been running on synth for many years, no leaks (knock on wood)
  16. parkerfe
    parkerfe F1 World Champ
    Sep 4, 2001
    12,887
    Cumming, Georgia
    Franklin E. Parker
    Ferraris in that era including the 328 came with a blended oil from AGIP. That being said, I am using Brad Penn dino oil in my BB512i and have been well pleased.
  17. pks41805
    pks41805 Formula 3
    Aug 4, 2007
    1,152
    Colorado Springs, Co
    Paul Sloan
    Will synthetic oil work with the case seals in older cars?
  18. bill brooks
    bill brooks F1 Veteran
    6,081
    waynesburg,pa
    bill brooks
  19. Futureman
    Futureman Formula 3
    May 16, 2007
    2,024
    My take on the whole "synthetic oils leak" is that if you've got an oil leak of any kind then something is wrong with your seals/gaskets. Either poor quality, poor installation, or both. A synthetic oil in and of itself shouldn't be the sole cause of an oil leak.
    But then what the hell do I know, I can't even spell "synthetic" correctly. So feel free to mock me.
  20. bill brooks
    6,081
    waynesburg,pa
    bill brooks
    notice i abbreviate a lot. also i scribble words i can't spell.
    just like doktahs...
  21. f308jack
    f308jack F1 Rookie
    Jun 7, 2007
    4,300
    Jack Verschuur
  22. GCalo
    GCalo F1 Veteran
    Sep 15, 2004
    7,645
    Northern California
    Greg Calo
    I love this response. It's genuine and definitely not synthetic!!!
  23. Glassman
    Glassman F1 World Champ
    No synth for me. Castrol 20 50 only.
  24. Glassman
    Your absolutely correct, but what do you do? Replace all the seals because you want to run synthetic? I won't.
  25. Futureman
    Futureman Formula 3
    May 16, 2007
    2,024
    Yes, I will. But then, I'm just that anal. I'm itching for a reason to pull the engine. Twisted, huh?
    I can't even begin to tell you how much it's driving me crazy that I screwed up the spelling on the thread topic, and FChat won't let me fix it. That's the level of "freak" that I am.
