Switch to Synthitic Oil? | Page 2 | FerrariChat
Discussion in 'Technical Q&A' started by Futureman, May 7, 2009.
  1. Iain
    Iain F1 Rookie
    Jan 21, 2005
    3,352
    At the very least you should consider changing that to 10W40 (5W40 or even 0W40 would be better still) - 20 50 is just too thick at startup (so you will be seeing increased cold engine wear rates) and unless you do a lot of extreme high speed running in a hot climate its arguably too thick at the top end too.
    If you run lighter oil and your engine starts burning it, well then it probably should be on its way to the rebuilders anyway in due course.
    You might expect to see a drop in oil pressure, but that's OK because the oil flow rate will be much higher.
  2. hardtop
    hardtop F1 World Champ
    Jan 31, 2002
    11,298
    Colorado
    Dave
    I've never had an issue with leaking using synthetics (1 QV, 2 328's).
    Dave
  3. f308jack
    f308jack F1 Rookie
    Jun 7, 2007
    4,300
    Cape Town, South Afr
    Jack Verschuur
    Are there any changes in the composition of seals on the 308? And if so, when were seals introduced to withstand synths?
  4. Tahoe Guy
    Tahoe Guy Karting
    Jan 16, 2006
    176
    Vancouver, WA
    Alexander Everhart
    Man if the Italians were really smart they would figure out a way to use olive oil in the Italian cars. Wouldn't that be awesome or what? LOL.
  5. tazandjan
    39,312
    I love a serious oil thread. Great comments.
    Most people do not seem to realize a 20W-50 conventional oil is a 20W oil with viscosity enhancers to make it act like a 50 weight when warm. Until those viscosity enhancers break down. Then you have a heavy weight oil at start (20W is way too thick) and a lightweight oil (unknown viscosity way less than 50 weight but hopefully more than 20 weight) when hot.
    A 5W-40 synthetic (I looked up the spelling Futureman) is a 40 weight oil when hot that flows like a 5 weight when cold. Big difference. Thank you, Dr Haas.
    Taz
    Terry Phillips
