Switching from 911 to 488, need advice | Page 2 | FerrariChat
Discussion in '458 Italia/488/F8' started by RogerWang, Apr 5, 2023.
Tags:
  1. stretchgeneral
    stretchgeneral Formula 3
    1,419
    MA/TX
    McK
    One of my residences is in a high rise building. The parking garage sounds similar to yours. The parking spaces near the A/C condensing units usually have a duplex needed for maintenance. See if you can reserve or park near that spot and you can run your trickle off that duplex. That is what I do. I had to get them to relocate my reserved spots to that location.
    430jm likes this.
  2. boostedt0y
    boostedt0y Formula Junior
    Dec 25, 2014
    774
    Bay Area, CA
    depends on the Porsche. I have a 73 911 and a 964 as well as a scud. The 911s seem to get similar attention as the scud. My old 997 gt3 did as well. Being that all my 911s are/were red and modified might have garnered the attention though :)
  3. 430jm
    430jm Formula Junior
    Jun 11, 2017
    443
    Atlanta
    My 458SPIDER has recently required two new batteries, and is on its fourth charger. They keep frying even when plugged into the surge charger I bought. Meanwhile, the 812 is fine. F dealer says it’s the outlet. Condo HOA has tested the outlet and says it’s the charger and battery.
  4. Kent Adams
    Kent Adams F1 Rookie
    3,028
    Of course they would say its the charger, lol. You likely are getting some "dirty power" to that outlet, or perhaps that outlet is suffering from too many surges or possibly too many quick power failures which will fry a computer board in no time.
    430jm and 05F430F1 like this.
  5. 430jm
    Jun 11, 2017
    443
    Atlanta
    Much appreciated Kent. What kind of test should I demand they do? Thanks!
  6. Kent Adams
    3,028
    Make sure you are using a quality charger, like CTEK, have a certified electrician of your own come out and do a test and if nothing shows up while he/she is there testing, use one of these with your charger: https://www.dell.com/en-us/shop/isobar-ultrablok-428-surge-suppressor/apd/a5509799/power-cooling-data-center-infrastructure
    Your charger should be properly specced for your car. If you're already using a higher end CTEK and you've gone through so many, its a problem with the outlet. An electrician can use an oscilloscope on your outlet to check voltages. Most surge protectors on the market are garbage, but the one I linked here is a good one.
    430jm likes this.
  7. Kent Adams
    3,028
  8. 430jm
    Jun 11, 2017
    443
    Atlanta
    In other words, don’t get another Ferrari charger? Much appreciated
