Switching my oil to Redline. Any thoughts why I should not? | Page 2 | FerrariChat
Discussion in 'Technical Q&A' started by xavior, Nov 14, 2006.
  1. Rifledriver
    37,288
    One is red and the other isn't.
    75/90 NS is a GL5 and MTL is a GL4. For all I know they put red dye in MTL and put more sulpher (a common EP additive) in 75/90. Whatever the difference in chemistry the MTL makes shifting easier in a trans with no mechanical issues.
  2. Crallscars
    Crallscars F1 Rookie
    Jun 7, 2006
    2,512
    Bainbridge, GA
    Douglas Crall
    Sounds good to me, if you recommend it, thats what I'll use
    MTL for thee Trans, Castrol GTX 20-50 for the engine,
    Got any good stock tips? Looks like Clear Channel is selling all their TV stations and about 500 of their 1200 radio stations, hope my next owner can put up with me....
  3. Rifledriver
    37,288
    Just have to do like me. Make it so it costs more not to employ you. Doesn't really matter how much they don't like you then.
  4. jonesdds
    jonesdds Formula 3
    Aug 31, 2006
    2,163
    SB,CA & Park City UT
    Jeff
    My 328 has been running 20-50 Castrol GTX and I've always heard from mechanics that it is best to keep things as constant as possible. It's not the type as much as the frequency with this car I would think as well. Not sure what to do with the tranny. I've always used redline products in the diffs and tranny's of my BMW's. 75W90 synthetic, Mobil 1 I think, in the tranny currently. I would be interesting to try other options to see if shifting is improved, not that it's a problem. I'd be curious if a redline product would improve cold shifting in the car especially.
    Jeff
  5. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,832
    Cerritos, CA.
    Everybody is talking about Red Line what about Amsoil what's wrong with them, I use them with no problem and not a drop of oil anywhere on my 308 QV, runs smooth, quiet, and stable oil temp at normal op. temp. and stable oil preasure at 85lbs.
  6. Gary48
    Gary48 Guest
    Dec 30, 2003
    940
    Miketuason, Those two and Mobil 1 are as good as they get.
  7. enjoythemusic
    enjoythemusic F1 World Champ
    Apr 20, 2002
    10,676
    Worldwide
    Steven
    Love Amsoil 75W-90 SVG for the tranny. Motor oil, prefer Mobil 1 0W-40. If your hot pressure is 85 lbs at 5 krpm you may want to try using a thinner oil. Also, read AEHASS' papers about oil and visit BITOG discussion board. Seems to me your pressures are very high, meaning your oil is too thick and you could be causing more wear during start up as well.
  8. whammy
    whammy Rookie
    Feb 15, 2018
    48
    Glenn Cox
    My 456 GT is 23 years old. I'm in Sydney so the climate is mild all year round. Should I stay with specified oil rating or go to something more suited to an older engine? I use LiquiMoly 10W60 in older BMWs.
    w
  9. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    9,742
    I would still recommend the 10W-40 version.
    The engine in the F355 was designed and clearanced for a 40 weight oil (14 centiStokes) at 100ºC.
    In addition the engine materials were chosen so the engine would not self destruct at an oil temperature of 305ºF so long as the oil maintained an HTHS viscosity of 4.2.
    And finally, the valve train had materials chosen that desire 1100 PPM of ZDDP in order to live a long and healthy life.
    Those are the 3 numbers you look for in an oil for the F355. 12-15cSt, HTHS > 4.0, and 1100 PPM ZDDP.
    A long time ago, RedLine had a 5W-30 oil that met every one of these numbers except the HTHS was 3.8 (or 3.9). I tried it it worked good.
  10. moysiuan
    moysiuan F1 Rookie
    4,254
    Canada
    Red Line uses a "true" synthetic ester base stock that is quite expensive, not the same as most other "synthetics" which are actually still refined from conventional petroleum oils. I think Motul and Silkolene use a similar base stock chemistry to Red Line, maybe some others do too. Other oils have either natural esters, or much lower levels of the types of esters used in the Red Line. Whether that makes Red Line "better" is wide open to debate, its not like the other oils like big company Mobil or the boutique company Amsoil are lacking anything by using different base stocks and additives. Different chemistry seems to get you to the same ends, for most normal (non industrial) applications. But as a product, I think it is fair to say you do get something for the extra cost of Red Line, being a more costly base stock. You are not paying for marketing, packaging or multi level distribution business models which can be the case in this highly marketing driven industry.
    The only possible downside I am aware of is the type of esters in Red Line which give it some positive solvent/cleaning properties can be harder on some types of gasket and seal materials ("ester" is kind of a chemistry word for alcohols, and eg. we all know what alcohols in gas can do to hoses and seals if your car is not set up for it in the first instance). Not an issue on modern gasketry, but if you have an old original car, with original gaskets, like pre-1990, you might end up with some leaks where you otherwise might not have had any. But that also probably meant your gaskets/seals were getting heat and age hardened anyway.
  11. ago car nut
    ago car nut F1 Veteran
    5,523
    Madison Ohio
    David A.
    I believe, and correct me if I'm wrong. The difference between Gl-4 and GL-5 gear oil is: Gl-5 is designed for extreme pressure in a hypoid type ring and pinion. And GL-4 is for helical type diff. GL-5 is some transmissions might make the synchro rings too slippery to shift good. Use the type of gear oil recommended for your particular drive train!
  12. AceMaster
    Feb 6, 2009
    34,789
    Ontario, Canada
    How did you find a 12 year old thread?
  13. Mitch Alsup
    Nov 4, 2003
    9,742
    The guy in front of me resurrected it.
  14. AceMaster
    Feb 6, 2009
    34,789
    Ontario, Canada
    Sorry that was meant for him not you
