System Not Programmed error, after putting in redone Sticky HVAC Panel | FerrariChat
Discussion in '458 Italia/488/F8' started by 328Stuts, Oct 28, 2023.
  1. 328Stuts
    328Stuts Karting
    Aug 17, 2013
    185
    TN
    Chris
    Just got parts back from Sticky RX (top notch job btw) changed out Dome light cluster and HVAC panel... getting a System Not Programmed error... everything works fine. I have an Antigravity battery and its good to go...
    Anyone else had this issue after doing the swap? Seems unusual..
    Thoughts?
  2. Bob in Texas
    Bob in Texas F1 Rookie
    Apr 23, 2012
    2,733
    Just East of Weird
    Bob
    Had the same error pop up after some a/c work. The error went away.
    You might try turning the car on and off a few times. Lock/unlock car, go for a short drive.
    All easy to try and costs nothing.
    Sent from my iPad using Tapatalk Pro
  3. 328Stuts
    328Stuts Karting
    Aug 17, 2013
    185
    TN
    Chris
    Dave at Sticky was a great help, after swapping the old unit back in to test, the error went away, even though both the new 'de sticky' one worked flawlessly as well as the sticky one... just swapped the electronics from one to other, to it still used the old electronics but the "de sticky'd" panel.. works fine it was stranget bit it is what is.
    I did try doing a test drive etc.. and the error never went away until the old one was swapped out...
    Thanks all!
