T-28A Pilot/PPI report | Page 2 | FerrariChat
Discussion in 'Aviation Chat' started by snj5, Oct 29, 2007.
  1. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    You hear from a lot of folks on the A model being a bit sluggish or even underpowered, so it's time to run the take-off numbers here in hot south Texas.
    I pulled out the old pilot manual and ran a summer case scenario. On a hot 100 degree F day here in San Antonio the density altitude is usually around 3,700 feet for SAT's 800 foot elevation. Using a gross weight of 7000 pounds the take off distance with zero headwind is about 2000 feet ground run. On the more typical 85 degree day here it plots at around 1750 feet with zero headwind.
    Whay are you Dallas guys seeing up there?
  2. rob lay
    rob lay Administrator
    Staff Member Admin Miami 2018 Owner Social Subscribed
    Dec 1, 2000
    64,570
    Southlake, TX
    Rob Lay
    I've seen 2,500-3,500 density several times this summer, but I was also flying a bunch after work when it was the hotest.
  3. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    Hey everyone - If you have a take off performance chart on the airplane you fly, what kind of take-off distances are you seeing say for example at 85 degrees and a density altitude of 3500 feet as a comparison? The A model needs about 1800 feet no wind at gross as we saw before. It would be interesting to compare ground runs.
  4. boffin218
    boffin218 Formula Junior
    Oct 8, 2005
    888
    Philadelphia
    Chris
    It is a late contribution to the thread - especially since your T-28 is undergoing a PPI - but I was curious SNJ5, if you'd looked at the T-34? I hear the 'C' model can be a real treat to own/fly.
  5. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    A great suggestion, a terrific flying airplane.
    The T-34, which I have flown several times, is a great little airplane. They also are currently an airframe AD nightmare. In addition to the ones (especially the spar re-work) already, the word is the FAA has another major airframe AD in the works, or could even ground the fleet. I do not think it is Beech's errors, rather that the fleet has been mistreated by many owners. So, the T-34 is currently a maintenence non-starter for me.
    The T-28A, in over 50 years, has ONE airframe AD for a trunion inspection.
    It's built like a tank.
  6. boffin218
    Oct 8, 2005
    888
    Philadelphia
    Chris
    I had no clue the T-34 was such an AD nightmare. The T-28 definitely seems like the way to go.
    I used to admire a T-28 at the airport near my parents' house. I never managed to meet the owner, but always liked it --- even when taxiing behind it and thinking 'good gracious that thing is HUGE'.
  7. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    Well, I am flying the guy up from Miami to do a PPI. He is one of the best in the country, and will be doing the inspection after Thanksgiving. Here is an excerpt from the email with the breakdown of the ppi costs:
    " Airfare (Southwest) $138.80 roundtrip
    Hotel (Ramada Inn) $ 67.80 one night
    Rental Car (Alamo) $130.72 11/26 returning on 11/27 @JAX
    $337.32
    Travel expenses must be paid in advance and per diem rate ($600/day) paid upon completion of inspection. A detailed written report including photos of any maintenance issues found will be provided to you"
    Well, it's a bit expensive, but it IS better to bring someone in from out-of-town. Actually, except for the travel, it is much like a Ferrari ppi.
    I checked with the current owner and he verifies that the insurance quotes I have been getting are about right with the cost and 5 hours dual. I've a new medical and will schedule a cmplx BFR prior to pick-up. My last bfr was in a T-6, so will have to get used to nosedraggers again. :) Have a tenetive hangar deal set for December, as it looks like pick-up and check-out will be the first week in December if the ppi goes well
    I re-asked him what to flight plan and he said 180 kts at 8K or 10K at about a 38 gph fuel burn. I also inquired about take-off distances. He said his was quite a bit lighter and he routinely worked off of 3000 ft strips in 100 degree wx no problem.
  8. Spasso
    Spasso F1 World Champ
    Feb 16, 2003
    14,656
    The fabulous PNW
    Han Solo
    Very exciting Russ.
  9. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    Thanks Dana -
    I did get the actual weights of the plane and it is substantially lighter than a stock T-28A.
    N8089H weighs in at 5742 pounds with a long range fuel gross of 6870 while the stock aircraft grosses at 7400 - 7500 pounds, so about 600 pounds lighter. That neatly corresponds to the claimed 600 pounds shed during the removal of the old avionics and such. So that reduces the pounds per hp to 8.58 from 9.37. (To compare, a T-6 is 9.16 pounds per hp).
    This is good.
  10. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    For those of you interested in the details of this to get a plane for yourself, I think now is the time in the off-season.
    The loan came in at 7% for 20 years at Bank of America.
    PPI will be done Monday-Tuesday
    The hangar hunt was problematic here in San Antonio - one problem being the height of the plane listed at 12' 8" and the tallest hanger that was available was 12'6". Well, the previous owner actually measured and it came out to 12' even, so we are looking at a 48' hangar that is 12'6" tall. There are 42 foot hangars that would fit the 40 wingspan, but right now I think I want a little room. It will be at Boerne Stage (5C1), although I may move to Stinson if a hangar opens up there.
    I am setting up a 'round robin' landing training route that takes me to several local fields to practice pattern work and landings, with full roll-outs at each landing and taxi backs (good to run checklists for a new guy).
    Everyone's invited for a ride if you're here in San Antonio once I get good in this thing.
    best
    rt
  11. Bob Parks
    Bob Parks F1 Veteran
    Nov 29, 2003
    8,018
    Shoreline,Washington
    Robert Parks
    Russ, from what I was told by a friend of mine who owned a T-28, it is a creme puff of an airplane to fly. He went from a C-172 straight into the T-28 without a problem. Really a good looking bird. The weight sounds like it's close to that of an empty P-51 which isn't bad with an R1820 up front.
    I'm referring to a great guy who ran into a mountain a few years back but he had a great looking T-28. Post more pix.
    Switches
  12. rfking
    rfking Formula Junior
    Nov 16, 2003
    785
    Italy
    I love it when a plan comes together!
  13. Spasso
    Feb 16, 2003
    14,656
    The fabulous PNW
    Han Solo
    Sure would be a great X-mas present.
  14. rfking
    Nov 16, 2003
    785
    Italy
    I hope you plan on picking it up before the 19th of December and making a stop here in Birmingham - that's when I leave for Seattle for the holidays. I want a ride!
  15. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    #40 snj5, Nov 23, 2007
  16. Spasso
    Feb 16, 2003
    14,656
    The fabulous PNW
    Han Solo
    I can kind of relate to that waiting thing....................
    Hope it turns out.
  17. rfking
    Nov 16, 2003
    785
    Italy
    I know it's not nearly as bad, but the Ferrari has been in the shop having its 30K major inspection since November 3rd - I'm ready for it to be out!!!!! Should be by Wednesday next week. Just gotta keep my fingers crossed that it costs less to get out of hock than Russ' new T-28.
  18. Spasso
    Feb 16, 2003
    14,656
    The fabulous PNW
    Han Solo
    Your Mondial being a 3.2 instead of a "T" should guarantee that. The "T"'s can be very needy as well as requiring an engine out for service..
  19. rfking
    Nov 16, 2003
    785
    Italy
    Here's hoping you are right on that point. The main thing is that I want to be confident that I can continue to drive the thing as a daily driver for another 15K without being stranded on the side of some Alabama road.
  20. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    Will post the full results next week, but overall looks good. Need to replace some aileron trim tab forks. Engine seemed to be in good shape. He made the comment that the fuselage was exceptionally low time and 'un-bent' at 2800tt, which he describes a s a practically new airplane.
    Right now plan is to pick up plane next week. Here we go!
  21. rfking
    Nov 16, 2003
    785
    Italy
    Great News! Keep us posted.
  22. rob lay
    Dec 1, 2000
    64,570
    Southlake, TX
    Rob Lay
    hot dawg diggity!
  23. Spasso
    Feb 16, 2003
    14,656
    The fabulous PNW
    Han Solo
    WOW!! THIS IS SO COOL!!
    I hope there are no surprises.
  24. Spasso
    Feb 16, 2003
    14,656
    The fabulous PNW
    Han Solo
    Properly maintained, that 3.2 will not let you down. The bottom end on that engine is basically the same as used in the F-40.
    Just keep it full of oil and keep the valves away from the pistons!
  25. rfking
    Nov 16, 2003
    785
    Italy
    The inspection is basically complete and they are putting everything back together. They had a couple of values on one bank that were "tight' so they pulled one of the camshafts and adjusted the tappets.
    The clutch master cylinder had developed a bit of a leak - I had noticed it at high speed shifts feeling like it was "wearing" - but apparently the clutch is fine.
    The waterpump has been replaced, as it had started to leak anyway and was beginning to sound like a chain dragging with the bearings failing. Also being replaced are several (20 year old) hoses, so I expect to have it back by Monday or Tuesday in virtually new condition.
    And they are looking at stiffening the anti-roll bar for track days. We'll see.
