t.360 not starting and dash lights flickering | FerrariChat
Discussion in 'Technical Q&A' started by zapper/dapper, Aug 21, 2024.
  1. zapper/dapper
    zapper/dapper Karting
    Feb 26, 2004
    53
    My 360 wont start and dash lights flickering.. with Warning light flickering. I have a battery tender connected overnight. I was able to jump-start the car though.
    What may be the issue?
  2. Qavion
    Qavion F1 World Champ
    14,290
    Ian Riddell
    Just curious…. What gave you the idea to provide your vehicle with an alternate/supplemental (dc) power source?
  3. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,928
    Central NJ
    Dominick
    Bad battery
    imahorse likes this.
  4. imahorse
    imahorse F1 Rookie
    4,354
    WI
    Dustin
    Qavion likes this.
  5. Qavion
    14,290
    Ian Riddell
    +1
    @zapper/dapper You probably have a bad battery (or trickle charger), but because you jump-started a "modern" Ferrari you may now have more serious issues.
    RedNeck and imahorse like this.
  6. zapper/dapper
    Feb 26, 2004
    53
    Was using a battery tender but not doing the job
  7. zapper/dapper
    Feb 26, 2004
    53
    Thanx..appreciate reply
  8. 6ated
    6ated Rookie
    Sep 4, 2024
    16
    Salt Lake City, UT
    Bradyn L.
    For sure a dead battery. Yes it is not typically a good idea to jump start because you run the risk of frying other electronics in the car you probably got away with it this time, assuming you haven't noticed any electronic issues yet. I know that's a pain when it's something as simple as a dead battery but you're better off paying what $200 or so for a new battery and taking maybe 20 minutes to replace than kicking yourself later because you accidentally damages something else that's now a much more expensive fix.
    For future use, if you want to make sure you don't kill your battery, there is a kill switch in the frunk on the passenger side of the car that's a knob you can turn so your battery can last much longer with nothing being able to draw from it while sitting. I do recommend a trickle charger though and make sure it's working using a multimeter if unsure.
