Tach and Speedo Trouble | FerrariChat
Discussion in '308/328' started by Premoto1, Jul 21, 2016.
  1. Premoto1
    Premoto1 Formula Junior
    Jun 6, 2013
    263
    Cincinnati, Ohio
    Tyler Winslow
    Looking for some guidance regarding a sporadically inoperative tach and speedo. They are inoperative independently from each other in that the problem doesn't occur between the two gauges simultaneously. So far we checked the speed sensor at the trans-axle, which was loose. We tightened it up but the problem is no better. We then checked for the tach signal wire connection at the coil and found it to be good. My next step would be to remove the gauges and check input signals to determine if the problem is wiring or the gauges themselves. When they're working, the do so accurately and smoothly. Let me know if I'm on the right track or if you have any other suggestions.
    Thanks,
    Tyler
  2. MNExotics
    MNExotics F1 Rookie
    2,631
    Good Thunder
    Ben Gruenzner
    Before my speedo sensor died it was sporadic. Other than that I would check the ground before replacing parts.
  3. Dr Tommy Cosgrove
    36,460
    Birmingham, AL
    Tommy
    Yeah, but his tach is acting up too so it is probably something other than the sensor (unless it is an odd coincidence)
  4. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    This first. I added a second ground to the instruments. Helped steady gauges and brighten lamps.
  5. Alden
    Alden F1 Rookie
    3,633
    Central Florida
  6. Premoto1
    Jun 6, 2013
    263
    Cincinnati, Ohio
    Tyler Winslow
    Just to update as both issues have been resolved. The tach problem was due to a faulty voltage regulator that was causing the alternator to over-charge. The speedo was a ground issue with the sensor at the gearbox. Removed it to take it apart and check diodes and found the ground wasn't making good contact with the circuit board. Viola!
  7. mwr4440
    57,988
    Bavaria, The 'Other' Germany
    Mark W.R.
    Robert,
    How did you do this?
    Do you have pics?
  8. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    Sorry no picture but just ran a wire from chassis below instruments up through gauge area then to each instrument mounting post.
