Tach signal wire | FerrariChat
Tach signal wire
Discussion in '348/355' started by Godspeed!, Dec 7, 2014.
  1. Godspeed!
    Godspeed! Karting
    Dec 1, 2006
    137
    Mandeville, Louisian
    Dave Foley
    On my way to completing the Electromotive Tech Gt install on the 94 348, but need some help please.
    Needing the pin out for the plug at the tach. I am assuming the brown wire is the tach signal? Just need this to get gauges back in and such. can't seem to source a diagram online.
    Thanks for the assistance. As mentioned before, will post pics and experience with install, but she runs great!
    Godspeed!
    Dave
  2. pnicholasen
    pnicholasen Formula 3
    Jan 14, 2011
    1,364
    South of Philly
    Paul Nicholasen
    It's the center wire of the 5 wires in the plug. I'm pretty sure it is brown.
  3. Godspeed!
    Godspeed! Karting
    Dec 1, 2006
    137
    Dave Foley
    Paul, Thank you............
    Godspeed!
    Dave
  4. pnicholasen
    Jan 14, 2011
    1,364
    South of Philly
    Paul Nicholasen
    Glad to help. If you have trouble trying to get your application to work, give this video a try. I used that middle wire to put in a shift light, but to get the correct tach reading, I had to use an unusual scale on the device. Don't know if that's something you will have to deal with or not.
    https://www.youtube.com/watch?v=knDl-SPy1cc
  5. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,614
    The Brickyard
    The Bad Guy
    You are a great Stooge and a valuable member of the The 348 Brotherhood!
  6. Godspeed!
    Godspeed! Karting
    Dec 1, 2006
    137
    Dave Foley
    Paul,
    I was thinking the same thing. Since the factory utilized two ecu's , the tach is probably set up for a 4 cyl signal. The Tech GT is of course programed as an 8 cyl. So this will be interesting..................
    Godspeed!
    Dave
  7. whyte
    whyte Formula Junior
    Apr 25, 2006
    409
    Merritt Island, FL
    John C
    Can't wait to see how this turns out! Will be awesome to get some aftermarket management options documented and tested.
  8. pnicholasen
    Jan 14, 2011
    1,364
    South of Philly
    Paul Nicholasen
    Yeah, the settings for the shift light weren't exactly intuitive, so I had concerns you would encounter similar issues.
    So the big question is why are you changing your fuel injection system?
  9. Godspeed!
    Godspeed! Karting
    Dec 1, 2006
    137
    Dave Foley
    #9 Godspeed!, Dec 11, 2014
    Full story soon. As with many stories attached to Ferrari purchases, this is a good one!
    John C, the car runs extremely well. Tech GT is set up presently with only crank sensor. See pic. No idle control, no cam sensor, no O2 sensor. Preliminary start up tune/ run was accomplished with a wide band O2 sensor temporarily installed.
    Attached pic presents crank sensor mounting. and is reflective of the overall quality of the install. Custom mount which installs in existing pick up lug, positioning sensor precisely at 11th tooth on stock 60-2 wheel .
    An interesting journey it has been, will share all findings and solutions!
    Godspeed!
    Dave
