Tach trouble 86 Testarossa | FerrariChat
Discussion in 'Technical Q&A' started by CRUZINTR, Jan 18, 2005.
  1. CRUZINTR
    CRUZINTR Rookie
    Jan 18, 2005
    8
    Santa Cruz, CA
    John DeAngelis
    Tach stopped working correctly a month or two ago. Now shows idle of 1K, but when rev'ed up, shows maybe as high as 2000 to 2500 RPM when it's turning 4000 to 5000rpm. Once in a while, it does show correct reading, but not often.
    Any ideas about what components I could check, electrical contacts, their physical location, etc.
    It's not good to use the rev limiter as a shift point indicator, a working tach is better.
    Thanks, 86TR
  2. ASG 86TR
    ASG 86TR Formula 3
    Aug 23, 2001
    1,474
    New Jersey
    Adam G
    Typicaly it is one of the sensors. I replaced mine as well as a few other. I cannot for the life of me rem which sensor it is, but I think it is the one on the flywheel.
  3. Rifledriver
    37,288
    If those sensors are bad the motor won't run. One is the rpm sensor, the other is the crank position sensor for the Marelli Ignition unit. Either one quits, the motor dies. If the signals are getting to the tach (check them, there is no substitute for good old fashioned diagnosis) it is a bad tach. If the signals are not present go up stream and find out where you lose it. This will require the Testarossa electrical manual. If you do not have one finding electrical faults will be like banging your head against the wall.
  4. f355spider
    f355spider F1 World Champ
    18,055
    All the 3.2 engine cars from the mid/late 1980's had a similar problem. It sounds exactly the same, the tach constantly reads low. I sent the tach from my 1987 328 to Palo Alto Speedometer, and Helmut the owner was well aware of the problem, and turned it around in about 3 or 4 days. $150, worked great from then on...
    http://www.paspeedo.com/
    Apparently there are some components in the tach that commonly fail.
  5. CRUZINTR
    CRUZINTR Rookie
    Jan 18, 2005
    8
    Santa Cruz, CA
    John DeAngelis
    I went to PASPEEDO at lunch today... Owner(paspeedo) had a TR + many customers with this low reading problem. Got an appointment on Fri to repair....Thanks!!!
  6. khayes
    khayes Formula Junior
    Nov 1, 2003
    591
    Austin, TX
    Kelly Hayes
    There is no rev limiter on my 86 TR. It'll run up as high as you care to push it.
  7. f355spider
    18,055
    Glad to be of help.
    Regards,
    Dave
