Tachometer/revcounter problem.. | FerrariChat
Discussion in '308/328' started by marc.l, Jul 6, 2009.
  1. marc.l
    marc.l Karting
    Feb 25, 2008
    78
    Help, my rev counter only works when the lights are on. Checked all the wireing around the coil end and can find no problem, I havnt taken any thing apart at the rev counter end so cant see there being a problem that end. Dose it sound like a earth problem ? Any one got any idea of were to start trying to fix it ?
    regards
    marc
  2. chrmer3
    chrmer3 Formula 3
    May 19, 2006
    1,719
    USSA
    Chris
    Pull the gauge and start with connections.. my guess is somehow when the lighting circuit is energized its completing the missing(corroded/oxidized) circuit. My gut would say ground related but unsure if ground is switched on the 328 lighting... Typically ground goes direct (not switched) & would not affect if lights are on or off (unless somehow switched completing the circuit).
    Pull gauge & make your own ground connection to see if thats issue... should be able to find issue using detective work..
    Good Luck
    Chris
