News
Tail light
Discussion in '348/355' started by Guss23, Sep 13, 2019.
  1. Guss23
    Guss23 Rookie
    Jun 11, 2017
    42
    Indianapolis
    Jason Sharkey
    My center stop light was not working in my car so I pulled the light out and there is no feed wire. It looks as though somebody removed it or pulled it out. Can anybody advise on where I would find it’s routing? Where does it originate?
  3. Ferrarium
    Ferrarium F1 Rookie
    2,918
    Central NJ
    Eric
    When you close the rear deck, on the passenger side rear there is a metal plate. That contacts a plunger on the same position on the rear deck cover. The current is transferred there when it is closed. So the lights will not work when deck lid is open. So the light has a connector though the rear deck lid that terminates that at rear plunger. Have a look when you see it it will make sense.
    Qavion likes this.
  4. Guss23
    Guss23 Rookie
    Jun 11, 2017
    42
    Indianapolis
    Jason Sharkey
    Thanks, that makes sense!
