tail lights on 308 | FerrariChat
tail lights on 308
Discussion in '308/328' started by drghamm, Mar 2, 2009.
  1. drghamm
    drghamm Karting
    May 15, 2008
    58
    Texas
    Gary
    I had some paint work done on my 80 308 and the tail lights are now in wrong, how hare is it to move these lights? I do not want to damage them and just need to know how to reverse them back to normal. Thanks
  2. greg328
    greg328 F1 Rookie
    Nov 17, 2003
    4,209
    Austin, TX USA
    Greg
    Reach inside the trunk, peel back the carpet and you'll see how easy this task is. If I remember correctly, there are 4 long screws holding each light in. Just remove and re-orient, taking care to mark the wire clips, and to not damage the light housings, as they are expensive to replace!
    There may be another step or 2 I forgot, as I haven't had mine out in a few years...
    Good luck,
    Greg
  3. Joe_CT
    Joe_CT Formula 3
    May 16, 2007
    1,778
    CT
    Joe
    #3 Joe_CT, Mar 2, 2009
    Very easy. Just get inside the trunk area and you'll see how easy it is. This is one you can definitely tackle yourself.
  4. Steve Magnusson
    26,806
    #4 Steve Magnusson, Mar 2, 2009
    Be very careful about how much you tighten the mounting nuts during reinstallation (these aren't cyl head nuts ;)) -- it's very easy to pull the studs out of the (aged) plastic housing. If there's already some cracking in the plastic, you might want to try to repair/reinforce somehow.
  5. BigTex
    79,380
    Houston, Texas
    Bubba
    I'll add to the caution, the whole housing is brittle, so as Steve says go easy on those long studs and popping the bulb holder out is a delicate task as well!
    Good luck......they are only about $450 each, if you ruin one.....:D :D
  6. drghamm
    drghamm Karting
    May 15, 2008
    58
    Texas
    Gary
    Maybe I should just leave them the way they are
  7. 4re308
    4re308 F1 Rookie
    4,882
    Woodstock, GA
    Mitch D
    There has been discussion about this before, but there have been several cases of a 308/Mondial/328 with the taillights reversed from other 308s. I'd just leave it or take it back to the paint shop and have them do it.
  8. Steve Magnusson
    26,806
    Yuck -- it's not THAT hard to do, just wanted to warn you not to crank down overly hard on the nuts.
  9. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,810
    Cerritos, CA.
    I would, if it ain't broken, don't fix it:)
  10. Irishman
    Irishman F1 Rookie
    Oct 13, 2005
    3,524
    Raleigh
    Kevin
    If you get out enough or post pics around here eventually you will be beaten into submission by well intending folks constantly pointing out the discrepancy.
  11. cockrill
    cockrill Formula 3
    Jan 23, 2008
    1,088
    Columbia, MO
    Jeremy Cockrill
    It's very easy to do. You'll need a 4mm and 6mm (I think) long socket. The larger one is for a ground wire connecting to the chassis. Nothing should break unless you drop something. Again, very easy and "novice" friendly project
    --Jeremy
