Taillight nut stripped, ideas? | FerrariChat
Discussion in '348/355' started by Ferrarium, Dec 16, 2018.
  1. Ferrarium
    Ferrarium F1 Veteran
    Sponsor Rossa Subscribed
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    On my 348, the plastic hand nut just spins, I assume the brass nut in the plastic has stripped its teeth and is just spinning. I pried the backing bucket to apply pressure to the nut like you would do with a cage nut, that made no difference either.
    Before I start cutting and what not I figured I'd see if anyone has encountered this and has an elegant solution.
  2. Wade
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
  3. Wade
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
    #3 Wade, Dec 16, 2018
  4. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    yep the nut actually tightens down tight, when backing in out it then just spins, so its not the nut, must be the stud. Will have to buy a new housing cover and cut this one off I imagine. ugh...
  5. m.stojanovic
    m.stojanovic F1 Rookie
    3,221
    Serbia - Niš
    Miroljub Stojanovic
    If the stud is turning together with the nut, then the stud should come out of the lamp housing as it is threaded into it like a self tapping screw (see pic). Remove the other nuts and then, while turning the offending nut, apply some pull on it and the cover should come off together with the stud and nut. Then, you can hold the stud at its hex to undo the nut. The brass insert of the nut can get stuck on the stud threads so use some penetrant or WD40 and turn the nut in small increments in and out until you feel it is loosening.
    johnk... likes this.
  6. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    That exact what I thought Miro, it was the first thing I did, no dice, it just spins when undoing. I tried light and heavy pressure. Very odd. The nut tightens down snug but when backing off after 1 turn it just spins. I ordered a new back cover but I am not sure they are available. If so I'll cut it off and see whats happening.
    Daniel I saw that, do you have the threaded boss also the nut screws into?
    Thanks!
  7. Wade
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
    Thanks for the photo/reminder. I'd forgotten that the stud and nut were one piece.
  8. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    Looking at that photo, thanks btw... I bet the big threads in the in the back of the light are cross threaded and is now just spinning. When you apply pressure you can fell the light moving out then back in then out then back in as it turns.
  9. Ricambi America
    Sponsor Owner
    No, we do not stock those.
  10. m.stojanovic
    3,221
    Serbia - Niš
    Miroljub Stojanovic
    That means that you have already unscrewed the stud from the lamp body. Don't apply pressure on it, pull it outwards together with the cover.
  11. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    Yes did that as well, spun no pressure, medium and hard pressure for almost 30 min. Even tried slipping small box wrench down there to catch the nut. Hand nut just spins but it always tightens back up snug with 1.5 twists. I am guessing sheet metal threads are cross threaded on the way out.
  12. m.stojanovic
    3,221
    Serbia - Niš
    Miroljub Stojanovic
    I forgot about the fact that the lamp studs go through the sheet metal from outside. In addition to the four studs that also hold the rear cover, there are two more in the middle. All six studs have standard nuts (under the rear cover) that hold the lamp to the sheet metal. If you could pull the rear cover back as much as it will go and somehow undo the inner nuts on the studs (except the offending one), you could pull the lamp outwards and then deal with the stuck plastic nut. However, a new rear lamp cover seems to be the only possible solution. I bought one from Eurospares a couple of years ago so they might still have them.
  13. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    Crap the LH plastic cover is NLA. Searching for a used one now before I cut it off.
  14. m.stojanovic
    3,221
    Serbia - Niš
    Miroljub Stojanovic
    The alternative is to destroy ("Dremel out") the head of the plastic nut, if you have sufficient access to it. If you can grind down the star shaped part of the plastic (it is hollow) including the thin flange resting on the cover, you will be able to pull the cover out.
  15. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    Ohh cheers! That's a freaking GOOD idea, get a carbide dremmel cutting bit down in there. Then I can diagnose the issue and retain the impossible to get bucket.
  16. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    OK I got it off for others. I did what Miro suggested. Easy breezy. At least for this one where I had easy access. The left cover is NLA so chopping it apart is an issue. The issue was the jam nut was NOT tight on the stud and the stud was just spinning. You can see it in picture 3 below. If your ever back there double check those.
    • First step is hacksaw off the excess nut.
    • Dremmel off the face of the nut with a Dremmel and a carbide bit, (it looks like a straight cut router bit)
    • Pry the cover off to pop off the excess plastic you could not get after you get 80% of it. (it tends to just spin)
    • What your left with is the shank and nut of the thumb nut you can then back off.
    • You can see the jam nut was loose and when backing off the thumb-nut the jam nut would back off the sheet metal and then just spin. Pretty sure the result was the light assembly where the stud screws into the light housing is not hogged out. If I ever take it out it can be filled with epoxy and re-tapped though.
    • Only damage was a scrape to the cover and it was actually from the hack saw, it bit in an an angle as I was sawing like they tend to do, I was cutting real close scraped the cover. I will take a wheel to that though.
  17. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    #18 Ferrarium, Dec 18, 2018
    This was all preventative maintenance too. Changing every bulb and fuse and any remotely suspicious relays in the car. Goes to show the old "while we were in there we found" always happens. In fact a captive nut slipped on my side passenger cheese grater (ugh.. a whole f'in there there). Even simple things like "change a light bulb for good measure" :) can turn south with older cars once someone else has touched that part it in the past.
    BTW I pinged the Ebay vendor about the light cover here is what he said, after we went back and forth I assumed he thought I was talking about the tail light grill cover with the Cavilino badge. Nope...
