Tailpipe "Chirp" Inserts-my DIY | Page 2 | FerrariChat
Discussion in 'Technical Q&A' started by gatsby, Jul 25, 2005.
  1. gatsby
    gatsby Karting
    Apr 26, 2005
    206
    half moon bay, CA
    jim
    No, Home Depot or Orchard Hardware only had sheets that were 22ga thick. This is very hard to roll. I got mine from a scrap metal outfit - these are the best places. You go there and ask for 26ga Stainless Steel sheet and give them the dimension and number of pieces. They will cut it for you to exact size and charge you only by weight. You could actually have them cut it to 5" X 3-1/2" rectangle pieces (4 each) and even have them rolled in their hand roller machine (looks like a dough baker's roller) and you will end up with 4 curved pieces. Then you can just adjust them to smaller diameter at home. I had my pieces cut larger and simply trimmed to size with tinner's snips at home. HTH.
  2. ronfrohock
    ronfrohock F1 Rookie
    4,150
    MA
    Ron Frohock
    As the author of the Banshee post I can tell you that I and Ferrari of New England spent a considerable amount of time trying to identify the source of the chirping sound. The thing that got us was the fact that it didn’t chirp unless the car was being driven. I guess it had something to do with the lower pressure in the area of the exhaust with the car in motion. Laminar flow or something like that.
    Any way’s, they sold me a set for my Mondial and they really worked.
    I strongly recommend them. I just wish I had known about these inserts a year ago when I bought the car.
  3. jsumnertx
    jsumnertx Karting
    Dec 9, 2004
    162
    Austin
    Yeeehaww. Thank you oh wise ones of Ferrarichat. My 308 has sounded like a VW Bug for *10 years*. I first thought it was a bad valve (because I did have one 10 years ago) but that got fixed 10 years ago and still had the chirp. Took off the exhaust and cats and still heard the chrip so I figured it wasn't the tips so I just dealt with it for 9 years. Then I saw the post on air injector plugs
    http://www.ferrarichat.com/forum/showthread.php?t=131252&highlight=injector
    and that helped, but still didn't get rid of it. So, back to this thread and $10 in steel + 30 minutes of sweat and now.... No chirp. Thank you all. Should have tried this eons ago.
    By the way, my 308 exhaust uses 4" inner circumerence tips, not 5" as is mentioned for the 328 this thread was written for.
    Right now, they are crummy inserts because I could only get zinc coated 26 ga at Home Depot and the local steel supply place doesn't carry 26 gauge stainless (though they would have been happy to order it for me for only $150). So, once I find a local source for 26 gauge stainless and some 4" circumference pipe to wrap them around, I should be sitting pretty & chirp free. I'll post before and after audio for those of you who have never had the pleasure of sounding like a VW bus.
  4. f355spider
    f355spider F1 World Champ
    18,041
    Switch to ss as soon as possible. My experience with plain galvanized sheet steel is that as soon as it gets good and hot, it will curl a bit tighter and blow out. Stainless steel has enough "spring" in it to stay put.
  5. f355spider
    18,041
    Oh, and be sure to push them in far enough that they are behind the "lip" formed where the end of the perforations stop. That edge or lip helps retain them.
  6. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,801
    Cerritos, CA.
    DO you know if that's the same measurement for the 308 QV?
  7. jsumnertx
    jsumnertx Karting
    Dec 9, 2004
    162
    Austin
    not sure but it's easy to check. The diameter of the inside of my tips was 1.25 inches. Measure your inner diameter and multiply by pi (3.14).
  8. tatcat
    tatcat F1 World Champ
    Sep 3, 2001
    11,013
    panama city beach FL
    rick c
    i like that my aircooled vw sounds like my ferrari. i actually don't hear it at all.
  9. jsumnertx
    jsumnertx Karting
    Dec 9, 2004
    162
    Austin
    #34 jsumnertx, Aug 17, 2007
    I realized the "after" isn't terribly interesting but here's the "before" in case you've never heard what a case of the chirps sounds like. It's most prominent at heavy throttle from around 2000 RPM up to around 4000 RPM.
    Also, couldn't get 26 gauge locally so I bought some 24 gauge and will install it tomorrow.
  10. GTHill
    GTHill F1 World Champ
    Jul 1, 2006
    14,054
    Double Wide
    GT Hill
    I was in the same boat as Tillman. I didn't have any idea what you guys were talking about. Unless I just don't notice it, my car (328) doesn't make that noise. Nice solution!
    Gene
  11. Air_Cooled_Nut
    Air_Cooled_Nut Formula Junior
    Nov 25, 2004
    952
    Portland, Oregon
    Toby Erkson
    Hahaha, it does sound like a stock air-cooled VW Bug! I love the deep smooth sound of the Ferrari, though :)
  12. Mike Duncan
    Mike Duncan Rookie
    Aug 11, 2007
    13
    I always thought my MOndial sounded like a VW, standing beside it at idle, even the engine noise or maybe the combination with the chirp. I knew I saved that stainless for a reason. I'm going to the garage right now!
  13. bolex
    bolex Karting
    Feb 28, 2011
    63
    San Diego, CA
    Brian
    #38 bolex, May 3, 2013
    This tread is great. I have had whistle/squeal/chirp since I got the car and have been very annoyed. I tried this with some sheet aluminum from the hardware store and it worked perfectly. The noise was gone, but as stated previously, the aluminum curled up and two of them came out while driving. Now that I confirmed it was the exhaust, I ordered an X-ost Maranello muffler.
    I know the thread is old, but thanks to Gatsby and Fchat for wonderful info as usual.
    Brian
  14. DANCER308
    DANCER308 Formula Junior
    Oct 24, 2009
    935
    KY
    Dan
    Could this same problem be fixed by removing the baffle, if it can be removed?
  15. F308fan
    F308fan Karting
    May 7, 2017
    162
    Peoria, AZ
    Tony Pacini
    2021 update: 2 sheets of K&S .018 stainless steel sheet ($7.99 each @ Ace Hardware) did the trick for mine. Cut to 3 1/8” x 4 1/16”, rolled around a floor jack handle, drove in to the tail pipes with a socket and wood block. Worked like a charm, chirping noise is gone.
    JayG likes this.
