Taking out center console on 2002 Spyder | FerrariChat
Discussion in 'Maserati' started by Friuli575M, Aug 8, 2010.
  1. Friuli575M
    Friuli575M Karting
    Jan 25, 2008
    66
    California
    I am trying to replace the face plate to the nav unit in my 2002 Spyder (getting it ready for Concorso Italiano). I have everything un-attached but now can't figure out how to get the emergency brake handle through the center console so I can lift it out.
    Does some one know how to take the e-brake handle off. I'm thinking there is a way to get the grip piece off, then the bar of the e-brake handle would fit through the leather boot.
    I'd appreciate any help that folks can offer.
    Cheers!
  2. Friuli575M
    Friuli575M Karting
    Jan 25, 2008
    66
    California
    Never mind, I figured it out. The car was not designed for maintenance :)
  3. 3M7M5
    3M7M5 Karting
    Sep 26, 2004
    183
    Speaking of maintenance, does the Ferrari engine/powertrain mean Ferrari maintenance costs? It appears to be a pretty decent daily driver, but my main concern is Ferrari maintenance costs and reliability.
  4. 3M7M5
    3M7M5 Karting
    Sep 26, 2004
    183
    #4 3M7M5, Aug 9, 2010
    I should have done a search before asking because I just found a lot of great info in other threads and on ************. I'd still appreciate your input though.
    Have fun at Concorso!
  5. DesertDawg
    DesertDawg Nine Time F1 World Champ
    93,251
    The Desert
    DesertDawg
    #5 DesertDawg, Aug 9, 2010
    I use my '02 Coupe as my DD, and outside of a couple items I had to sort out when I got it late last year, and one lighting controller module that went bad 3 or 4 months ago, so far I haven't had any major issues with reliability... they are complex cars, so there is indeed more potential for stuff to go bad, but the general consensus seems to be that if you budget in the $3k-$3.5k range a year for maintenance, you'll be right in the ballpark in most cases. Clutch replacement is the most expensive regular maintenance item on these, and $5k is the most common price tag you see mentioned for that if you have it done at the dealership (though, some indy shops appear to be able to do it for less).
    If you buy one that has a lot of deferred maintenance, though, you could be in for a lot more expensive experience in your first year of ownership... I've seen more than a few cases of that pop up on the ************ forum. And - unfortunately - a good number of these vehicles tend to come to market in that condition... people buy them, drive them for awhile, put stuff off, and once enough stuff's been put off to where it now is desperately in need of a $1,500-to-$2k major service interval, plus a $5k clutch job, and the $1,700 for a new reverse shifter pod after some ham-fisted valet just broke the T-Bar handle (those can easily be rebuilt, though - just giving you some examples of typical retail/dealership price tags), THAT's when it hits the market.
    Not trying to scare you off with the above paragraph... not all of them are like that, of course - to put it in perspective, I've spent more this year in repairs on my '02 Blazer than on my '02 Maserati, so good examples are definitely available... as with any major purchase, the more homework you do, the less you're likely to be blindsided and hit with any big surprises. Right now's a great time to buy, as the Global Economic Apocalypse has deflated the exotic market, and I would venture to say that the '02-'06 Maserati's seem to have been hit a little harder.
  6. DesertDawg
    93,251
    The Desert
    DesertDawg
    I see that you mention you've got it figured out, but I was curious as to why you're pulling the whole console in order to just replace the faceplate on your Nav unit? You're talking about the control head in the upper portion of the console near the dash???
  7. bundas
    bundas F1 Veteran
    Dec 31, 2005
    7,090
    lexington ky usa
    mitchell barnes
    i use my 02 as a daily driver. no problems at 24,000. the only problem has the dealer trying to rip me off.
  8. 3M7M5
    3M7M5 Karting
    Sep 26, 2004
    183
    Thanks for the great responses. I'd obviously do my homework before and get a well-maintained example. I would say that the Coupe/Spyder is one of the best values right now. The looks are timeless.
  9. 285ferrari
    285ferrari Two Time F1 World Champ
    Sponsor
    Sep 11, 2004
    20,958
    MD and NE
    Robbie
    +1---Sticky buttons maybe? I have a pdf file of the removal of the entire NAV and center console areas
