News
Tankless water heaters - opinions?
Discussion in 'Other Off Topic Forum' started by Mera, Nov 17, 2007.
  1. Mera
    Mera Formula Junior
    Aug 13, 2005
    661
    Milwaukee, WI
    Rodney Dickman
    I am looking at a used Takagi TM-1-N Mobius Tank less Water Heater that a guy has. It is only 2 years old and I can get it for around $600. They are around $1500 new. Looking for opinions on installing a tankless unit instead of a new tank type water heater. My water heater is around 17 years old and certainly near the end of its life. Pros and cons of converting the the tankless type or should I just stay with a tank type.
    Rodney Dickman
    1990 348 TS
  3. 8 SNAKE
    8 SNAKE F1 Veteran
    Jan 5, 2006
    6,666
    Springfield, MO
    Tankless gives you instant hot water and is more energy efficient than a conventional tank because you're not keeping a constant supply of water heated until you need it. I'd go for it.
  4. Buzz48317
    Buzz48317 F1 Rookie
    Dec 5, 2005
    2,803
    Shelby Twp., MI
    Michael
    I'd look into what the total costs are going to be to have it installed in the home. I looked into it a few years back and the install was more involved than just pluging into the water and gas feeds. The tankless system had to be specially vented etc.
  5. 2NA
    2NA F1 World Champ
    Professional Ferrari Technician Consultant Owner
    Dec 29, 2006
    17,740
    Twin Cities
    Tim Keseluk
    Other than a 3/4" gas line to supply the rather large 235,000 btu burner, the installation doesn't look too much different from a conventional water heater.
    You'll have a bunch of left over space after you replace the old tank.
    If you need to fill a big whirlpool tub it's probably the "hot ticket".
    You can download the installation manual. Read through and see if it works in your house.
  6. 62 250 GTO
    62 250 GTO F1 Veteran
    Jan 9, 2004
    7,732
    Nova Scotia Canada
    Neil
    Not quite instant right? 20 second wait?
    Much better for consumption though. By the way, where are "our" {North America} gray water systems?
  8. Gilles27
    Gilles27 F1 World Champ
    Mar 16, 2002
    13,337
    Ex-Urbia
    Jack
    I went through this about two years ago. Actually, if you search, there may be a thread. But at that time the consensus between most experts was to go with a conventional heater. It seems like tankless heaters are OK if you have a smaller home or don't use a lot of hot water. They're not great at feeding multiple appliances/showers simultaneously, and they can only be installed in certain areas of your home due to the required venting.
  9. Protouring442
    Protouring442 F1 Veteran
    8,583
    Harriman, TN
    One Stupid SOB
    What electric tankless heaters?
    Shiny Side Up!
    Bill
  10. GregD
    GregD Formula Junior
    Nov 3, 2003
    885
    California
    Greg
    I looked into it but went for a traditional heater because the tankless sytem may reduce water pressure to the showers.
    If you are the type that enjoys low flow shower heads, then it make work for you.
  11. recoil
    recoil Formula Junior
    453
    Virginia
    Steve
    I hated mine in my last house. If you turn down the flow rate of your hot water too low, it will shut down the hot water stream as a protective measure. My wife likes hot showers, I don't. As I would reduce the amount of hot water, I would often hit the "rev limiter" and get chilled. I had to periodically "tune" the settings at the heater in the attic based on the seasons. Granted, my units were about ten years old. I'm sure updates in the technology have happened since. For my newest house, I went with regular gas heaters.
    Steve
  13. Protouring442
    8,583
    Harriman, TN
    One Stupid SOB
    Interesting... thank you very much for the info!
    Shiny Side Up!
    Bill
  14. mwarrior
    mwarrior Formula Junior
    339
    Ontario and Texas
    Gagan P
    We bought a Tagaki heater last year, havent used it yet as we decided to use a Baxi (same as the Laars Mascot) heater for that building. But heres the main things I"ve noticed.
    For venting, its about the same as a regular NG water heater, although you may not be able to use ABS pipe anymore. Other than that, its great. The reason for switching is because our air handler is also using the hot water, and the Baxi/Laars units have a section for the closed loop for the air handler and then the other section for the DHW. Installation cost is about the same, I reinforced the wall myself for the mounting. Best thing is if you're out of town for say a week, your conventional heater will turn on for at least 3-4hours (or more/less? I'm guessing... feel free to correct me). The tankless will only turn on for a total of 7 minutes (well the one I installed does, I think the others do too), so that the bearings/seals do not dry out. So it comes to 4hrs of gas a week, or 7minutes? Thats 6hours a year vs 208hours.
    In the long run I think it makes sense, both for overall costs and space being saved., Plus if your kitchen is near the tank, even better. That 10-15second delay will always be there to get the water to the tap unless you install one of those under-sink systems that circulate the water through so its always hot (but then forget the 6hr/yr idle usage)
  15. BT
    BT F1 World Champ
    Mar 21, 2005
    14,790
    FL / GA
    Bill Tracy
    If it is a gas tankless it should be good for you. If it is electric you need some pretty large amperage to run the tankless for the whole house. Generally you need around 100-150 amps dedicated for the electric models. In either case you can run a recirculating pump to keep hot water available at the taps in seconds. That uses a little more energy (like $30 per month) but is very convenient.
    BT
  16. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    17,740
    Twin Cities
    Tim Keseluk
    Takagi TM-1-N Mobius Tank less Water Heater is a natural gas unit.
  17. Mera
    Mera Formula Junior
    Aug 13, 2005
    661
    Milwaukee, WI
    Rodney Dickman
    Looks like I'm just going to stay with a tank type water heater.
    Thanks for the input.
    Rodney Dickman
    1990 348 TS
  18. wingfeather
    wingfeather F1 Rookie
    Feb 1, 2007
    3,493
    rock bottom
    I worked for Takagi. I would never install their water heaters in MY house. Crap products form crap people.
  19. Oengus
    Oengus F1 Veteran
    8,304
    Between timing belts or OH, SC, CO, CT
    Chas
    I have a Takagi in my house, we put in a shower spa system and I wanted to make sure we had enough hot water as well as instant hot water.
    No complaints from my end......I also think the gov is giving a $300 tax credit on them.
  20. jimpo1
    jimpo1 Two Time F1 World Champ
    Silver Subscribed Owner
    Jul 30, 2001
    22,502
    Dallas, TX
    Jim E
    I nearly put in a tankless 2 weeks ago. Turns out the gas tankless heaters have to have stainless steel venting, with no joints or rivets. It would've cost me thousands to have my existing venting replaced, so back to traditional for us.
  21. mwarrior
    339
    Ontario and Texas
    Gagan P
    Thats not exactly true on the SS venting. You can use BH Vent (new) or some specialized piping that actually from the manufacturer.
  22. chris marsh
    chris marsh F1 Rookie
    4,616
    Detroit
    Chris Marsh
    Personally I don't have one but my hockey team mates were talking in the locker room last night and 3 guys had them and said they are wonderful and anyone looking to replace they're heater should get the tankless model.
