Targa top noise | FerrariChat
Targa top noise
Discussion in '308/328' started by tallen3335, Nov 1, 2015.
  1. tallen3335
    tallen3335 Karting
    May 12, 2014
    57
    Colorado Springs
    Tom
    Normally drive my 328GTS without the top on, but with cooler Colorado weather put the targa top on today. Unfortunately it rattles a lot. The noise comes from the back so I assume it has something to do with the latches. Checking they seem tight, so not sure what I can do to get rid of the noise.
  2. godabitibi
    godabitibi F1 Veteran
    Jan 11, 2012
    6,329
    Papineauville, Quebec
    Claude Laforest
  3. Dr Tommy Cosgrove
    36,431
    Birmingham, AL
    Tommy
    Shim the latches with a business card or something similar and see if it disappears
  4. JasonMiller
    JasonMiller F1 Rookie
    3,649
    Co Springs/ Texas
    Jason Miller
    I went driving today as well, the squeaky top was so annoying I finally removed it.. much better :)
  5. SpyderGT
    SpyderGT Formula Junior
    May 15, 2005
    997
    Vancouver, BC
    Jon
    Might it be an issue with dried out or shrunken mouldings, noting that your latches are tight, e.g, trying shims as Tommy suggests. Maybe a little glycerin to dress the mouldings? I can't say that I notice the top rattling and I drive with the top on more often than not (OK, maybe I really want a GTB as Claude suggests). Jon
  6. piezo
    piezo Formula 3
    May 27, 2011
    1,533
    Hong Kong
    Steven
    I concur :D
  7. robbie
    robbie F1 Rookie
    Aug 26, 2005
    3,015
    Los Gatos, CA
    Robert
    I think that short of lubricating the seals, rattles and squeeks are part of having the top in place. The body flex is such that the mating parts just move relative to each other. There are probably some non-petroleum based lubes that could help reduce the noise. (NO .. not KY Gel). :)
  8. Bullfighter
    Bullfighter Two Time F1 World Champ
    Jan 26, 2005
    22,596
    Gates Mills, Ohio
    Jon
    My 328 was pretty quiet with the top in place. I suspect it's the condition of the rubber.
  9. Albert-LP
    Albert-LP F1 Veteran
    8,173
    around Modena, Italy
    Alberto Mantovani
    maybe the problem are the rubber seals gone, but some noise with rattles and squeaks is a standard for a GTS.
    The GTB is definitely a better car, when the GTS has the top on
    ciao
  10. Dr Tommy Cosgrove
    36,431
    Birmingham, AL
    Tommy
    My Saratoga rattles like nothing you can imagine. And the irony is you don't appreciate the benefit unless it is left in.
  11. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,566
    San Carlos, CA
    Mitchell Le
    You lube the seal and the squeak will go away.
  12. Albert-LP
    8,173
    Alberto Mantovani
    which lubricant do you use?
    Thank you very much
    ciao
  13. Iain
    Iain F1 Rookie
    Jan 21, 2005
    3,320
    A very small amount of silicone grease.
  14. Rifledriver
    37,099
    I lube the contact points of the latches and front and rear seals as well as the alignment pins with clear silicon grease and wipe the excess with a rag. If done at annual services it keeps most of the noise away.
    http://www.sears.com/search=3m%20silicone%20paste
  15. Albert-LP
    8,173
    Alberto Mantovani
    Thanks!
    ciao
  16. robo330
    robo330 Formula Junior
    Apr 15, 2014
    608
    Michigan USA
    Karl Robertson
    I had the same problem when I bought my 1985 308 QV. Put rubber / foam washers over the two front pins, someting that will compress abou 1/8 of an inch (3.0mm) and a soft plastic tube over the jegs of the Rear Latches. All rattles gone!!!
  17. robo330
    Apr 15, 2014
    608
    Michigan USA
    Karl Robertson
    Sorry! "Legs" of the Rear Latches. Jegs may be construed to be something else...
  18. mspelt
    mspelt Formula Junior
    May 28, 2010
    269
    Tallahassee
    Mark Pelt
    I got some lube for my S2000 that was specifically for conditioning the top seals from Honda. Unfortunately l am sitting on a plane in Atlanta heading for Salt Lake City so I can't get the specifics. I use it on my 328 and have no noise from the seals only some rattling at the latch. Have what I need to fix the problem but just need the time. That being said I think I've had the top on 3 times in the last 4 years.
    Sent from my SAMSUNG-SM-G890A using Tapatalk
  19. piezo
    piezo Formula 3
    May 27, 2011
    1,533
    Hong Kong
    Steven
