Targa top storage | FerrariChat
Targa top storage
Discussion in '348/355' started by speedtrapp, Dec 14, 2007.
  1. speedtrapp
    speedtrapp Formula Junior
    Mar 26, 2007
    308
    Tommy
    To all you with a targa top car--on the floor behind the seats where the top fits into is there supposed to be anything there? my car just has 2 open holes that the spikes on the top fit into but I think there might be something missing there like a plastic plugs or something to prevent the top from ridding on the metal body also the leather top cover when I slip it over the top for storage with the latches in there locked(down) position the cover dosent fight right am i supposed to just lay it over the top and than fasten the 2 hold downs in the rear?
    thanks fellas..
    93 S/S ts
    "WHITE IS RIGHT"
  2. Elliott
    Elliott Karting
    Jun 28, 2007
    141
    Bay Area
    Elliott
    There are supposed to be two rubber plugs in those holes to hold it more securely it is very common for them two fall into the holes so before you go out and buy a new pair, although they are only a couple of bucks, check inside and if they are there take out some needle nose pliers and carefully pull them out. Good luck
  3. vvassallo
    vvassallo F1 Veteran
    Aug 4, 2006
    8,329
    Palos Verdes
    Vince V
    FYI, if you are over 5'9", there is no way you can store your top and drive safely anywhere. Put it in the garage wrapped in your car cover while you and baby go out and play. :)
  4. Elliott
    Elliott Karting
    Jun 28, 2007
    141
    Bay Area
    Elliott
    +1, I cant fit with it back there!
  5. StanT
    StanT Formula Junior
    356
    Vienna, VA
    I'm 6' tall and can drive comfortably with the top behind me. Perhaps because my '98 GTS is an F1 I don't have to worry about fussing with the seating position to control the clutch.
  6. modena2904
    modena2904 Formula Junior
    Jul 6, 2007
    917
    Ellicott City, MD
    Eric
    This isn't universally true. I'm 5'10", and there is room to spare for the top when I have the seat in the preferred position. Maybe I just have shorter legs and a longer torso.
    - Eric
  7. Elliott
    Elliott Karting
    Jun 28, 2007
    141
    Bay Area
    Elliott
    Italian driving style/English. If you drive like your in a Morgan you cant fit, if you drive like an Italian you should fit just fine.
  8. speedtrapp
    Mar 26, 2007
    308
    Tommy
    Im ok with my size 5'7 on a good day lol =the plugs are missing does daniel carry them? Thanks guys
  9. Ricambi America
    Sponsor Owner
