TCU’s Software Questions and F1 “Stuff” | FerrariChat
Discussion in '360/430' started by Mrjb, May 23, 2022.
  1. Mrjb
    Mrjb Karting
    Jan 12, 2022
    83
    Matt
    Greetings,
    I shall be the new owner of a 2001 360 spider this week.
    The F1 fluid needs flushing and bleeding. I’d like to do it the proper way, with the appropriate diagnostic equipment, however I understand that the TCU on a car from 2001 won’t actually connect to something like the X431 Launch.
    What options do I have, diagnostics wise which will give me the facilities to run bleeds etc outside of the SD software and leonardo on a car of that age.
    Second question is, the car has a slight fluid weep around the potentiometer on the bottom of the F1 unit. There seems to be a support or gasket the potentiometer mounts against. Is that support designed to provide any kind of seal against the F1 unit.
    thanks in advance.
