Tech in NorCal to reset airbag light | FerrariChat
Discussion in 'Technical Q&A' started by mello, Jul 2, 2016.
  1. mello
    mello F1 Veteran
    5,518
    CA Bay Area
    Steve
    Does any one know a place where I can reset the airbag light for a 360? Preferably Northern CA, Contra Costa county area first choice, Bay area Oakland/SF second choice.
  2. Andrie
    Andrie Formula Junior
    Mar 6, 2015
    726
    Bay Area, CA
    Andrie Hartanto
    May I know what the reason you need to reset? I've replaced the seat on my F430 with racing seat and currently has airbag light on. Wonder if I need to reset them if I put my original seat back in.
  3. mello
    mello F1 Veteran
    5,518
    CA Bay Area
    Steve
    I was working on my steering column and have to disconnect the airbag. I forgot to reconnect the airbag before turning the main power switch back on. As soon as the ignition switch is on/engine off, the system diagnostic senses that the airbag is disconnected and trigger an airbag fault. BTW, whenever the airbag light is on it means that the airbag will not deploy. I have a 360.
  4. ar4me
    ar4me F1 Rookie
    Apr 4, 2010
    3,114
    Southern California
    Jes
    Yes, any Ferrari service center - try Google ;) :) Otherwise, perhaps try post in the regional section for NorCal for pointer to an independent with SD2/3 or Leonardo...
