Technical bulletin 44? | FerrariChat
Discussion in '348/355' started by bobzdar, Mar 9, 2023.
  1. bobzdar
    bobzdar F1 Veteran
    Sep 22, 2008
    6,892
    Richmond
    Pete
    Finally getting around to the major service and found this on the top passenger side of the rear subframe: TB44 /USA/N5
    Thinking there may have been a technical bulletin for USA cars and mine was the 5th to get it? Mine is a Sep 94 build, so pretty early production.
    Going well so far, haven't found anything unexpected yet, but did notice a crack in the alt belt tensioner housing, so ordered a new one.
    308 GTB likes this.
  2. spaghetti_jet
    spaghetti_jet Formula Junior
    Jan 5, 2005
    925
    Europa
    Bob
    That was from the factory assembly, to make sure they decked the right body to powertrain. I'm guessing you have a GTB? Does your car's VIN end with 44? N.5 is probably the team or production cell that assembled the powertrain into the cradle.
  3. bobzdar
    bobzdar F1 Veteran
    Sep 22, 2008
    6,892
    Richmond
    Pete
    Ah, yep gtb, but sn is 100329, so not sure on the 44.
  4. spaghetti_jet
    Jan 5, 2005
    925
    Europa
    Bob
    Hmmm. Interesting. What about the engine sn?
  5. bobzdar
    bobzdar F1 Veteran
    Sep 22, 2008
    6,892
    Richmond
    Pete
    37706 looks like, assembly no 17273.
  6. MAD828
    MAD828 F1 Rookie
    Oct 8, 2011
    2,629
    Elliott Caras
    Mine says 8 TS 16 AUST - TS for GTS
    308 GTB likes this.
  7. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,757
    Lake Villa IL
    308 GTB likes this.
  8. spaghetti_jet
    Jan 5, 2005
    925
    Europa
    Bob
    Week 44?
  9. bobzdar
    bobzdar F1 Veteran
    Sep 22, 2008
    6,892
    Richmond
    Pete
    It has a September 94 build date, so that doesn't line up. It's a mystery but likely not materially important.
  10. 308 GTB
    308 GTB F1 World Champ
    11,717
    New Jersey
    Barry Wolinsky
    I wish I could help, Pete, but none of the pictures I have that were taken during engine out servicing show that particular view of my rear subframe.
    Barry
  11. zstyle
    zstyle Formula Junior
    Jun 28, 2007
    552
    Tempe
    Jon
  12. zstyle
    Jun 28, 2007
    552
    Tempe
    Jon
  13. zstyle
    Jun 28, 2007
    552
    Tempe
    Jon
    @ShineKen, do you have photos of your early ‘95 sub chassis’?
  14. bobzdar
    bobzdar F1 Veteran
    Sep 22, 2008
    6,892
    Richmond
    Pete
    Interesting, that's the closest explanation so far.
    I didn't find any other references while I was in there, but it's back in it's home now.
    Had to replace the cam sensors as they disintegrated when I unplugged them, but fired right up after getting it all hooked up. The Ricambi kit is really nice, and I decided to replace the tensioners as I had no record of them being done, ordered friday morning and had them Saturday afternoon. No date code on them so I'm guessing they predate when they started doing that which was mid 90s, so had to have been the originals. I did a full cam cover reseal which was a pita due to the copious amounts of sealer the last guy used. Future me will hopefully be happy I was judicious in applying it. Hopefully nothing leaks. Still a bit to go before driving it, but at least it's running and should be ready to go when the weather clears up.
    JSBMD, Mike Morrissey and 308 GTB like this.
  15. carl888
    carl888 F1 Veteran
    Oct 31, 2003
    6,933
    Melbourne, Australia
    Carl
    TB, Berlinetta
    44, Cradle number (Will match, hopefully!!) the number stamped on the LHS upper rail AND the cradle
    USA, Market
    N5, Unknown
